Decent, but save your money for a better printer...
Started May 17, 2013 | User reviews
Combat By Design
Combat By Design Regular Member • Posts: 279
We bought this printer through Amazon after I found it at Staples for $250.
The price point was the main reason for purchase, and my sister and I needed to print large format documents and images, and since we weren't buying it ourselves, and Epson 4880 was out of the question.
I've used it to print CD wallets, 7" EP jackets, full sized posters and packaging.
It's prints well on almost any sort of matte paper, and will accept Bristol board.
Unfortuantely we returned it three times before we recieves a fully functioning printer...
The Pros:
- **High print quality**
- Prints fairly quickly even at highest quality
- Large format
- Simple user interface
- Built in Scanner
- Simple paper load/feed
- Reliable wireless connection
- Easily disassembled to clear paper jams
The Cons:
- Recieved three non-functional printers before getting a good one
- Sucks paper back in to the print path after it's done printing
- Scanner bed is too small for such a large printer
- Size limits places to put printer
- HP Glossy Photo paper is highly reccomended as the HP ink doesn't react well with other glossy stock
My take on it: If your printer is dead or dying and you (almost immediately) need a large format AIO that spits out decent print, it's a good printer for the price assuming you get one that works... but if you're buying a printer just to upgrade, save your money and get a real nice printer, it'll benefit you in the long run, and save some headaches.
 Combat By Design's gear list:Combat By Design's gear list
Canon EOS Rebel T4i Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 50mm F2.8 EX DG Macro +8 more
HP Officejet 7500A - E910a
Multi-function printer • Inkjet •
Combat By Design's score
2.5
Average community score
2.5
Rkelac Regular Member • Posts: 466
Re: Decent, but save your money for a better printer...
The Pros:
- Large format
- Built in Scanner
The Cons:
I have this printer and mine has worked fine.  It should not be used to print photographs though.  It just doesn't have the color range with only three color cartridges.
I must admit, I treat it horribly because of the way I refill its cartridges. But, it still just keeps printing and printing.  Since the cartridges are opaque, I just let them run out of ink and then fill them up with R-JetTek ink.   Must have refilled about 10 times already and no burnt out heads.  I just run a cleaning to fill up the tubes again and it works fine. No need to reset the cartridges.  Just ignore the low ink warnings.
 Rkelac's gear list:Rkelac's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8
