55mm Macro Magnification Filters
Started May 14, 2013 | Discussions
TheVyper06
Junior MemberPosts: 48
May 14, 2013
Do the set of 4 filters that magnify your picture by +1, +2, +4 and +10 work? I'm considering buying them for a easy and cheap way to get some close-up shots
Edward Sargent
Veteran MemberPosts: 4,608Gear list
Re: 55mm Macro Magnification Filters
In reply to TheVyper06, May 15, 2013
I have 2 sets that I used on my 707 and film cameras many years ago. They seemed to work fine then but have not tried since.
Sarge
A99| A77| A700
|8mm & 14mm Bower|Sony 28-75 & 70-300 G|
|35-70, 50mm 1.7 & 200 G Minolta |
|Sigma 18-250 - 70-200 - 50-500 - 2X TC|
|Tamron 90 - 1.4X TC|
Albums at www.sony-snapper.com
 Edward Sargent's gear list:Edward Sargent's gear list
Sony Cyber-shot DSC-QX10 Sony SLT-A99 Sony a77 II Sony 70-200mm F2.8 G Sony 70-300mm F4.5-5.6 G SSM +33 more
zakkix
Regular MemberPosts: 377
http://kurtmunger.com/hoya_close_up_setid232.html
TheVyper06
In reply to zakkix, May 15, 2013
Thanks for the review, I believe I will be buying the $15 set I found on ebay then since it will be a great start for me
_sem_
Veteran MemberPosts: 4,682
In reply to TheVyper06, May 16, 2013
They work, but it is a better idea to buy one or two good ones, 2-element achromats like Canon 500D (+2), 250D (+4)... Which diopter depends on the lens you have. Longer tele lenses work better for this and with low diopters.
Edward Sargent
In reply to _sem_, May 16, 2013
A lot more expensive but that is why I'm not using the Macro Magnification Filters any more, I use Maurmi Macro 200 (+5) and sized to fit most my lens filter diameters (77mm)
Sarge
A99| A77| A700
TheVyper06
In reply to TheVyper06, Jun 2, 2013
Thanks again for all the  suggestions. I went ahead and got some cheap ones to just see what they do (paid less than $5 for a +1 +2 +4 and +10) and I liked them, I will probably upgrade to better quality ones in the future but these are fine for now on my limited budget.
dlkeller
Veteran MemberPosts: 6,922
They will be fun to play with while you save for a true macro lens, which is what I really recommend if you want good macro shots.
Dave
