Your experience with the Qflash T5dR
Started May 7, 2013 | Questions
Sam Carleton
Senior MemberPosts: 1,971Gear list
May 7, 2013
I have owned Lumedyne for a long, long time and I LOVE it, the only thing I miss is TTL.  I am thinking about getting a Qflash T5dR to gain TTL and I would love to hear others experience with the flash.
Sam
developer of Photo Parata the event presentation software
http://www.PhotoParata.com
 Sam Carleton's gear list:Sam Carleton's gear list
Nikon D2H Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF Micro-Nikkor 60mm f/2.8D
Arved
Senior MemberPosts: 1,396
Re: Your experience with the Qflash T5dR
In reply to Sam Carleton, May 7, 2013
I don't own one, but I was a "voice activated lightstand" for a local pro who had several. The flash foot broke on two of the flash units, and I had a heck of a time keeping the softbox on it (that attaches the same way the reflector does). I once had a flash bulb fall out - fortunately it popped into the the softbox.
Overall, I liked the results we were getting, but I don't think the build quality is up to the pricepoint. Better than my Sunpak 120J, but I never broke the foot off my 'J, either. Retail price on the T5DR being about 10x what the 'J was, and about 3x what a used T2D goes for, I expect better. I dunno - maybe she abused her flash units before I signed on.
Strange thing was, as a "Pro" the photographer refused to use TTL. I think she'd have been better off with a T2D. Those have a repurtation of being built like a tank, but they don't do TTL.
I hope this helps. Good luck!
- Arved
'Highlights next to shadows to create detail, depth, dimension and added color saturation.' - David Ziser
UKphotographers
Veteran MemberPosts: 4,134
In reply to Arved, May 7, 2013
Arved wrote:
I don't own one, but I was a "voice activated lightstand" for a local pro who had several. The flash foot broke on two of the flash units, ...
T5d-R's don't have hotshoe feet.
Ian.
http://www.commercialphotographer.co.uk
Theres only one sun. Why do I need more than one light to get a natural result?
UKphotographers
I use them all the time, and am happy with them Sam.
I prefer the X5d-R's for their greater output, but all the Quantum's work essentially the same. If you already have  400Ws Lumedynes then the X5d-R's will be the same with a Qpaq + 200Ws booster. Alone, a Qpaq is 200Ws. I still have Lumedynes as well but they get used far less than they used to. They normally get used for full power lighting factory interiors or engineering projects, but they  still get triggered by the Quantum FreeXwire receivers and sometimes alongside the Quantums whether using TTL or not.
Older T5d-R heads can split if you apply too much pressure to the fixing collar forcing the head clams apart but the newer ones are better. I've properly broke one in about six years. The tighter you fasten them the more pressure is applied to the head clam which forces it apart.. using some Chimera speedrings or some Lumedyne ones which are thicker gauge can lead to stressing the head clam, so don't just force the fitting and don't be heavy handed. I don't expect to swing a 100x120 softbox on the neck-flange, It's not sensible. The metal body of the Lumedyne deluxe heads are better suited for that or use an adapter instead.
The new R3 upgrade for the T5d-R is useful which enables three remote T5d-R's to be controlled in any mode and whilst I have the Trio and Pilot for control, I find that I mostly use the CoPilot as a controller. The CoPilot will control 3 groups in TTL or Manual, or mixed and is really small.
Ian.
Arved
In reply to UKphotographers, May 8, 2013
Hmmm... Sorry. Thanks for the correction!
So, to correct my ignorance, is there a T5 series model that has the hot shoe mount? Now I'm curious. The lady said she was using T5dRs, so I assumed she knew what she was talking about, and had no reason to question her.
- Arved
NYCphotoman
Regular MemberPosts: 134
In reply to Arved, May 8, 2013
T5D-R is "handle mounted" and does not have a shoe.  So the screw from a tripod or camera bracket will screw right into it.  You either need screw type lightstand or a bracket.
The TRIO is the only shoe mounted Quantum flash.  The Pilot, a headless TRIO, is also shoe mounted.
UKphotographers
The hotshoe on the Trio grips like a limpet as long as you tighten it up.. you did tighten it up if it was a Trio did you ?
Ian.
UKphotographers
In reply to Sam Carleton, May 8, 2013
If you already have Lumedyne packs, the X5d-R heads will fit those with a Lumedyne>Quantum adapter.
Ian.
Sam Carleton
Re: Your experience with the Qflash X5d-R
I misstyped, I was really asking about the X5d-R, not the T5d-R.  I want the one that goes to 400w/s.
Is my impression correct that both units work with modern TTL of Canon and Nikon?
Sam
UKphotographers
In reply to Sam Carleton, May 9, 2013
With an appropriate 'D' adapter fitted for hotshoe use or remotely with an FW7Q for radio, or a Qnexus for IR, both the T5d-R or the X5d-R will operate with Canon or Nikon TTL.
Ian.
Arved
In reply to UKphotographers, May 9, 2013
Yes. We tightened it up, but it self-loosened. There's a collar that pulls the shoe foot into the flash, rather than the more common tightening nut that clamps the shoe to the foot. The work around was to use a cold-shoe with a screw clamp. IIRC, I talked her into (read: gave her my) Stroboframe shoe until she could send them in for repair.
I thought it was a novel design, but something must have gotten stripped inside the flash.
Again, I apologize for assuming this was the T5dR. I'm not that familiar with these flash units. Thanks for pointing out this must have been the Trio. Between the foot issue, and the bulb seemingly spontainiously ejecting, I have to say that I'm not impressed with the build quality, but I was impressed by the volume and quality of light produced.
- Arved
