Primes vs Zooms
Started May 8, 2013 | Discussions
vbuhay
vbuhay Senior Member • Posts: 2,328
Primes vs Zooms
I know this debate has been discussed here many, many times and its still going on. I was thinking about this yesterday while reading some post here and listening to a baseball game at the same time and it dawned on me:
Primes are for homeruns, Zooms are for base hits. Either way , we all need runs. Enough said!
Vic
 vbuhay's gear list:vbuhay's gear list
Nikon Coolpix AW100 Pentax K20D Pentax K-5 Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED +30 more
lost_in_utah Regular Member • Posts: 458
Re: Primes vs Zooms
Vic
They both have their purposes and advantages/disadvantages. Saying one is always better is a generalization and therefore, flawed.
gatorowl
gatorowl Senior Member • Posts: 1,035
Re: Primes vs Zooms
Vic
Interesting analogy.  I'm not sure I see it--or agree with it--but it does provoke thought.
Perhaps a golf analogy would be better.  However, I'm not sure whether primes are putters and zooms are drivers.
Hmm, thoughts?
 gatorowl's gear list:gatorowl's gear list
Canon EOS Rebel SL1 Nikon D7200 Nikon D500 Canon EOS 80D Canon EF 85mm f/1.2L II USM +12 more
ofior Contributing Member • Posts: 582
Re: Primes vs Zooms
Define homerun:
1-  If that means the success of an image, then, I think we've all seen many homerun photos, some taken with primes, some with zooms, and some we did not know what was used. So, no iI do not agree. Some taken with equipment older than you and I.
2- If homerun means corner to corner pixel peeping "critical" sharpness, then you might have a point, but even then only some primes achieve this consistently.
I agree sometimes must have both, but the number of pros using zooms as their primary lenses seems to indicate that they can hit "homeruns" with zooms. In the end, it is not the bat, but the batter.
Ozzie
 ofior's gear list:ofior's gear list
Nikon D800 Sony a6000 Nikon D7200 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +14 more
scokill Senior Member • Posts: 2,448
Re: Primes vs Zooms
That's like saying the best tool is a hammer.....if using a nail, yes . If using a screw a screwdriver would be better.
 scokill's gear list:scokill's gear list
Nikon D610 Nikon Df Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +1 more
primeshooter Senior Member • Posts: 3,150
This one will never end
Vic
I have no snobbery against zoom lenses. I just don't own any...I prefer the weight of the short primes at least, and the extra 2 stops of light and dof control most of my lenses have.
Re: Primes vs Zooms
Possibly, or just use your head.
wasserball Veteran Member • Posts: 3,417
Re: Primes vs Zooms
Pros use prime telephotos at baseball games.  They move around during the game between first and third base photo boxes or moats.
 wasserball's gear list:wasserball's gear list
Kenko Teleplus Pro 300 AF 1.4x Nikon D3S Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 400mm f/2.8G ED VR II +4 more
Re: Primes vs Zooms
Don't get it...
paulski66
paulski66 Senior Member • Posts: 2,754
Don't listen to these wishy-washy miscreants...
Primes are better.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
ata3001
ata3001 Contributing Member • Posts: 599
Re: Primes vs Zooms
Primes will generally give the best in image quality however many look at zooms as being better because of the "convenience" in getting the image. I don't consider "convenience" an important factor in the final image. Primes are much less convenient to use since it requires constantly changing lenses for that "right" focal length however I find it gives me the ability to use the larger apertures (f/1.8 & f/1.4) that primes offer that aren't available with zoom lenses (f/2.8 at best). The newest primes are extremely good at their widest apertures & I will use these widest apertures when the need arises. Most primes are better at every aperture when compared to zooms. I pixel peep & print large, so even the smallest improvement that a prime lens gives me over a zoom lens is extremely important. More important than the convenience that a zoom has to offer. At the end of the day it's the sharpest, most detailed image that counts. Longer focal length zoom lenses are great for portrait work since ultimate sharpness is not always desired but the longer focal length allows for nicely modeled (out of focus) backgrounds. My opinion only & no one will change it.
 ata3001's gear list:ata3001's gear list
Nikon Coolpix P7700 Nikon Coolpix A Nikon D700 Nikon D610 Nikon AF Nikkor 24mm f/2.8D +33 more
Guidenet
Guidenet Forum Pro • Posts: 15,748
Re: Primes vs Zooms
Vic
I've never really understood this particular discussion. Focal length isn't that important except when you need consider it because you can't get to the position you want, or because you need some particular perspective.
Now, how one gets to the focal length they've decided upon seems to me the most useless information in photography. It strikes me as the ultimate in gearheadism "new word   " Seriously, why would anyone care how you chose the focal length unless it severely affected the IQ as in a super ratio zoom?
To me, a zoom is nothing but a variable prime lens. When I'm going on location and I know exaclty my focal length needs, I probably will take primes because they are usually smaller and faster. If I think I'll need several focal lengths and am not so sure what they will be, I'll bring one or more zoom lenses. It's a bag full of various focal lengths.
But that's all this means, this difference between zooms and primes. That's it. There's no other reason to be concerned or to try and make it part of photography. It always amazes me when people say things like, "I'm switching to all primes" or all zooms or anything of the sort. My retort would be, "So What" or "why would you do that?" What does that have to do with making an image?
Take it easy.
Cheers, Craig
Follow me on Twitter @craighardingsr : Equipment in Profile
 Guidenet's gear list:Guidenet's gear list
Canon PowerShot G1 X Nikon D300 Nikon D700 Nikon D3S Nikon D800 +31 more
Mssimo
Mssimo Senior Member • Posts: 1,041
Re: Primes vs Zooms
Vic
Primes...they are much better.
 Mssimo's gear list:Mssimo's gear list
Nikon D810 Carl Zeiss Distagon T* 2/25 Nikon AF-S Nikkor 85mm f/1.8G Sigma 35mm F1.4 DG HSM Art Sigma 120-300mm F2.8 DG OS HSM +4 more
Mssimo
Re: Don't listen to these wishy-washy miscreants...
paulski66 wrote:
Primes are better.
I would have to say primes are much better.
Stacey_K
Stacey_K Veteran Member • Posts: 7,864
paulski66 wrote:
Primes are better.
Not all primes are better than any zoom. There are many so so primes that don't have the IQ of a really good zoom.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
Mikhail Bogdanov Veteran Member • Posts: 5,829
I've lived in the Red Sox City for 20 years
still don't understand the game... and your insightful point of lenses is...?
paulski66
No no...
Stacey_K wrote:
paulski66 wrote:
Primes are better.
Stacey
...primes are better.
Mssimo
Stacey_K wrote:
paulski66 wrote:
Primes are better.
Stacey
Primes are much better. Zooms are slow, big, only shart in the center, have a ton of CA and cost more money.
If you like to compare a $2000 zoom with a 50mm f1.8...well the 50mm prime still wins.
anotherMike Veteran Member • Posts: 8,098
Yup, I guess that's why I sold my 105/2 AFD DC after finding, on a D800E, that my zoom, the 70-200/2.8G VR-II, was sharper at all distances. Shrug....  (or the 14-24 zoom being clearly better than the Nikon, er, Tamron, er, Nikon 14/2.8 prime...)
It depends on the lens. Modern primes generally beat modern zooms, but at times modern zooms beat vintage primes designed in an earlier era...
-m
LOL! I'm cleaning my bag/lenses now, and grabbed this snap. There is nothing my cheap plastic 50/1.8 wouldn't be ale to do compared to 24-70... assuming it's a prime, and you have to use your feet...
