Trigger for using camera phone with external flash?
Started May 9, 2013 | Discussions
Zanorway New Member • Posts: 23
Is it possible to use an android phone with external flash, such as Elinchrom Ranger RX, or just a regular off-camera external flash - with some sort of trigger device / receiver?
For example an elinchrom trigger with bluetooth reception, combined with a camera app that sends the signal when taking a picture?
Or a bluetooth controlled trigger with PC sync out? (together with a camera app as mentioned).
Or with wiring from the phone's audio jack output...
Manual would be ok, as long as the camera app would allow manual control..
ScratchDisk Veteran Member • Posts: 3,188
Re: Trigger for using camera phone with external flash?
Hi, Not sure if Bluetooth can be fast enough ..
If all else fails, it's always possible to use off-cam flash like this:
The 580ExII is been driven by a simple optical slave device, which in turn is responding to the P&S's built-in flash (behind the IR-pass filter). But you could put an RF trigger link, Tx & Rx, between the optical slave and any driven off-cam lights, Studio or Speedlites. (Hopefully 'pre-flashes' are not an issue with phone flash - if they were, you'd need some 'pre-flash ignore' tech.)Cheers, Donald
Clueless Wanderer
Clueless Wanderer Senior Member • Posts: 1,142
Put your flash on a sync cord and attach the sync cord to something like this and just hold it in the path of your phone's flash
http://www.ebay.co.uk/itm/Slave-Trigger-Unit-for-Flashguns-and-Studio-Flash-Sync-Socket-and-Tripod-Mount-/120860249625?pt=UK_Photography_Slaves_Trigger_Systems&hash=item1c23d50e19
 Clueless Wanderer's gear list:Clueless Wanderer's gear list
Nikon D200 Nikon D700 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +21 more
dad_of_four Veteran Member • Posts: 7,743
It may also depend on your cell phone, and how it uses its flash.  On my phone, for example, the LED "flash" is more like a continuous light.  When I press the shutter, the LED illuminates to help focus, briefly extinguishes,  then illuminates again to take the image.
You would have to program your external trigger to ignore the first "flash", and then trigger on the second.  And, I am not sure exactly how long of a delay there is between the second flash, and the shutter firing.  Your external flash may still trigger too early.
 dad_of_four's gear list:dad_of_four's gear list
Nikon D70 Nikon D2Xs Nikon D700 Nikon D5000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +10 more
