Chromatic Abberation
Started May 5, 2013 | Questions
RiDeC58
RiDeC58 New Member • Posts: 12
I have only Photoshop Elements.  Is there a simple process for removing so-called "Purple Fringing" while preserving overall color balance? Does one have to "Select" the fringe and change it's color or is there an easier way? Any help would be appreciated.
Thanks,
Richard
Ronny Harris
Ronny Harris Veteran Member • Posts: 7,062
Re: Chromatic Abberation
Open a Hue/Sat adjustment layer.  Choose Magenta in the drop down menu and click the dropper on the fringe.  You can now desaturate and/or change the hue.  Invert the mask to hide the effect and then paint the effect back in over the fringe.
Ronny
RiDeC58
RiDeC58 OP New Member • Posts: 12
Thanks Ronny, I'll give this a try.
Steve Bingham
Steve Bingham Forum Pro • Posts: 23,300
Yes! Easy
In ACR, when converting to tiff, go to the lens icon. Under the Color tab, make sure the Remove Chromatic Aberation box is checked. Under the Profile tab, make sure your particulat lens is selected (vignetting and dsitortion). Done.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D810 Nikon D5500 Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 85mm f/1.8D +27 more
Toermalijn
Toermalijn Forum Pro • Posts: 13,503
Re: Yes! Easy
Steve Bingham
www.dustylens.com
Not sure acr is in elements...
Steve Bingham
Re: Yes! Easy
Steve Bingham
www.dustylens.com
You might be right. It IS in Elements, but perhaps it does not have this feature (Elements uses a slightly crippled version of ACR). Someone with Elements 11 might want to jump in.
Steve Bingham
www.dustylens.com
RiDeC58
Re: Yes! Easy
Thanks for the tip.  I have Elements 10.  My ACR does not have this, but I will check to see if I can download a newer version which might.
Thanks.
sensingsys
sensingsys Senior Member • Posts: 1,535
You can try this PhotoShop action http://blog.lorrifreedman.com/index.php/2008/07/30/hdr-and-the-purple-fringe/ , not sure if it works in Elements.
Brev00
Brev00 Veteran Member • Posts: 7,419
Re: Yes! Easy
Are you shooting with a Nikon camera?  Nikon View NX2, a free download, has a ca correction tool.  I just move the affected files completed in Elements through the Nikon software for a very quick click and save.  Maybe do another adjustment or two while I am at it.  Canon's software may have the same option.  There are other plug-ins you can upload (ptlens, for instance) that offer ca correction.  I am hoping Adobe adds this feature in Elements 12 but I am not holding my breath.
www.flickr.com/photos/brev00
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 DX II Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +3 more
JulesJ
JulesJ Forum Pro • Posts: 38,963
Re: Yes! Easy
Steve Bingham
www.dustylens.com
I think this is the preferred route to getting rid of it.
