Is it better for me to shoot JPEG as opposed to RAW if I dont do any PP?
Started May 8, 2013 | Discussions
WilbaW
WilbaW Forum Pro • Posts: 10,728
Re: Is it better for me to shoot JPEG as opposed to RAW if I dont do any PP?
mfait wrote:
WilbaW wrote:
You can extract the embedded JPEGs from a batch of raw files (the same JPEGs you would have got if you shot raw+JPEG),
Not true on my XSi and probably not true on most dSLR's.
RAW+JPG give me a 12 MP JPG file.  However the JPG image embedded in the RAW file is about 3 MP.
Right! I was thinking of the 60D.
So... you can extract a low-res JPEG from the raw file, which is plenty good enough for evaluation and sharing.
Check out the unofficial Rebel Talk FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
WilbaW
No I didn't
With DPP you should be able to generate the same JPEG that you would have generated in camera from the raw file, assuming you match the settings in your camera.  You also have the opportunity to develop something you like better than what you would have with the camera.
That's true but it's not what I meant.
RAW+JPEG saves you from having to do that RAW conversion, but that's about it.
That's true too.
WilbaW
Re: What I don't understand is the reluctance to use PP software to alter an image.
DSHAPK wrote:
Because there are times I don't need raw. I bought the best camera to have a choice. The t4i with its digic 5 processor produces great jpgs. Why should I post process when the camera gets it right 99% of the time?
Do you have home insurance? Why not save your money when your house is not going to burn down on 99.999% of days?
It all depends on your definition of "right". I bet yours is different to mine, and that's okay, but no-one can insist that their "right" is good enough or necessary for every other photographer.
I'm an amateur taking amateur photos, not a pro shooting a wedding. Why download hundreds of 18 meg files, if not needed?
Yeah, use the format that meets your needs.
I think you've answered a different question to the one Oilman asked.
scrup Regular Member • Posts: 137
Re: Personal Preference Really
It depends on what I shoot. If they are important images that are keepers then I will shoot in RAW. If they are random images for other people they will be in JPG. Most of my friends don't want to deal with software and conversion.
RAW is like the negative and JPG is like the print.
RAW images are just more forgiving when it comes to PP.
It is a little bit like filter and no filter debate.
 scrup's gear list:scrup's gear list
Canon EOS M Canon EOS M3 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +1 more
R2D2 Forum Pro • Posts: 16,416
+1
I've gotta agree with you here WilbaW.... (aaaargh!)
I've been doing this a long long time, and I've never met an image I couldn't tweak a bit to "improve" (ie adjust to better suit my vision).
R2
Sony RX100 II Canon PowerShot G3 X Canon EOS 70D
jayrandomer
jayrandomer Contributing Member • Posts: 731
The embedded JPEG isn't necessarily the JPEG you'd get from the camera
Olga Johnson wrote:
jayrandomer wrote:
mfait wrote:
WilbaW wrote:
Smiller4128 wrote:
am I still better off shooting RAW?
Unless you're perfectly happy with what you get out of the camera and that's all you'll ever need, you're always better off shooting raw. You can extract the embedded JPEGs from a batch of raw files (the same JPEGs you would have got if you shot raw+JPEG),
He does not mean "develop".  There is always a JPG embedded in a raw file.
Olga
but it's possible to develop that exact JPEG from the RAW.  That's what I thought he meant.  You are right in that not being what he meant, but what he meant was wrong, at least for some cameras.
demarren 123 Veteran Member • Posts: 3,616
paparios wrote:
paparios wrote:
Smiller4128 wrote:
I don't really believe in using any PP software to alter an image too much. If I do, it's to lighten/darken certain parts of an image or to enhance the color a tad if it's been brought down by haze and such. I'm wondering though if maybe I'm better off using JPEG as opposed to RAW since the camera will automatically makes adjustments to the image? Or am I still better off shooting RAW?
Well, sometimes it helps,.....a lot. In the example below, one friend used my camera to take a picture, without adjusting the exposure (the camera was in manual). Using RAW and Lightroom 4.2, I was able to adjust the exposure (by 4.3 stops) and get  at least a viewable result.
Miguel
Another example, this time with High ISO. The original without PP, using DPP. The second processed through Lightroom.
Miguel
Yes but you can do this with JPG to.lightroom have A white balance picker.
It is just A white balance problem you corrected.
My English is poor.Try to Understand
Nikon D70s,Nikon D90,Nikon D3200 Samsung NX100 Fuji X10
Sony Nex3 Sony nex5n Sony hx100V
_______________________________________________
http://www.flickr.com/photos/73737307@N00/sets/
Claus M
______
 demarren 123's gear list:demarren 123's gear list
Olympus E-10 Sony Cyber-shot DSC-HX100V Fujifilm X10 Nikon Coolpix P7700 Panasonic Lumix DMC-LX100 +10 more
WilbaW
R2D2 wrote:
+1
Go on, you know you want to.
I've been doing this a long long time, and I've never met an image I couldn't tweak a bit to "improve" (ie adjust to better suit my vision.
Right, vision - I don't know what that is until I manipulate the image in the raw converter.
WilbaW
Re: The embedded JPEG isn't necessarily the JPEG you'd get from the camera
jayrandomer wrote:
... what he meant was wrong, at least for some cameras.
That's a bit negative. Can we agree that it's not true for all cameras?
jayrandomer
I'll go further
I'd say it's effectively true for all cameras, but not exactly true for some
Klaus dk
Klaus dk Veteran Member • Posts: 3,349
demarren 123 wrote:
paparios wrote:
Miguel
Miguel
Claus M
______
Yes, but sometimes the jpg is so much off, that too much information is lost. With RAW you have much more headroom.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Klaus dk
Sometimes you don't know it's a keeper until you have processed it. Shoot in RAW+JPEG. Only give JPEGs to your friends.
So why not? Memory cards are not that expensive, really?
I don't agree. If the filter has introduced flare or blur, it might be impossible to get rid of and if the JPEGs are beyond repair, you can't recreate the RAW files. If you are satisfied with the JPEGs, you can throw away the RAW files.
007peter
007peter Forum Pro • Posts: 10,359
Custom White Balance - Why Not "LEARN" to shoot right the 1st time?
demarren 123 wrote:
Miguel
Call me traditional, but I prefer the FILM METHOD - get it right the the 1st time!
You don't need RAW, you don't need photoshop.  Learn to use Custom White Balance, get it right the 1st time.  In the old days, people are more careful with their exposure/WB balance/ and composition.  Today, all we have is lazy shooter who fixed everything Photoshop.  Theser are not photographer, just software manipulator.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 25mm F1.7 ASPH
Klaus dk
Re: Custom White Balance - Why Not "LEARN" to shoot right the 1st time?
You have strong opinions. They need both a spellcheck and a raincheck.
DSHAPK Contributing Member • Posts: 782
Actually I agree with this thought. Id rather have wb correct going in than to correct a multitude of pictures.
 DSHAPK's gear list:DSHAPK's gear list
Canon EOS 550D Canon EOS Rebel T4i Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 55-200mm f/4.5-5.6 II USM +3 more
it is personal preference. After shooting with the rebel line for over two years now, Im almost at the point I can set the camera to get my intended picture. I have a very good sense when to use raw for later processing and when it is unnecessary. I haven't lost a "keeper" shot in a while, but that does go with experience.
Klaus dk
Because sh*t happens!
I'm no different. I prefer to have everything correct in camera and I have no desire to waste time using whatever software to make up for bad exposure or WB. No way.
Most of my pictures are exposed in manual mode because I use studio strobes for them.
I have no desire to burn down the house, get robbed or be killed. But I have insurance nonetheless, and I urge my friends to have insurance too. Because sh*t happens.
paparios Regular Member • Posts: 482
demarren 123 wrote:
paparios wrote:
Miguel
Miguel
Claus M
______
Well, actually no. If you check the exif of the picture, it was taken with the XTi at ISO3200, which means a lot of noise to control besides the WB.
While it is true that a JPG image can also be processed with good results, the processing of the JPG file (as opposed to using the RAW file) will produce some artifacts which are easy to see.
But more important to me is the fact that these PP tools are continuously being improved and produce outstanding results when applied to old pictures. I have used mainly DPP and Lightroom, since 2007, to process my pictures and I have found that a RAW picture originally processed with DPP in 2008, when I revisit it with the last version of Lightroom (or  DPP) the result is so much improved, like you have taken the frame with a different camera.
 paparios's gear list:paparios's gear list
Canon EOS 5D Mark II Canon EOS 50D Canon EOS 400D Canon EOS 7D Canon EOS M +17 more
Re: Because sh*t happens!
Yes, stuff happens. But I have appropriate protections against stuff happening based on the degree of loss. Where I don't feel there is a loss,I have no protections.
i can apply this analogy to my picture tafamily as well. Not every shot I take is Ansel Adams, sometimes I just like taking a snap and it is what it is.
Klaus dk wrote:
demarren 123 wrote:
paparios wrote:
Miguel
Miguel
Claus M
______
I totally agree if you print big,otherwise I see no reason to do so.
I also agree that you want to shoot raw.however I am not one of them.
I find raw to cumbersome but hey everyone is deference.
happy shooting
Claus M
______
