60mm 2.8 macro - Experiences and pictures
Started May 10, 2013 | Discussions
call me Skippy
Forum MemberPosts: 70Gear list
May 10, 2013
Hi there!
Bought the 60mm macro tow weeks ago. Very fine lens - tricky to handle though. Hairline thin depth of field. The split-second between acquiring focus and actual shutter release is enough to move the focus considerably. With 60mm shaking is also an issue. Count in that macro-work often means moving the camera into awckward angles, so holding it still is even more difficult. Count in other conditions - like wind moving leaves - and it becomes quite challenging to get clear pictures... to move quickly in the field and hold the camera steady I am thinking about buying a monopod. Suggestions? Does it work?
Here the - I fear overprocessed - pictures.Noise from high iso cleary visible - but thats the fault of my processing I fear.... However. I am quite pleased with the results. Bought an LED-light to have more room to avoid shaking and keeping the aperture closed...
 call me Skippy's gear list:call me Skippy's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
windriver
Regular MemberPosts: 163Gear list
Re: 60mm 2.8 macro - Experiences and pictures
In reply to call me Skippy, May 10, 2013
Those are nice, sharp shots for sure.
But to consistently get macr (or even closeup) shots I like I have to use a tripod - because of the factors you mentioned.  I prefer natural lighting for all my shots, though an accessory light sure does enable fast shutter speeds.
DLBlack
Forum ProPosts: 11,720Gear list
Nice set of macro photos for just doing it for two weeks.  Macro photography is a lot of work, but the mft with touch screen really does help.  A tripod helps.  Maybe some off camera lighting if not over done can help.  Living bugs really makes it tough since they do move a little bit and it doesn't take much movement to ruin a macro photo.
Keep at it and post more photos.
Dave
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II +29 more
call me Skippy
In reply to windriver, May 10, 2013
Thanks. Thats the reason I want to buy a monopod: I feel a tripod would slow me down to much. Do you have experiences with monopod? About the light: Yea. Natural light would be cool, but I feel most stuff you can edit afterwards. And: with insects its not only about shaking hand. The damm guys are fast!
robonrome
Senior MemberPosts: 1,837Gear list
In reply to call me Skippy, May 11, 2013
i feel tripods and monopods are next to useless for insect pics. the answer is external flash with diffuser.
 robonrome's gear list:robonrome's gear list
Sony Cyber-shot DSC-RX100 III Olympus E-M1 Olympus E-M5 II Sony Alpha 7R II Canon EF 135mm f/2.0L USM +13 more
vincent filomena
Veteran MemberPosts: 5,106Gear list
Excellent: I have the lens, but will probably rarely use the Macro;
I just use it for the sharpness !
Thanks, Vjim
 vincent filomena's gear list:vincent filomena's gear list
Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-G5 Olympus PEN E-PL5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +1 more
windriver
I have no experience with a monopod.  I can see where macro w/tripod for moving creatures would be a challenge.  I have shot static subjects only with macro or extreme close-up, so no help there either.
I think even macros of insects could be more interesting if the light were just so - maybe backlit, sidelit - anything but flat head-on.  Maybe bouncing light off a white board from the side or through a diffuser would help.  Just some thoughts.
eques
Senior MemberPosts: 2,025Gear list
60mm 2.8 macro - Tripod vs Monopod
In reply to windriver, May 11, 2013
I tried a monopod, because it is much faster to adjust to various positions. Results were a little disappointing. Having the extra weight of the monopod certainly reduces shakeing. And it helps to eliminate shake in 1 dimension: up/down if it is placed more or less vertically.
My problem then were the other 2 dimensions: left/right and even more back/forth, which makes critical focus difficult.
But I use MF macro lenses. Perhaps it is easier with AF?
So right now I either use a tripod (for static things) or try hand-held-mode.
Peter.
 eques's gear list:eques's gear list
Ricoh GR Panasonic Lumix DMC-GX7 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
Brian Wadie
Veteran MemberPosts: 6,623Gear list
These are a good start but as you say, its tricky to get sharp shots hand-holding with any macro lens.
I shoot a lot of bugs, bees and butterflies and for > 90% work hand-held as the types of shot I am after aren't feasible from a tripod. If its a long session I will sometimes use a mono-pod but that is as much to reduce the strain on my arthrititc shoulders as it is to stabilise the camera
I find that the IBIS system on the EM-5 is an enormous help as is the use of flash if the natural  lighting is inadequate
A technique I have found works for me is not to try to hold the camera stable but to use SAF to get intial focus lock then holding the shutter button half depressed to rock my body back and forth to get final focus lock on the eye of the subject (using the EVF not the LCD - I can't get that to work for me as I can't hold the camera stable enough).
Pressing the shutter is done whilst still moving, just as the eye detail comes into focus.
It took a while to get this method to work consistently but now its instinctive and I find I can't get the shots with a static hand-held camera (I shake too much)
A few examples, all with the EM-5 but some with the 60mm, others with a panny 45 macro or the kit lens in macro mode
(I should point out that many, if not all are crops, even when shot at 1:1 with minimum focal distance I often can't see the detail I'm after but the image files carry so much information they respond well to cropping)
 Brian Wadie's gear list:Brian Wadie's gear list
Panasonic Lumix DMC-FZ1000 Olympus E-M1 Olympus E-M5 II Canon EF 70-300mm f/4-5.6L IS USM Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +3 more
Brian Wadie
last one was with canon
In reply to Brian Wadie, May 11, 2013
I've just spotted that the last shot was with my old canon system using the canon 100 f2.8 LIS, I reckon the M4/3rds system holds up quite well on comparison
mazzuccato
Senior MemberPosts: 2,249Gear list
Very nice shots!
Stefano
 mazzuccato's gear list:mazzuccato's gear list
Sony RX100 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +3 more
Aleo Veuliah
Forum ProPosts: 14,596Gear list
Very good pictures, liked much. Well done.
Simplicity is the ultimate sophistication.
Learn the rules like a pro, so you can break them like an artist.
Pure logic is the ruin of the spirit.
If plan A doesn't work, the alphabet has 25 more letters, keep calm.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH4 +4 more
