5D Mark iii Off camera Flash Wireless transmitters/ receivers
Started May 7, 2013 | Discussions
Myatix Junior Member • Posts: 29
Hi All,
I want to get some off camera transmitters/ receivers for my Speedlite... I currently have a canon 430EXii but am planning on buying a new flash, perhaps a 600EX?
I have heard Pocketwizard has issues with the Canon 5D mark iii when it comes to the mini and flex? Is this still the case? Are the PW plus iii's better? Would really like something that supports TTL...
it is for use in portrait and wedding photography!
Look forward to hearing your feedback!
thanks!
 Myatix's gear list:Myatix's gear list
Canon PowerShot S95 Canon EOS 5D Mark III Canon EOS 6D Canon EF 50mm f/1.4 USM Canon EF 16-35mm f/2.8L II USM +2 more
drent Regular Member • Posts: 250
Re: 5D Mark iii Off camera Flash Wireless transmitters/ receivers
I use the yongnuo 622. It has all functions like E-TTL and works with on-camera flash settings.
Michael Thomas Mitchell Forum Pro • Posts: 11,042
Another nod for the Yongnuo 622c system. Extremely easy and reliable operation at a fraction of the cost. I particularly like the "transceiver" design. The integrated transmitter/receiver allows mounting of a flash ontop the unit itself.
qianp2k Forum Pro • Posts: 10,350
Maybe initially. By now PW has new firmware update that supports 5DIII directly. I use mini-TT1 (1) and flex-TT5 (2) on 580EX II and 430EX II virtually without problems (similar as 5DII).
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R +20 more
SithTracy
SithTracy Regular Member • Posts: 325
I use the Pixel Kings w/ 5Dmk3, 430EX II and 600EX-RT.  The Yongnuo's are good from what I have read, they are King knockoffs, but not firmware upgradable.  I was concerned there might be initial issues after the new 5d3 fw 1.2.1, but all works great.  One note, you may want to consider a Yongnuo YN568EX instead of a 600EX-RT.  I need another lite and this is likely what I am going to grab.  Supports HSS.
 SithTracy's gear list:SithTracy's gear list
Fujifilm X-Pro1 Canon EOS 5D Mark III Fujifilm X100T Fujifilm X-T1 Fujifilm X-Pro2 +22 more
Keith Z Leonard Veteran Member • Posts: 5,406
Agreed, these 622s just work, super simple to use and inexpensive.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/4.0L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM +15 more
Muresan Bogdan Contributing Member • Posts: 500
If you want to switch completely to 600 ex-rt you could also use the original Canon transmitter.
 Muresan Bogdan's gear list:Muresan Bogdan's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 24-105mm f/4L IS USM +1 more
dave_bass5
dave_bass5 Veteran Member • Posts: 6,211
Yep, another user here. Cant really fault them for basic stuff.
 dave_bass5's gear list:dave_bass5's gear list
Canon EOS 5D Mark III Sony a6000 Canon EF 135mm f/2.0L USM Canon EF 24-70mm f/2.8L II USM Canon EF 35mm f/2 IS USM +10 more
Al Malin Regular Member • Posts: 189
I have same good results with my 5D3, mini-TT1, Flex-TT5s and Canon Speedlights. Recently bought cable to remote fire 5D3 with the PocketWizards.
KatManDEW Senior Member • Posts: 1,894
I'm also using the 622's with my 5D3. I haven't used them much, but when I have they worked well.
 KatManDEW's gear list:KatManDEW's gear list
Canon EOS 300D Canon EOS 7D Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS 5DS R +16 more
Myatix OP Junior Member • Posts: 29
Hi All,
Thanks for the feedback, it has been very helpful!
Looks like pocketwizard burnt their finder when the 5D mark iii came out! I have noticed that both the Mini and Flex aren't fully supported with the 600EX anyone with any experience on this?
cheers
One  more thing!
Can you control the flash power remotely with the Yongnuo 622's?
As far as I understand this can be done with the Mini and Flex... If they work? Is this correctly understood?
cheers!
Myatix wrote:
One  more thing!
With PW AC-3 zone controller that sits on top of mini-1 or flex-5, you can adjust flash strengths remotely on three zones of flashes independently. If I start from scratch I may look into Phottix Odin eTTL trigger/receive seriously. I heard it works very reliably.  PW reliability is not perfect but still pretty good.
http://www.pocketwizard.com/products/transmitter_receiver/ac3%20zonecontroller/
cheers!
Yes, you can!
