Lightroom 4 help!
Started May 8, 2013 | Discussions
robertofabbri Regular Member • Posts: 365
Lightroom 4 help!
Good day to you all, I really need help, thank you.
I have been using Lightroom  for many years, I am now on 4 and happy with it.
I am on a long journey in South East Asia and I have been working on it almost every day for the last 4 months. I have less than 5,000 images in one catalog.
Yesterday I tried to import images from my xqd card, Lightroom detected it, opened the import window displaying all the raw images, but after clicking “import” a little window came out with: “Could not copy the files to the requested location”.
I tried the operation several times with the same result; I tried using a compact flash card, same; I tried with raw images from the hard drive, same; I tried with JPEG images, same; I created a new catalog, same.
I checked if something was wrong on the destination panel, but all is correct.
Any idea on this problem, I really need to solve it quickly.
Thank you for your assistance.
Roberto Fabbri
www.robertofabbri-wildlife.com
noirdesir Forum Pro • Posts: 12,482
Re: Lightroom 4 help!
Restart LR? Restart the computer?
cplittleton
cplittleton Regular Member • Posts: 401
I have a mediocre server connection at my office (long story), and every once and a while I'll just get a blank stare from various different applications when I try to save a file.  With the lousy connection, the network will sometimes report that the destination disk is full even though there are several terabytes free.  The software knows about the terabytes of space, but can't access it because of the disk full message, and the software just hangs.
Now my first check for a blank software stare is "is there adequate disk space" and "are there adequate permissions (including connection at my office - not an issue for you) to access that space"?  I only bring this up because I once read about some permissions issues with older LR versions on Macs.
CPLittleton
 cplittleton's gear list:cplittleton's gear list
Konica Minolta Maxxum 7D Sony SLT-A77 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Sony 70-400mm F4-5.6 G SSM Nik HDR Efex Pro +2 more
CameraCarl Veteran Member • Posts: 4,458
You might try copying the files to the hard drive bypassing Lightroom. Then open Lightroom and Add the files to your LR catalog in their existing location.
mustaphapashu Forum Member • Posts: 76
I know you said the right side of the import panel was correct, but did you inadvertently check the box that copies the imported files to a backup drive? That can be an issue if there isn't one on-line.
robertofabbri OP Regular Member • Posts: 365
Thank you Mustapha, but I cannot find the box that copies imported files to a back up drive. Only boxes I see 'don't import duplicates', 'make a second copy' this under files handling and 'into subfolder' under destination.
Help!
Roberto Fabbri
A backup is essentially making a second copy.
