Remote Shutter Release D800
Started May 13, 2013 | Discussions
romfordbluenose Senior Member • Posts: 2,083
Re: Remote Shutter Release D800
net_walker wrote:
Robin Casady wrote:
net_walker wrote:
Apologies but when I do a search for this it comes up with crap loads of chatter (unless you can search a phrase that I do not know about)
I am after suggestions for remote cable release, wireless or not is good.
Cheers...
I've used a variety of remotes, wired and wireless. My favorite, and the one I use 90% of the time is the RFN-4s. The camera part is small and plugs directly into the 10-pin connector without a cable. Most wireless remotes put a bar of soap on the flash shoe. This doesn't.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
Thanks Robyn.
Link did not work but I binged and found on Amazon.
I wonder if there is a way to use remotes as well as the GPS-1 at the same time...
Cheers...
The Phottix GEO ONE has a connecting remote release
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
Robin Casady Forum Pro • Posts: 12,898
Re: GPS & Remote Shutter Release
BeachnCruz wrote:
Robin Casady wrote:
net_walker wrote:
Robin Casady wrote:
net_walker wrote:
Thanks Robyn.
I believe the GPS-1 has a 10-pin outlet so you can connect a remote. You should check first.
If you get an Aokatec AK-G1syou can use their cord remote, or a remote compatible with Canon Rebel Xsl, 450d, 50e, 500, 300, 300x, 300v, 400d, etc. The connector looks like a stereo mini jack so don't plug it into your iPhone.
Yes Robin, the GPS-1 has a 10 pin connector and I have one already. It looks like the RFN also uses a 10 pin connector hence my dilemma
Thanks all for your other responses so far.
Cheers...
What is your dilemma? Plug the RFN-4s into the GPS-1 and you should be set. The plug on the GPS-1 was put there so you could use a remote.
Hi Robin.... Memory foggy today? I think you recommended the Solmeta 10-pin Y-splitter a few months ago.
https://www.ppsna.com/product_info.php/products_id/738
Jim
The Nikon GP-1 has a 10-pin pass-through outlet. You can plug a remote into that outlet. So, a Y-splitter is not required.
Other GPS units that connect to the 10-pin connector on the camera do not have a pass-through outlet so you would need a splitter to use a remote.
Robin Casady
— Bertrand Russell
net_walker OP Contributing Member • Posts: 812
Robin Casady wrote:
BeachnCruz wrote:
Robin Casady wrote:
net_walker wrote:
Robin Casady wrote:
net_walker wrote:
Thanks Robyn.
Cheers...
Jim
Robin Casady
— Bertrand Russell
So is the bottom line: I can use the GPS-1 and RFN-4 together or I need another type?
Cheers...
 net_walker's gear list:net_walker's gear list
Nikon D800 Nikon D4S Nikon D750 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED +7 more
axcentphoto
axcentphoto Senior Member • Posts: 1,392
Do you folks leave your RFN-4s on your camera continuously?
 axcentphoto's gear list:axcentphoto's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +2 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,570
If I'm going out shooting on a tripod, I put it on.  I take off again when I get home.
Even though it's small, it's still big enough that something might catch it and break it, or break the 10-pin connector.
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
RFN-4s, not RFN-4
So is the bottom line: I can use the GPS-1 and RFN-4 together...
No, the FRN-4 an entirely different animal. It fits the D600, D7100, etc. which do not have a 10-pin connector.
You need the RFN-4s.
Robin Casady
— Bertrand Russell
Yes. I only remove it when I need the 10-pin connector for something else.
Robin Casady
— Bertrand Russell
Re: RFN-4s, not RFN-4
Robin Casady
— Bertrand Russell
OK, sorry Robyn but yes I meant can I use the GPS-1 & the RFN-4s at the same time?
Cheers...
PHXAZCRAIG
Sigh. Just ordered another one...
Don't know what happened exactly, but today I put the remote on the camera before I walked out into the desert.  A little over a mile later I stopped to get some shots on the tripod with the remote release, and it was gone.   Must have rubbed against my hip when I the camera slung over my left shoulder and worked it's way loose.   Retraced my steps as best I could, but couldn't find the receiver.
From now on, I'll put it on in the field and be more careful.
At least I'll have two transmitters in a week or so.
Craig
www.cjcphoto.net
Cheers...
Yes, but be careful with those letters, nut_walker. One letter can make a big difference.
Robin Casady
— Bertrand Russell
LOLS, but you could be true...
No, I'm just a figment of your imagination—a caterpillar on a mushroom.
Robin Casady
— Bertrand Russell
BeachnCruz Senior Member • Posts: 2,034
Re: SMDV RFN-4s Remote Shutter Release User Guide
Here is a link for the SMDV RFN-4s PDF User Guide/Manual...
SMDV RFN-4s User Manual
Review of RFN-4s
http://www.earthboundlight.com/phototips/rfn-4s-new-favorite-wireless-remote.html
Jim
Review of RFN-4s
Jim
Thanks Jim...
Still not seeing how to have this and the GPA-1 connected at the same time tho.
Thanks for the PDF link. I'd misplaced my tiny paper version didn't remember what the bulb trick (impacts bracketing sequences) was.
Thanks Jim...
You open a cover on the GP-1a to reveal a 10-pin outlet. You plug the RFN-4s into that. See this page and select Product Information. Look at #4.
Robin Casady
— Bertrand Russell
Thanks Jim...
Robin Casady
— Bertrand Russell
Hey Robyn,
Mr Thick here again
OK, get me try and get this one last time.
I hook the RFN-4s to the round 10 pin terminal on the front of the D800.
Now, how do I connect the RFN-4s to the GPS-1 to the remote inlet/outlet that you describe above and once before? I see no cable pins in the RFN-4s manual as linked by Jim.
Cheers again
Paul...
PHXAZCRAIG
Read the first sentence.   You plug the RFN-4s into the GPS-1, not the other way around.
Craig
www.cjcphoto.net
BassFisher
BassFisher Regular Member • Posts: 341
Re: Solmeta 10-pin Y splitter with coiled cable now available
+1 on the SMDV RFN-4S remote.
I have the MC-36  but bought 2 of SMDV RFN-4S remote  one for D800E and one for my D700 when my daughter an I go shooting together.
This is one nice piece of gear. Cheap and small. Easy to use and put the MC-36 back in the cupboard.
BillD
Sydney, Australia
Time is the only thing I don't have enough of.
 BassFisher's gear list:BassFisher's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +2 more
Craig
www.cjcphoto.net
Ok, I think I am finally seeing the light.
So, GPS-1 connected to the front 10 pin round plug.
Then I hook the RFS-4s to the side of the GPS-1 using a cable what converts 10 pin round to 10 pin rectangle.
So I need to acquire another cable then?
Paul...
Re: Fitting the old round peg into a rectangular hole trick....
Craig
www.cjcphoto.net
Paul...
Ever watch the old Monty Hall Game Show? What's behind Door #4? Fitting the old round peg into a rectangular hole trick.... Ever feel like someone has gifted you a 1000 piece puzzle and neglected to tell you that 1 piece of the puzzle is missing? The Fog Bank is still lingering Robin.....
Jim
