External drive
Started May 4, 2013 | Discussions
Christopher D Mann Regular Member • Posts: 394
External drive
I have a mid 2011 27in  iMac and I am wanting to get a external hard drive for it. I have one firewire port and two thunderbolt ports. I want to use the thunderbolt ports if possible. I am using Lightroom 4 and I have been storing photos on a time capsule but very slow to bring photos into Lightroom from it and now realizing that is not Time capsules intended purpose. I have looked at the 2TB LaCie thunderbolt units but they seem to get mixed reviews. Just wondering if anyone has a good suggestion. Thanks
 Christopher D Mann's gear list:Christopher D Mann's gear list
Tamron SP 70-200mm F/2.8 Di VC USD Nik Silver Efex Pro
Nikko aus London Senior Member • Posts: 1,138
Re: External drive
I bought the LaCie 1TB Thunderbolt SSD Little Big Disk which I use in RAID0.  It contains all my user folders including my Aperture database.  Performance is astonishing!
Nikko
 Nikko aus London's gear list:Nikko aus London's gear list
Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
CameraCarl Veteran Member • Posts: 4,457
Re: External drive
Several years ago I bought a USB powered LaCie hard drive. It failed under warranty and I sent it back. The remanufactured replacement started making grinding noises within a few months so I sent it back. The second refurb seems to be working ... for now.  You might consider OWC external hard drives.  I've seen lots of good reports on here about them; do a search and you'll find many, many more discussions about external drives.
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 16,728
Re: External drive - Stupid Question.
I've had an OWC drive for over a year, now, no problems whatsoever.........except I'm not really sure how to best use it.
I am, as you can tell form that, not particularly "computer literate", I've just been using my iMac and slowly coming to terms with it, but I have no idea if I'm doing things "right".
A couple of weeks ago, my sister's newer iMac just quit and the Mac store says they can't access her photos and such from the dead harddrive, and I'd like to protect myself from that and have been dragging photo files to the backup but don't know where they all are.
STUPID QUESTION:
Could I just drag my hard drive Icon to the backup disk?
Thanks - and yes, you may berate me for my stupidity, I deserve it!
-Erik
'He who hesitates is not only lost - he's miles from the next Exit.'
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
Peter Berglund Regular Member • Posts: 100
Eric,
Really, I don't recommend you doing backups manually like that. Instead, get a cheap external drive that is at least 50% larger than your HDD and set up Time Machine. If your internal drive fails you will have your entire system up and running again in no time.
If you absolutely need to know your images are in the iPhoto library bundle (looks like a file) in you Pictures folder. I assume you're using iphoto...
But you will find it a total mess to browse that library in Finder with a myriad of thumbnail image files etc. stay away would be anybody's strong advise.
Peter
 Peter Berglund's gear list:Peter Berglund's gear list
Canon PowerShot SX210 IS Canon PowerShot S100 Canon EOS M Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM
Tom_N Forum Pro • Posts: 10,211
Erik Ohlson wrote:
STUPID QUESTION:
You'd be better off to buy a copy of Carbon Copy Cloner or SuperDuper to do the backup.  Either of these can be used to do incremental backups – so that the second, third, etc. time that you do your backup, you only have to wait for the machine to find and copy the files that have changed.
You can also make backups to multiple drives, so that you can keep one off-site (just in case fire, flood, hurricanes, tornadoes, etc. get the computer equipment inside your house).
Howard Moftich Veteran Member • Posts: 7,851
I just want to clarify what was said.  CCC or SuperDuper! will do a *smart copy* which means it will find new/changed files (since the last copy) and copy only those new/changed files to the 'master' backup.  What it will NOT do is keep a series of copies over time (ala Time Machine).  Each technique has it's own advantages and disadvantages.  I usually have *both* a TM and SD copy made for any machine and data I care about.
Erik Ohlson
Stupid Question, many thanks!
Thanks for the replies - that gives me something to check into.
It was a real wake-up call when my sister's newer machine suddenly died
So, if I understand what I think you are saying, "Time Machine" will keep saving the same thing (including changes) over and over, wheras "CCC" or "SuperDuper" will just update from time to time with only new or changed data.
Is that pretty much what happens?
Cheers, and thanks, all,  -Erik
(unknown member) Veteran Member • Posts: 3,985
Re: External drive
I currently have two thunderbolt enabled G-Tech's which work very well.
However, they just ignored my third email to tech service, so if you ever need service I think you might be out of luck.  I wouldn't buy another for this reason.
One day long ago, a sorcerer and a warrior did battle, as such things were commonplace in that age. Sometimes the sorcerer won, and the sum value of human abilities was improved some trifling amount. Sometimes the warrior won, and again the human race improved by some insignificant amount, for a sorcerer who can't defeat one miserable warrior is a poor sorcerer indeed.
Re: External drive
that's kind of obnoxious since they are 'premium' priced to begin with.
Re: Stupid Question, many thanks!
Time Machine stores a series of "snapshots" of each file.  This may not include EVERY change you save to the file because (a) there is a limited amount of space on the backup drive, and (b) Time Machine only looks for new versions to save every so often.  But it often stores multiple versions of a file, which may let you recover if you do a Save and then wish you hadn't.
The downsides of Time Machine are that the backup disk isn't bootable (you have to restore the Time Machine backup to another drive, then boot from that drive), and that the "backup in the background nature" of Time Machine backups encourages you to keep the backup drive connected to your Mac at all times (where both could be taken out by a single catastrophic event like a fire).
CCC and SuperDuper help you to keep a copy of the latest version of each file, but they don't do anything (directly) to help you keep catalogs of past versions that you can browse through.
Re: External drive
Imagine what I think.  I'm the one who wrote the check
Let me explain the key difference between TimeMachine and CCC here. CCC will back it up such that your external drive has precisely the same content as your hard drive.  It will do so by updating the files that have changed recently. The advantage:  the backup drive doesn't need to be bigger than your internal hard drive.
TimeMachine will also back up files that have changed recently (not back up the same stuff "over and over again").  But it will keep historical version for a while such that you can browse back in time. The advantage: let's say you one day open up a photo or a movie and find that it got corrupt by a disk error.  With CCC that corrupt file would be on your backup so your file is lost. With Time Machine you can step back day-by-day, then week-by-week, month-by-month etc until you find your intact file. Similarly, if you accidentally delete a file it will be gone forever with CCC but with TM you can go back and recover it.  The drawback with TM: the external drive should be at least 50% larger than the amount of data you are backing up.  With today's price levels I personally think it's worth it. CCC and SuperDuper were great tools and they still have their use in cloning disks. For example, I make a CCC backup once a month or so to a backup drive I keep in my office drawer at work just in case our house burns down or similar.  But with Time Machine now available for free, with such an elegant user interface, I would not recommend anybody to use these older methods (CCC etc) any more for their daily backup needs.
Peter
