Nikon SB-600 speedlight/D7100 multiple flash firing
Started May 9, 2013 | Discussions
toucan Regular Member • Posts: 181
Hope someone can help with the following.... I purchased a used Nikon SB-600 speedlight which I use with  my Nikon D71000. Reading the instructions (Page 38 of the) it indicated that the Speedlight would fire mulptiple flashes in succession if used external to the camera.
I have tried to make this happen attaching the speedlight both via extender cord and using Pocket Wizard MiniTT1 and Flex TT5 remote system. Neither way will give me multiple flash firing.
The SB-600 works otherwise fine. Am I missing something in the camera settings?
toucan
Nikon D7100
JeffryZ Senior Member • Posts: 2,301
Re: Nikon SB-600 speedlight/D7100 multiple flash firing
I could not find anywhere in the manual where it indicated that would work with an SB600.  I think it only works with the built in flash.  I tried unsuccessfully to do that as well. On page 247 it seems to say it might work with an SB400?
"When the optional SB-400 flash unit is attached and turned on, Custom Setting e3 changes to "optional flash", allowing the flash control mode for the SB-400 to be selected from TTL and Manual (Repeating Flash and Commander mode options are not available).
But since the SB400 cannot be used as a commander unit, it seems that Repeating Flash will also not work with that unit since the manual lists those options as "not available".
When I install my SB600 to my D7100, e3 does not change to "Optional Flash" so this option does not seem to be available with this flash unit.
 JeffryZ's gear list:JeffryZ's gear list
Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Tokina AT-X Pro 11-16mm f/2.8 DX +1 more
On page 38 of the manual (the page you indicate) I see no references to either an external flash or repeating flash.
I guess you were refering to the flash manual- not the camera manual.  Continuous flash is not the same as the "repeating flash"  I thought the question refered to (in repeating flash, the flash strobes during the exposure).  Continuous flash firing is (to my understanding) doing a burst of exposures with the flash firing for each exposure- not multiple flashes for each exposure.  Sorry for getting myself confused.
blue_cheese
blue_cheese Senior Member • Posts: 1,722
toucan
are you in continuous release mode? (is your camera taking pictures in succession?
that page of the manual states the how many shots it fires before it overheats... not modeling light mode or the frame rate... nothing fancy...
toucan OP Regular Member • Posts: 181
Sorry about the confusion. I do mean repeating flash as in holding down the shutter release to produce more than one flash infused shot.
The shutter mode is on continuous.
Sounds like I might have to step up to a higher model as I am using the flash for bird photography and repeating flash is essential to capture the right shot.
toucan
blue_cheese
Depending on distance and lighting, for birds I assume that your problem is really the distance so flash is likely doing a near full discharge so the cycle time slows down considerably.
The batteries you use are a big element in the cycle time, consider Ni-MH batteries, even with some of the best are likely looking at 2.5s for a full flash cycle charge, so that comes down to a flash firing at 0.4fps which is abysmal considering the camera fps rate (page 88 of SB600 manual)
If you are not doing full discharge on the flash, then it should be able to keep up for at least a short burst.
toucan
I am still not completely clear on the effect you are looking for.  "More than one flash infused shot" sounds to me like a series of shots with the flash going off for each one?  That does work with the SB600 and the D7100. I tried it myself.   Have the camera set to "continuous" shooting and holding down the shutter button will give a burst of shots and the flash should work with each of them for a limited number of pictures (the camera buffer will probably hit its limit before the flash starts to get too warm and shuts itself off to cool).
If the desired effect is to have multiple flashes for a single image, according to the manual the D7100 can only do that with the built in flash.  If this is the case, maybe it would be cheaper to check into some sort of strobe system than a new camera?
fireplace33
fireplace33 Senior Member • Posts: 1,931
I experimented with exactly that in this thread
http://www.dpreview.com/forums/thread/2971630
I used the D90 but I'm pretty sure the D7100 has the same feature.
You use the on camera pop up flash in repeat mode to control an external flash in slave mode.
I used the SB700 remotely in SU-4 "slave mode" for my shots. The SB600 is very similar but does not have that  SU-4 mode!
There is however a workaround,...
you can buy a cheap slave adapter that attaches to the remote SB600 flash hot shoe and gives the SB600 a slave mode. The adapter has a light sensor and when it sees the multiple repeat flashes from the on-camera , it will fire the external flash each time. Of course you have to turn to power of the flash down so it can handle a set of say 5 flashes in a short time. And with the lower power you'll need to place the remote flash closer to the birds.
By the way if the light from the on-camera flash would disturb your shot in any way then you can mask that with another adapter that plugs into the hot shoe (SG-3IR)
Have fun!
 fireplace33's gear list:fireplace33's gear list
Nikon D7100 Nikon AF-S Nikkor 70-200mm f/4G ED VR Tokina 11-20mm F2.8 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR Canon PowerShot G15 +13 more
fireplace33
here is one example of such a slave adapter,...
http://www.amazon.com/Seagull-SYK-4-Optical-Trigger-Socket/dp/B0028DM1YA/ref=sr_1_3?ie=UTF8&qid=1368221411&sr=8-3&keywords=Seagull+flash+slave+trigger
there are many others avaialble.
pavi1 Veteran Member • Posts: 6,282
toucan
just to test, set the flash power to 1/8 power and take a series of shots of the flash. It should fire everytime until it runs out of juice And you will see this in the series of pics.  If you shoot one shot a full power, you will not get another flash until it recharges the capicator.
Everything happens for a reason. #1 reason: poor planning
WSSA #44
fireplace33
Would be interested to hear if this worked for you with those bird photos,...
Pipeandwire New Member • Posts: 4
i understand the question being asked, and i can assure you without a doubt IT CAN BE DONE. i called in to tech support to help me set it up about a year ago and got it working perfectly...
CONTINUOUS shooting say 5 shots with the flash firing with each shot. YES it can be done but now i forgot how and i need it again this afternoon... AAARRRRGGGG! did anyone figure it out??
i can set my flash to commander mode in the 7100, cam on ch or conti, low. channel 1 group a all that if fine as it will shoot once. cant get it to shoot multiple times and its driving me bananas. i have the original emails from the tech helping me but they appear only to be incident numbers.
anyone figure it out ?? thanks
