Bolt VX-760C Wireless TTL Flash
Started May 4, 2013 | Discussions
BrettSD
Regular MemberPosts: 186Gear list
May 4, 2013
Has anyone out there used the Bolt flashes, particularly the VX-760?  It appears to be new B&H store brand, and I've always had good luck with their store brands (like Impact), but there are no reviews on their site yet.  The price is right and the specs looks very good (E-TTL, guide number close to the 600ex and can be used wirelessly as master/slave), but I'd love to know how it works in the field.
www.headshotsnyc.com
www.gothamfamilyphotos.com
www.nyweddingphotos.com
 BrettSD's gear list:BrettSD's gear list
Canon EOS 5D Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/4.0L USM Canon EF 100mm f/2.8 Macro USM
Sailor Blue
Veteran MemberPosts: 8,676Gear list
Re: Bolt VX-760C Wireless TTL Flash
In reply to BrettSD, May 5, 2013
Talk about Smoking Strobes!
The Canon 580EX II which has a guide number of 45 at ISO 100 & 50mm..  This flash claims "Guide Number: 164' at ISO 100 & 50mm".
B&H - Bolt VX-760C Wireless TTL Flash for Canon
Speedlights.net | Canon Speedlite 580EX II Flash Review
Like they say, if it sounds to good to be true then it probably isn't.  This is most likely the greatest exaggerated guide number I have ever seen in print.
It isn't stated that this is a Master Flash so it is probably a Slave Flash, much like the Canon 430EX II.  Personally I would buy a 430EX II, a Nissin Di622 II, or a Yongnuo YN-565EX.
Speedlights.net | Canon 430EX II Speedlite Flash Review
Speedlights.net | Nissin Flash Review: Di622-II (flash for Canon / Nikon)
Speedlights.net | Yongnuo YN-565 EX Flash Review (Equiv 430EX II & ETTL-II on/off-camera)
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Kuppenbender
Senior MemberPosts: 1,957Gear list
In reply to Sailor Blue, May 5, 2013
I think the apostrophe after the 164 means feet rather than the industry standard meters. This would give the Bolt a more believable GN of about 50.
 Kuppenbender's gear list:Kuppenbender's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +3 more
Sailor Blue
In reply to Kuppenbender, May 6, 2013
Good point.  It is still pretty high and probably an exaggeration but more believable.
My advice still goes, if you want an E-TTL flash get one that is know to be a good one like the three I recommended.  They are listed in order of ruggedness and probably in order of longevity.
BrettSD
BrettSD OP
In reply to Sailor Blue, May 6, 2013
It is listed as a master flash, which makes it significantly different than the others you mentioned.  But it is missing high speed sync as best as I can tell, which might make it a deal breaker.
Upon further research, the Bolt flash appears to be identical to the Oloong SP-690II http://www.lightingrumours.com/oloong-sp-690-ii-is-affordable-wireless-ttl-master-1968 and and Calumet Genesis SP 692, all of which are Master/Slaves with guide number of 50 and lacking HSS.
