D800e sensor cleaning residue question
Started May 18, 2013 | Discussions
ki11ua Forum Member • Posts: 58
Hello,
I have wet cleaned the sensor using:
  • Ultra MXD-100 (Fabric) Sensor Cleaning VSwab
  • and the Sensor Clean liquid (green cap - expensive one)
After 4 tries with different direction and pressure, and of course waiting any remaining liquid to evaporate, there is always some residue left behind, visible under a light.
After many tests it doesn't seem to affect the image quality, but I am worried for any long term issues with the D800e sensor.
Any thoughts or similar behavior?
Thank you
 ki11ua's gear list:ki11ua's gear list
Sony SLT-A55 Nikon D600 Sony DT 18-55mm F3.5-5.6 SAM Sony DT 35mm F1.8 SAM Sony DT 55-200mm F4-5.6 SAM +6 more
Nikon D800E
cosmonaut
cosmonaut Senior Member • Posts: 2,180
Re: D800e sensor cleaning residue question
I would almost believe it was the cleaner not working since the spots are not coming off. I think at this point you need to take it to a professional cleaner. Can you post pictures of the sensor?
www.gregmccary.com
ki11ua OP Forum Member • Posts: 58
Sorry for any confusion, the cleaner works perfectly. No dust or oil remains.
But it seems to me that the liquid somehow leaves lines/traces.
Right now I cant upload images, but if I can't past over it, I will.
Thank you
Todd Jones
Todd Jones Contributing Member • Posts: 706
Thank you
When cleaning my D700 sensor, using Eclipse, I always have to use a dry Pecpad last to get those smudges off and I only use 2 or 3 drops of the liquid to begin with! It works perfect every time. 3 or 4 wet swabs followed by 1 dry.
Todd
 Todd Jones's gear list:Todd Jones's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/4G ED VR Tokina AT-X Pro 100mm f/2.8 Macro Carl Zeiss Distagon T* 2/35 Nikon AF-S Nikkor 20mm f/1.8G ED
Central Fla Regular Member • Posts: 438
The first time I cleaned my 800 the fluid left behind a huge area of visible film.  I used a little less fluid and tried it again and no fluid stains.  Cleaning a sensor is like cleaning your eyeball,  it just scares the h*** out of me.
Varjohaltia
Varjohaltia Regular Member • Posts: 123
I just tried cleaning my D600 sensor with VisibleDust / SmearAway. One drop on each side of the swab, as the instructions said. One careful pass from one end to the other.
All the oil drops had become long oil smears all over the sensor, and the rest of the sensor was full of cleaning fluid film residue. Yikes!
Tried a dry swab, which cleaned away some of the residue, but only smeared the oil drops worse.
Proceeded to use up all the swabs in the packet, and I still have smears and cleaning film residue all over. Obviously I'm doing something patently wrong. The smears and residue seem to be less visible than the original droplets, though, for what it's worth.
The takeaway from this is that sensor cleaning is not necessarily nearly as simple or easy as some have suggested, and I'm seriously considering paying for a professional cleaning. (Unfortunately there's none in town that I know of, so it'd be weeks without camera for that.)
 Varjohaltia's gear list:Varjohaltia's gear list
Nikon D600 Olympus PEN E-P2 Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED Nikon AF Nikkor 85mm f/1.8D +4 more
bills_pix
bills_pix Contributing Member • Posts: 541
Just blow the sensor and LensPen tip with a Giottos Rocket Blower then polish away any smears with a Lens Pen.  I've had zero issues in 6 years using it to remove smears and am very, very fussy about my images.
http://www.amazon.com/Lenspen-LENSK1A-Sensorklear-Articulated-Tip/dp/B001QUIEIS
'There is only one success - to be able to spend your life your own way.' -- Christopher Morley
 bills_pix's gear list:bills_pix's gear list
Nikon D800 Nikon D700 Nikon D2X Nikon D800E Nikon AF-S Nikkor 500mm f/4G ED VR +8 more
ragspix Contributing Member • Posts: 901
ki11ua wrote:
Hello,
Thank you
If you're waiting for the liquid to dry, you're using too much liquid. The glass should be dry (wipe streaks disappear) upon swab removal.
Rags
Phillip S Regular Member • Posts: 133
I have the D600 and used the Copperhill product. You can call and the owner will really talk and help you with cleaning your sensor. You might be surprised at what a few simple suggestions from him might do for you. Worked very well for me. Also, his system is much more economical than the others that I have looked into (but did not use).
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,506
First time I cleaned a sensor (D300), it took me 7 passes to get it done, each with a new pec pad.
You've used too much fluid, or didn't wait long enough after applying to the swab to let some of it evaporate.   Experiment with using a bit less, or waiting longer.
My method has been refined too:
1. rocket blower
2. sensor brush (optional)
3. lens pen (optional)
4. wet clean with Eclipse on pec pad.  I'm still using the bottle of Eclipse2 I bought in 2008.
5. check sensor with test shot.   It may or may not still have spots, but almost certainly has some stuff shoved into a corner.
6. if spots, repeat wet clean (15% of the time)
7. use sensorpen to carefully clean residue streaks (if any, from fluid) and dust that got pushed into a corner.
8. test shot.   Repeat some of above if necessary.
Craig
www.cjcphoto.net
Nikon 1 V1 Nikon D200 Nikon D300 Nikon D700 Nikon D800E +35 more
Mully410
Mully410 Forum Member • Posts: 98
I don't have any experience with the product you are using but I had a heck of time with Visible Dust swabs and solution.  I took Moose's advice and went with Copperhill.  It's a lot cheaper if I do have to make several passes on my D4 sensor.  After some practice, it usually only takes one or two pads to get to perfect.  http://www.moosepeterson.com/blog/2012/06/11/sensor-cleaning-with-copperhill/
 Mully410's gear list:Mully410's gear list
Nikon D4 Nikon D7000 Nikon AF-S Nikkor 500mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +3 more
Nikonfan99 Senior Member • Posts: 1,411
After many wet cleanings, I have the hang of it.
-Google Copper Hill Images.
-Order the 18mm quikstrip kit (not the 24mm)
-Use a good sensor loupe (like the visible dust) to pre-inspect the sensor.
-Use a good blower and spend a good amount of time blowing out the sensor.
-Using the blower, blow on the swab to get rid of any loose fibers.
-Use 2-3 drops of  eclipse on the swab.
-Make one pass at the top with one side of the swab. Flip it and make a pass on the bottom with the other side.
-Repeat with a new quikstrip till sensor meets your standards.
You get 100 quikstrips in the package for a great price and he sells quikstrips alone for cheap. Much cheaper compared to what 100 traditional swabs would cost you. Much better for the environment since you are not throwing out a plastic swab every time. Works great and customer service is beyond amazing. The key is to not use too much liquid. If you are getting streaks you are using too much. Dont trush it and it is better to use more swabs with a gentle pass instead of using less swabs and pressing too hard or forcing it. I think this system is The best I have tried. Nicholas at copper hill images is awesome.
 Nikonfan99's gear list:Nikonfan99's gear list
Canon EOS 6D Canon EF 40mm f/2.8 STM Canon EF 100mm f/2.8L Macro IS USM
AZBlue
AZBlue Contributing Member • Posts: 866
After you wet clean, if you still have some smudges then use a dry pad and gently rub the sensor until they disappear. Then blow off any dust and you should be good to go. Don't be afraid of scratching the sensor, you won't.
"I've been in more laps than a napkin" - Mae West
 AZBlue's gear list:AZBlue's gear list
Nikon D800 Nikon AF-Nikkor 80-200mm f/2.8D ED Nikon AF Nikkor 20mm f/2.8D Sigma 150mm F2.8 EX DG OS Macro HSM Nikon AF-S Nikkor 16-35mm F4G ED VR +1 more
Varjohaltia
Thanks, that was great advice!
You are welcome
