Filter stuck on lens
Started May 7, 2013 | Discussions
ReallyJustMe
ReallyJustMe Junior Member • Posts: 43
Having a stuck filter, I searched a bit around and found this:
https://ongabonga.wordpress.com/2013/05/05/how-to-remove-a-filter-that-got-stuck/
Has anyone tried this thing?
Best regards
hotdog321
hotdog321 Forum Pro • Posts: 15,164
Re: Filter stuck on lens
Yeah, I used something similar several times back in my film days. Cheap plastic filter wrenches are the best thing since sliced bread for removing jammed filters or separating a filter/step up ring combo.
Cheap, easy separation, no damage--every photographer should have one or two stashed in their bag. The ones you show in your link look a bit superior to the standard set.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Hank3152
Hank3152 Forum Pro • Posts: 13,448
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
ReallyJustMe
ReallyJustMe OP Junior Member • Posts: 43
82mm
Thanks for the reply. I was aware of these, but I only saw up to 77mm. I would need on for 82mm, which seem to fit into the jar opener.
I wouldn't mind something smaller, than the plastic thing, but I couldn't find anything for else for 82mm.
ReallyJustMe
Thanks for the reply, I think I might give this a try.
puttin
puttin Veteran Member • Posts: 6,713
Don't squeeze the filter between your fingers it distorts it making it harder to twist. Place your palm over the filter and press while twisting, works every time for me.
 puttin's gear list:puttin's gear list
Fujifilm XF1 Fujifilm X100S Nikon Coolpix A Nikon D300 Fujifilm X-Pro1 +30 more
SteveY80
SteveY80 Regular Member • Posts: 199
That does usually work with standard filters, but it's not a viable technique when the front of the filter rotates, e.g. a variable ND filter or circular polariser. I had a hell of a job getting a CP filter removed from a used lens that came with one stuck on.
ReallyJustMe
Perfect for 82mm filters
Exactly. I had a stuck Polarizer in 82mm and I couldn't get it off.
In the meantime I received it, and it loosened the filter instantly! It is a tiny bit bulky, but the only thing I found that would work on a 82mm filter.
