Problem updating CS6
Started May 6, 2013 | Questions
Ellar Contributing Member • Posts: 896
Hi Guys
I have probably done something stupid but wonder if someone can help me out.
I am running CS6 on my Macbook Pro (OS 10.8.3) and decided to run an update. Everything went fine until I fired up CS6 again. Now it appears that I have a trial version of CS6 Extended and I'm being asked for the product key. I've no idea how this happened, don't want CS6 Extended and want to get back to CS6 which i have obviously paid for.
Can I simply uninstall the extended version and re load my copy of CS6 or will this use up my "2nd machine" part of the licence. Is anyone able to explain how, when running the updates, I have managed to end up with an Extended version?
I haven't installed CS6 on my desktop yet as I have just replaced my old machine with a new iMac.
Any help gratefully received
Cheers
Paul
(unknown member) Veteran Member • Posts: 3,985
Re: Problem updating CS6
My best guess would be to go to the help menus and select the deactivate option, removing it as if you were simply going to change computers, the do a fresh install.
One day long ago, a sorcerer and a warrior did battle, as such things were commonplace in that age. Sometimes the sorcerer won, and the sum value of human abilities was improved some trifling amount. Sometimes the warrior won, and again the human race improved by some insignificant amount, for a sorcerer who can't defeat one miserable warrior is a poor sorcerer indeed.
Ellar OP Contributing Member • Posts: 896
Can't "deactivate"
Hi coronawithlime
Thanks for the response but I can't select the deactivate option because it is greyed out, probably because I now have a trial version. I'm thinking the best option is to do an uninstall and then re load my copy of CS6. I'm just not sure if there will be any repercussions
Howard Moftich Veteran Member • Posts: 7,856
Re: Can't "deactivate"
I'm too lazy to google this right now but that was a problem w/ a specific update.  I believe that Adobe released either a update to the update or a special little tool to 'do the right thing' and fix it.
You'll have to do a little searching
I seem to remember seeing a "removal tool" on the Adobe site that sounded like it was for cleaning up the mess.  Maybe that's what is needed.
Problem solved
Hi Howard
I had already googled this,before posting here, without success. However perseverance and some lateral thinking eventually found the solution. I've posted the link below to help anyone else with the same problem.
http://forums.adobe.com/thread/1114727?start=0&tstart=0
Thanks anyway
Paul
Howard
Was just typing my "problem solved" reply when you posted this.
Thanks, Howard
Paul
