MacBook Pro?
Started May 7, 2013 | Discussions
Elbert Zip Johnson
Elbert Zip Johnson Contributing Member • Posts: 834
MacBook Pro?
Can i use 2 of the same (canon shelby 800) printers on my mac book pro lap top?
I want to have images print to each printer as needed.
Can some one walk me through the set up?
 thanks
Zip
'EVENT PHOTOGRAPHER'
MID WEST
check me out? www.zipsphoto.photoreflect.com
Howard Moftich Veteran Member • Posts: 7,854
Re: MacBook Pro?
Not sure what you mean by 'as needed' but all that you hvae to do is Add each printer and select which one you want once your app (which one are you using?) drops you into the printer driver dialog
Jen Yates Senior Member • Posts: 1,413
Re: MacBook Pro?
Step 1: Plug in printer A
Step 2: Configure printer A (I suggest calling it something logical such as 'Printer A')
Step 3: Plug in printer B
Step 3: Configure printer B (Coming up with a suitable name could be tricky, but if you've followed my steps so far then 'Printer B' should be available)
Step 4: Print from your app, being sure to select 'Printer A' from the 'Printer:' drop down.
If you're finding step 4 tricky then I suggest revisiting step 2. Did you configure your printer with the correct name?
Of course these steps are assuming you only ever want to print from printer A. If you also want to print from printer B then you'll need to somehow adjust step 4.... I'll let you work it out.
Jacques Cornell
Jacques Cornell Veteran Member • Posts: 6,315
Printer pool
 thanks
Zip
MID WEST
If you have two matching printers, you can combine them into a "pool". The advantage is that you send your document to the pool, and whichever printer is least busy will print it. Great for high-volume, high-speed printing operations. Here's Apple's support article on how to set up a printer pool.
http://support.apple.com/kb/PH10891?viewlocale=en_US&locale=en_US
'No matter where you go, there you are.'
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G X Vario 35-100mm F2.8 OIS +27 more
TheDoctorWhat Regular Member • Posts: 158
Re: MacBook Pro?
 thanks
Zip
MID WEST
One more question. Are you using Photoshop or some software to edit and then print?
I know Photoshop and Photoshop Elements you do a print preview to set the page up and choose what printer you want to use. I have a 4x6 printer and a 13x19 Epson printer. You just select which one you want to use.
When you hit print, you should also adjust the print settings to the type of paper your using.  If your using the printer for just printing a document and have the settings for a photo the printer will spray too much ink saturating the page.
If you use Matte ink jet paper don't select the Glossy setting as that will also use more Ink when you do not need to do that. You'll have to replace ink more often costing you more money.
Just remember their is more to just selecting the printer, the options to tell what paper is being used to control the ink flow is important more so.  Of course use specific ink jet paper.
For me I like the Epson Photo printers for my needs. I've used Epson photo printers for at least 10+ years.
Peter Berglund Regular Member • Posts: 100
Re: MacBook Pro?
I believe the maximum number of USB attached devices is 127, so two would not be a problem. The fact that they are the same model does not complicate it as long as you name them differently so you know which one you're printing to.
Peter
 Peter Berglund's gear list:Peter Berglund's gear list
Canon PowerShot SX210 IS Canon PowerShot S100 Canon EOS M Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 22mm f/2 STM
Elbert Zip Johnson
Elbert Zip Johnson OP Contributing Member • Posts: 834
Re: MacBook Pro?
Thanks for all you'll responses
peace
Zip
MID WEST
