I need help
Started May 6, 2013 | Discussions
Jack D. Senior Member • Posts: 2,117
I need help
Hello Every1:
Here is a photo taken some time ago:
After PPing and seeing final version I have noticed ugly colours on my grandson's head. It can be removed by correct use of Topaz but there is another bad thing: the highlights are blown there and on boy's right arm.
I know that it can be easily (?) fixed using Photoshop masks etc but I don't know how to to it.
Can anyone fix it giving me work flow with all numbers etc?
RAW file available upon request.
Thanx in advance.
Jack
 Jack D.'s gear list:Jack D.'s gear list
Sigma DP1x Sony Alpha 7 II
asoftwind
asoftwind Veteran Member • Posts: 4,960
Re: I need help
Claude
benross Contributing Member • Posts: 924
Re: I need help
You will be better off working on your RAW file. I can't give you numbers because I don't have any (that you could use) since this edit was done with Pixelmator.
I duplicated the layer. On top layer I colour selected the cyan ring on his forehead. I extended the colour selection range to include the cyan halo around his face and the in his heir. This range of-course includes lots of areas in the image but for that parts I could mask the layer and use the original layer instead.
I then used the hue - saturation and luminance tools to change the cyan to a colour of its proximity. It was done with trial and error. but I think I improved it somewhat.
Jack D. OP Senior Member • Posts: 2,117
Re: I need help
Thanks for your help, guys.
Asoftwind: I like what you have done with highlights (this is, what I was looking for) but I don't like an idea of making it soooo colorish.
If I could keep original color together with your blown highlights fixed job - just like benross done it - it would be just great.
But how have you done it? Cloning?
Babine Veteran Member • Posts: 6,163
Re: I need help
Jack D. wrote:
Hello Every1:
Thanx in advance.
Jack
I used ACR to lighten overall, decrease the highlights somewhat and saturate. In CS, I used masks to selectively recolour, add light rays, darken BG, etc to draw a bit more attention to the subject and his lion.
Cheers.
Gary
http://forums.dpreview.com/Galleries/8298604696/photos
http://www.pbase.com/pictek
Law of Logical Argument - Anything is possible if you don't know what you are talking about.
asoftwind
Re: I need help
Highlights were fixed with a mix of Darken, Luminosity, and Color blend modes. And other tools too. For instance, in the case of his hair I used a hair brush and painted using an adjacent color. I worked section by section. Took a lot of time. I used Elements. If you would like the colors less saturated all you have to do is reduce saturation in Hue/Saturation. Try the following settings:
Reds: Sat -5, Lum -18. Yellows: Sat -50, Lum +2.
Claude
Jack Sofield Senior Member • Posts: 2,271
Re: I need help
Way to go Gary.  Looks great.
Always teach for understanding, not agreement.
JC Sofield
www.pbase.com/jcsofield
Cheers Jack Thanks. nt.
Cheers.
Gary
Re: Thank you all. (nt)
No text.
