M9 White Balance
Started May 15, 2013 | Questions
FotografiaFineArt New Member • Posts: 1
M9 White Balance
I have just taken possession of a very nice lightly used M9
So I am a newbie
The only complaint I have so far is that the (auto or incandescent) white balance for indoor images is TERRIBLE
Everything has a sickly yellow / green tinge
I know I can correct this in Lightroom (or other app)
But the fact that my Fuji X10 always gets it right in the same situations is disappointing
Am I missing something obvious?
Thanks for any advice!
sgr
Fujifilm X10 Leica M9
jammerbirdi_1 Contributing Member • Posts: 864
Re: M9 White Balance
Crickets?
http://50lux.com
@50luxdotcom on Twitter
meagre offerings
meagre offerings Senior Member • Posts: 4,854
Crickets?
http://50lux.com
is this a Leica joke??
pc
 meagre offerings's gear list:meagre offerings's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 50-230mm Fujifilm XF 56mm F1.2 R +7 more
Paul20
Paul20 Senior Member • Posts: 2,456
No,
The AWB on the M9 is terrible in low light indoor situations.
My technique is to always shoot RAW, [Jpegs on the M9 are also useless], import into Lightroom and using the Auto Balance function. That usually gets you somewhere near. If you really need accuracy then us a 18% grey card and set the balance in-situ.
AWB in evenly lit situations is normally ok.
The M9 has quirks but it is a great camera once you get to know it.
Enjoy it,
Paul
 Paul20's gear list:Paul20's gear list
Leica M9 Sony Alpha 7R II Leica Summicron-M 28mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH
MrLaki Senior Member • Posts: 1,094
So I am a newbie
sgr
check if you have the recent firmware, there were some corrections by Leica. Other than that you will have to use either manual WB or correct it in PP when it's that far off.
enjoy your M9 it's a great camera.
PaulChapman
PaulChapman Contributing Member • Posts: 970
When I went to the Leica users workshop the advice was to shoot at a constant temperature and correct afterwards in Lightroom. That way a group of photos can be given a consistent correction ... and you live in the knowledge that there is no problem with the camera. Something else that is useful is to set the camera up so that you shoot RAW plus a low res B&W JPEG and with highlight clippings ON. That means you can quickly check for exposure (and probably save battery life since you won't be spending so long looking at the back of the camera); later you throw the JPGs away of course. Good luck....and watch out for dust on the sensor..it sucks it all up!
 PaulChapman's gear list:PaulChapman's gear list
Panasonic Lumix DMC-LX3 Leica M9-P Leica M Typ 240 Panasonic Lumix DMC-GX7 Leica Summilux-M 21mm f/1.4 Asph +9 more
Mauro.B
Mauro.B Senior Member • Posts: 2,414
With the M9, WB presets are a better starting points than auto if you are going to fix wb in LR. Sunny preset is the best starting point in my experience.
Tungsten (2900 K°) and sodium (2000 K°) lights are more difficult to deal with prests, so it's best to set manual wb: even a white car is fine for that, or carry a credit card sized wb card (any 12% or 18% is fine).
The beauty of shooting under mixed lighting with the M9 is that the camera does not try to even out the different light sources (like all my Nikons do) but records all individual light colors according to the baseline color temperature selected (you may or may not like that; I like it most since gives a strong personality to night color photos).
Best regards,
M
 Mauro.B's gear list:Mauro.B's gear list
Ricoh GR Leica Q Leica M Typ 240 Sony Alpha 7R II
