7100 - What prime lenses do you use?
Started May 6, 2013 | Discussions
bobgeorge Contributing Member • Posts: 589
I'm seriously consider getting the D7100.  Question... what prime lenses do you use?  50/1.4? 50/1.8?
If so, will that make it a 75mm equivalent?
BG
 bobgeorge's gear list:bobgeorge's gear list
Nikon D600 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Sigma 50mm F1.4 EX DG HSM Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR
Nikon D7100
krikman Regular Member • Posts: 404
Re: 7100 - What prime lenses do you use?
Nikkor AF-S 28/1.8
Just right for D7100 - lightweight enough and resolves 24 MP. Speedy autofocus.
With 1.3x crop you have 42 and 58 mm equivalent.
Whalligeo Regular Member • Posts: 245
BG
50mm f1.8 is ok, the f1.4 is nicer but twice the price. yes it equates to 75mm in 35mm parlance and close to 100mm in crop mode. Its good for portraits, close family groups and selective landscape. If its you only lens, you might find it restrictive just on its own. If that's the case, I suggest something shorter.
They said it couldn't be done, so I encouraged my peers not to bother.
HooRoo!
PepsiCan Contributing Member • Posts: 739
BG
35mm DX 1.8
AF-D 50mm 1.8
AF-S 85mm 1.8
To get to the ideal ff length of 85mm you'd need a 58mm on DX, which does not exist. Instead use a 60mm fast macro.
The crop factor on the D7100 is 1.5 while all Nikon lenses have their focal length expressed in full frame terms.
 PepsiCan's gear list:PepsiCan's gear list
Canon PowerShot S95 Adobe Photoshop Lightroom 4 Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +5 more
bobgeorge OP Contributing Member • Posts: 589
Thanks all.  How is the bokeh with those lens? Are they good at creating a shallow DOF?
SverreE Contributing Member • Posts: 512
I think all the new primes gives a very good bokeh.
I have 35mm f/1.8 and the old 50mm f/1.8. I think the new 50mm is better: http://photographylife.com/nikon-50mm-f1-8g-for-wedding-photography
http://photographylife.com/which-nikon-prime-lens-to-buy-first
Sverre
BillD7000 Contributing Member • Posts: 778
I am loving the 85.1/8, having sold the excellent Sigma 50/1.4...  I like the more flattering close-up portraits with the 85mm.  It's VERY sharp and the detail is maximized wit the D7100.
 BillD7000's gear list:BillD7000's gear list
Nikon D7100 Nikon AF-S Nikkor 300mm f/4D ED-IF Sigma 8-16mm F4.5-5.6 DC HSM Sigma 105mm F2.8 EX DG OS HSM Nikon AF-S Nikkor 85mm f/1.8G +1 more
AdamT
AdamT Forum Pro • Posts: 58,440
Same here
Same here - the revamped AF-S versions of these lenses (Miraculously with RING Type AFS rather than the Crappy cog type AFS you`d expect for the price) are vast improvements on the originals
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
dcmackintosh Regular Member • Posts: 192
As it should be, since focal length doesn't depend on what size sensor is behind it.
I have the 35 and 50 1.8G primes.  I'd say that I prefer the 50 and generally will only switch to the 35 when I can't back up enough.  Most of my shooting is with my 80-200 f/2.8D, though, so I'm sure I'd like an 85 1.8.
hiro_pro
hiro_pro Regular Member • Posts: 281
i have the d7000 and the last trip i took i mainly used the sigma 30 1.4 and the nikon 85 1.8.  both are great lenses.  i love the 30 for walking around and that 85 is perfect for portraits.
d7000
tamron 17-50 f2.8
sigma 70-200 f2.8
 hiro_pro's gear list:hiro_pro's gear list
Nikon D600 Nikon AF Nikkor 50mm f/1.4D Tamron SP 24-70mm F2.8 Di VC USD Tamron SP 70-200mm F/2.8 Di VC USD Nikon AF Nikkor 35mm f/2D +4 more
Patrick Cox Contributing Member • Posts: 626
krikman wrote:
Nikkor AF-S 28/1.8
Do you think this lens is worth the premium you pay over the 35 1.8 DX?  I know I would prefer the 28 focal length but not sure it is worth the price difference.
 Patrick Cox's gear list:Patrick Cox's gear list
Sony Alpha 7
Have you had any problems with CA on this lens?  I have read that it can be very bad.  Thanks.
Sony Alpha 7
Stacey_K
Stacey_K Veteran Member • Posts: 7,864
I much prefer the 85mm f1.8g to the 50mm f1.8g for portraits, at least for head and shoulders type. It's an amazing lens.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
FujicaST605
FujicaST605 Regular Member • Posts: 462
Stacey
Agree on the 85 1.8G.
I also use the 35 F1.8G DX
and a 50mm F1.8 Series E (ai-s)
 FujicaST605's gear list:FujicaST605's gear list
Nikon D7100 Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 DX II Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Nikon AF-S Nikkor 85mm f/1.8G
Patrick Cox wrote:
krikman wrote:
Nikkor AF-S 28/1.8
definitely better rendition, better contra-light (Neveg actually go bad), faster AF, brilliant close-ups. And 28 much better than 35 on DX. It is safe to use only this lens - you'll got photograph in any condition.
And Nikon claims weather protection for this lens.
You pay for what you get.
Not at all...  The Nikon 85/1.8 is simply one of the best available.
The 85/1.8 is super on the D7100...
depscribe Senior Member • Posts: 1,215
I fairly regularly use the 50mm f1.4 Nikkor, the 85mm f2 Nikkor, the 105mm f1.8 Nikkor, the 180mm f2.8 Nikkor, and the 500mm f8 mirror reflex Nikkor. These are all manual focus, but in that I manually focused them on film cameras for years, I have no issue with manually focusing them on the D7100. And it makes following focus quite easy.
And yes, they all have a crop factor of 1.5x, so the 180 is effectively a 270mm f2.8 anf the 105 is effectively a 157mm f1.8. And the 50 is, yes, effectively a 75.
But what crop factor giveth it takes away -- none of my lovely Nikkor wideangles are wideangle anymore!
 depscribe's gear list:depscribe's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X30 Nikon D7100 Fujifilm X-E2 +8 more
