Fuji X30 wants
Started May 13, 2013 | Discussions
Trollshavethebestcandy
Trollshavethebestcandy Regular Member • Posts: 465
Fuji X30 wants
Same everything and approx size but 1" Xtrans sensor.
I can't see them getting much more out of this size sensor that they have without diminishing returns.
0MitchAG Contributing Member • Posts: 527
Re: Fuji X30 wants
I agree, but for a camera that new, the LCD really needs updating - 460k is quite poor and one of the biggest annoyances on my previous camera was the low resolution LCD. Sometimes, I couldn't actually see if my photos were in focus or blurred when reviewing them, and thus lost a few good shots upon seeing them on my laptop. Especially for a product of its price, it's really an afterthought it seems. As if because it had an optical viewfinder, it wasn't too important, though I can agree with that to some degree, but not enough to justify the high end price.
Battery life is also quite poor, when compared against competitors and even the other Fuji X series cameras.
 0MitchAG's gear list:0MitchAG's gear list
Panasonic Lumix DMC-G5 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 20mm F1.7 II +6 more
Eddaweaver Senior Member • Posts: 2,231
Re: Fuji X30 wants
Ideally
  • 1" 3:2 sensor
  • Bigger battery
  • Higher resolution LCD
  • More usable coverage from the viewfinder
With a two year development cycle and the X100s to compete with that may be too much to hope for.
Pacific462
Pacific462 Regular Member • Posts: 122
Re: Fuji X30 wants
I'm lost for words
 Pacific462's gear list:Pacific462's gear list
Canon EOS 30D Canon EOS 70D Canon EF-S 60mm f/2.8 Macro USM Sigma 10-20mm F4-5.6 EX DC HSM Canon EF 70-300mm f/4-5.6 IS USM +3 more
Re: Fuji X30 wants
Pacific462 wrote:
I'm lost for words
Did I say something wrong?
tazmac
tazmac Regular Member • Posts: 360
Re: Fuji X30 wants
When they release the new entry level X camera which is rumored for this summer you will no want X30 anymore!
xchert Regular Member • Posts: 194
Re: Fuji X30 wants
As long as you realize they would have to either make the lens much much bigger, do away with the 4x zoom, or make the lens much slower than F/2.0.  It's just physics.  I'd rather keep the good lens, personally.
Pacific462
Re: Fuji X30 wants
Agreed.
Trollshavethebestcandy OP Regular Member • Posts: 465
Re: Fuji X30 wants
I would gladly lose some tele end.  28-85mm
Re: Fuji X30 wants
Yes, the screen is poor for checking focus.
Re: Fuji X30 wants
Eddaweaver wrote:
Ideally
  • 1" 3:2 sensor
  • Bigger battery
A square sensor!
Maybe a new monochrome sensor?
Pan Jurek Mr Jerry New Member • Posts: 15
Re: Fuji X30 wants
What I would like to see is the following:
1.) A bigger sensor.
2.) An articulating screen.
3.) A choice of styles; like with the X20.
4.) Two different versions:  X30A Normal with any updates like the double exposure update for  the X20 and a X30B A Black & White / Sepia version with all the updates that the X30B gets too.
5.) A longer zoom.  More wider and more tele. (20 - 140)
6.) A faster lens with a constant appature of F/1.4
Re: Fuji X30 wants
Which entry level X camera are they releasing?
lacro Forum Member • Posts: 66
Re: Fuji X30 wants
The rumored X30 Project or Fuji's answer to the Sony RX100 II challenge must fulfil,
  1. many requirements,
  2. >>>soon<<< and
  3. at a similar reasonable price range < US$ 700 (without mining her bigger sisters' segment, the 100S).
Wouldn't mind the "best >jacket pocket< SIZE camera" (RX100 II), is SMALLER than the best small size cam (X30), provided
  • a broader (24-120) and faster (1.8-2.4) Fixed Zoom LENS (FZL),
  • a bigger SENSOR 1" at least (a Sony RX100 II challenger),
  • the X ×0 compact line EXPERIENCE is kept,
  • a much better LCD resolution,
  • a wider shutter speed range,
  • an even better coverage viewfinder as well as
  • a similar overall DESIGN philisophy, while
  • keeping at least the device quality and IQ standards from her bigger sisters.
Rgds, Carlos
prime Senior Member • Posts: 1,669
Re: Fuji X30 wants
Sure. How much bigger do you want the camera to be to accommodate that bigger sensor?  If you swapped a larger sensor straight into the X20 body, the image circle of the existing lens either would not cover the entire surface of the sensor, or there would be serious vignetting.  So you necessarily would have to make the lens bigger, too.
The current X20 goes to 112 mm equivalent, which is 28.4 mm actual, with the 2/3" sensor.  Even with the same size sensor, 140 mm equivalent would require an actual focal length of 35.5 mm.  Increase the sensor size to, say 1", and the actual focal length for 140 mm equivalent goes to about 51.7 mm.
In the X20, the diameter of the aperture for f/2.8 at 28.4 mm actual focal length (112 mm equivalent) is 28.4 ÷ 2.8 = about 10 mm; for an actual focal length of 35.5 mm (140 mm equivalent), an f/2.8 aperture requires an actual aperture of about 12.7 mm -- that's still with a 2/3" sensor.  Now increase the sensor size to 1" and the actual aperture for f/2.8 at 140 mm equivalent becomes about 18.5 mm.  Now increase the maximum aperture to f/1.4, and the actual aperture must be about 37 mm at 140 mm equivalent.
So your specification has increased the actual aperture -- the hole in the lens through which the light passes -- almost fourfold, from 10 mm to 37 mm.  How are you going to fit an opening of that size inside a lens barrel the size of the X20's lens barrel?  O.k., let's increase the size of the lens barrel.  Oops, the lens barrel now overlaps the viewfinder, so we'll have to widen the camera body to move the viewfinder out further, probably have to make the camera a bit taller, too, for the same reason.
But it's not only the aperture that you have increased in size; you have had to increase the size of each of the lens elements inside the lens barrel, too, and those lens elements have mass.  If you still want auto focus, you will have to increase the size of the motor moving those lens elements around, which will drain the battery faster, so you will have to increase the size of the battery, too.
There are real physical reasons for large sensor cameras with long lens reach and bright apertures being big and heavy.
Re: Fuji X30 wants
Thank you for the reply. Yes a 1" sensor would be great. I just hope that they keep everything else from the X10/X20 design. I really like the fact that the X20 got an updated view finder that you can actually see information while looking through it. Pretty much like a DSLR would do. Also an articulating screen or at least a titling screen would be great. HHmm. F/1.8? Why not a constant aperture of F/1.4?
Pan Jurek / Mr. Jerry
  1. many requirements,from the X10/X20
  2. >>>soon<<< and
Rgds, Carlos
Re: Fuji X30 wants
Thanks for the reply.                I thought that electronics played a larger role in lens and aperture design.
I remember from my old SLR, no not DSLR but SLR, that I could see the aperture getting bigger and smaller when I played around with the lens once I got it off of the camera.  I cannot see the aperture change on my APS-C sized lenses since I thought that this was done electronically.
evoprox
evoprox Senior Member • Posts: 1,448
Re: Fuji X30 wants
Agreed on the bigger sensor, preferably one-inch. The body doesn't necessarily need to be significantly larger - see m43 snappers like the E-PL5 or APS-C cameras like the NEX series. However the lens for a one-inch sensor would be somewhat larger than that on the X10/X10 if it'd keep the current specs - 28-112mm (FF equiv)/f2-2.8. For me that lens is just perfect as it is, an extended zoom range or faster openings would quickly make it too large for a 'compact' camera. Just let me add that I have something of a gut feeling that the X30 will come with an EVF instead of the current OVF; a deciding feature that would set it even further apart from Sony's soap boxes and other high-end compacts. The modules get cheaper, smaller and better with each generation, we'll get 100% coverage instead of the current 85%, no more parallax errors and corners covered by an extended lens and/or hoods. An EVF doesn't need more space than the current OVF, just some more juice so it's about time to give that camera a decent, ergonomic grip with enough space to hold a bigger battery. Go Fuji !
 evoprox's gear list:evoprox's gear list
Fujifilm X10 Sony Alpha NEX-7 Fujifilm X-Pro1 Sony Alpha 7R
Re: Fuji X30 wants
The Sony RX100 manages to get to 100 mm equivalent (37.1 mm actual) at the long end with a 1" sensor; the RX100's lens has a 7.6 mm actual aperture -- which limits the RX100 to f/4.9 at the long end. Didn't you think that a maximum aperture of f/4.9 at 100 mm equivalent (on the Fujifilm XF1) is unacceptably slow?
If you were to make a lens that had an f/2.8 aperture at 112 mm equivalent on a camera with a 1" sensor, the actual aperture opening would have to be 14.7 mm, nearly double the actual aperture of the RX100's lens.  Look at the Sony RX100: that lens sticks out pretty far (acknowledged: that the aperture size requirements relate to barrel diameter rather than to how far the lens extends from the camera body) from the body even when retracted, and occupies a lot of space in toto.  Could you live with a lens nearly double the size of the RX100's lens on an X20 successor camera?
After considering the size of lens required for equivalent 112 mm f/2.8 on a camera with a 1" sensor, do you think it would not be "too large for a 'compact' camera"?
evoprox
Re: Fuji X30 wants
Yes. See below.
Well, agreed on the length as the critical dimension regarding 'compactness' (vs. diameter) and thus pretty much depends on how collapsible such a lens could be realised - see your XF1, the X10/20 or any of the current 10+X super stretch travel zoom snappers (1/2.3" sensors). I'd rather see some of the long end/versatility sacrificed, e.g. 3x (28-84mm) instead of 4x (28-112mm) if they only keep the f2-2.8
84 vs. 112mm wouldn't be too much of a loss in my book (all my current FF lenses fall in that range). For me the only reason to upgrade from my trusty X10 would be a one-inch sensor together with a reasonably fast and flexible lens, even if it would be somewhat larger. I have no need for yet another half-assed 2/3" follow-up.
