Flash photography and using an ND filter
Started May 12, 2013 | Discussions
Richard Cooper
Senior MemberPosts: 1,540
May 12, 2013
There are many articles on using a flash for both indoor and outdoor photography with an ND filter.
But what I find missing are the beginning steps.
For example, shooting in manual set the desired aperture and see what the camera meters for shutter speed using the lowest ISO setting.
Determine at what shutter speed you want and then select the ND filter.
OR
Mount the ND filter, set your desired aperture, ISO and then lower your shutter speed. Take a test shot and adjust your shutter accordingly.
Or is their a specific tutorial on what comes first? Meter reading without ND filter or just mount ND filter and take some test shots and then adjust your shutter?
Richard
Hugowolf
Forum ProPosts: 12,347
Re: Flash photography and using an ND filter
In reply to Richard Cooper, May 12, 2013
Why do you want to use an ND filter? What effect are you trying to achieve?
Brian A
Sailor Blue
Veteran MemberPosts: 8,676Gear list
In reply to Richard Cooper, May 13, 2013
The only reasons I can see for using a ND filter with flash are:
Outdoors and sometimes indoors the ND filter is used to reduce the ambient light exposure.  If you do this you would want to figure out what lighting ratio you need at the desired aperture and then figure out what ND filter you would need to achieve the appropriate ambient light level and how much flash power is needed to achieve the ratio.
Indoors the power of the studio strobe can't be reduced enough to allow the use of wide apertures for a narrow depth-of-field.  Place extra layers of diffusion material on the front of the diffuser to reduce the light output instead of adding a ND filter.  Of course this presumes you are using softboxes or umbrellas with black backings so stray light isn't a big problem.
Note that focusing with strong ND filters can be a problem.  In this case you need to lock the focus before adding the ND filter.  Since adding a filter can slightly shift the focus you should use a wide enough depth-of-field to prevent the subject from going out of focus.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
dad_of_four
Veteran MemberPosts: 7,699Gear list
In reply to Sailor Blue, May 14, 2013
Shooting outdoors in bright conditions, and being constrained by the x-Synch speed of your camera and your desired aperture.  Be careful of ghosting in these conditions
 dad_of_four's gear list:dad_of_four's gear list
Nikon D70 Nikon D2Xs Nikon D700 Nikon D5000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +10 more
Hugowolf
In reply to dad_of_four, May 14, 2013
Well, there are a couple or three reasons why one might want to use an ND filter for flash, but without a reply from the OP, who knows?
Brian A
Fave Photog
Senior MemberPosts: 1,241
That's what Sailor Blue said:
"Outdoors...the ND filter is used to reduce the ambient light exposure."
The Five 'Ps' of Photography:
*Proper Planning Prevents Poor Performance!*
drh681
Forum ProPosts: 16,098Gear list
In reply to Fave Photog, May 14, 2013
Uh... a neutral density filter would reduce the over all exposure not just the ambient.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
You got a camera, now go out and get a life; or at least a picture of one!
 drh681's gear list:drh681's gear list
Nokia Lumia Icon
Hugowolf
In reply to drh681, May 14, 2013
Oh poor thing, but there is lttle one can do about the ambient light, whereas one can often turn up the flash - that is the point.
Brian A
drh681
In reply to Hugowolf, May 14, 2013
don't patronize me, discuss why that would even be desirable.
The only reason I could see is to use a larger aperture than the lowest flash output would permit.
Even for that, you could back off the flash distance to the subject.
Photons by the bag.
Nokia Lumia Icon
michaeladawson
Veteran MemberPosts: 9,005Gear list
I'm not sure what you mean by that.  Basically though, if you're shooting outdoors in sun and you want to use flash at wide aperture you are going to have problems.  Due to sync speed you are going to be limited to around f/9 or f/10 at ISO 100.  If you want to shoot at f/4 or f/5.6 you are going to have to use an ND filter.
My apologies if that is what you were trying to say.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800 Nikon D800E +21 more
Sailor Blue
Photons by the bag.
If you use flash from a hot-shoe flash or a studio strobe then you are making two exposures.  One exposure is an ambient light exposure.  One exposure is a flash exposure, or if outdoors it is a combination of ambient and flash.
In a studio the ambient light exposure is usually much lower than the flash exposure so it can be neglected.  The problem in the studio is usually too much strobe power even at the lowest settings, and this is when you start adding extra layers of diffuser material to the light sources to reduce their intensity.
Using flash restricts your shutter speed to a maximum of the sync speed.  If you want to use a wide aperture to give you a small depth-of-field then you can easily find your outdoor ambient lit background being overexposed.  This is when you add the ND filter to cut down the ambient light lit background exposure and crank up the power of the flash to offset the exposure reduction of the ND filter.
If you use window light as one light source indoors and add flash as the second light source then you are again looking for ways to adjust the ambient and flash exposures.  If you are unable to keep the ambient light background from being overexposed at wide apertures, chosen for a small depth-of-field, then you need to use the ND filter to reduce the ambient background exposure and up the flash power appropriately.
I hope this clears up any confusion.
Richard Cooper
Sailor Blue, thank you for your response.
This is what information I was looking for.
Richard OP
