Upgrading Nikon D80 to D5200? or D7200? - will lenses transfer?
Started May 4, 2013 | Discussions
Sandi Price New Member • Posts: 1
I have a Nikkor AF-s 18-135mm DX lens and a Tamron AF XR DI LD 28-300mm lens that I used with the D80. Will those lenses work on the D5200 and D7200?
I would also like opinions as to whether the D7200 is worth the extra cost over the D5200?
I am a hobbyist - don't know much about photography but am trying to learn.
thanks,
Sandi
Nikon D5200 Nikon D80
stevehughes
stevehughes Regular Member • Posts: 449
Re: Upgrading Nikon D80 to D5200? or D7200? - will lenses transfer?
Hi Sandi,
its a D7100
is the Tamron AF XR DI LD 28-300mm a screw-drive lens ? If so it will not auto-focus on the D5100. The Nikkor would though.
both lenses should be fine on the D7100 as far as I can see.
is the D7100 worth the extra cost over the 5100?  Depends. It the answer was a straight "yes" they wouldn't sell any 5100s.  The image quality would be very similar.  You'd be paying for the extra features of the D7100.  For me, it's a YES (I just bought one to replace my D50).  For others maybe not so.
Best regards,
Steve
 stevehughes's gear list:stevehughes's gear list
Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 85mm f/1.8G +3 more
eddyshoots Senior Member • Posts: 2,176
thanks,
Sandi
Your 18-135 with work with both cameras you ask about; it is an AFS lens which means it has a built in focus motor. The D5200 doesn't have a focus motor so it can only auto-focus with AFS (common) and AFI (rare) lenses. The D7200 has a focus motor built in so it can auto-focus with any auto-focus lens made by Nikon (AF, AFI, AFS, AFD). For maximum lens compatibility go with a camera like the D7200 and stay away from the entry level cameras such as the D5200.
http://www.kenrockwell.com/nikon/compatibility-lens.htm
The Tamron is another matter. I'm not sure. I think Tamron uses the letter combo of USD (ultra sonic drive) or PZD (paisano drive    ) on some lenses to indicate having a built in motor. I don't think your lens has such a motor. If not then you need to go with the D7200 over the D5200 if you want to auto-focus with it. The newest Tamron 28-300 has the built in motor....I guess it all comes down to how old your copy is. Tamron has been a bit confusing with this issue where some lenses are labeled and some are not, it's a real mess.
eddyshoots
MRM4350
MRM4350 Senior Member • Posts: 1,921
Both of the previous replies sort  of answer your question, but I would like to clear up some details.
D5100 16 megapixels
D5200 24 megapixels
D7100 24 megapixels
I believe you are asking about the two 24megapixel models. Your AF-S 18-135 will auto focus on either model, but I'm guessing that the Tamron is old enough to be of the AF D type of Nikon auto focus which needs a motor in the camera. If that is the case then only the D7100 will auto focus that lens.
Is the D7100 worth the extra $ over the D5200? If you use auto ISO, and always shoot in P, A, or S mode you will not notice the differences in control. Me, I would never consider anything below the D7100 (disclaimer: I use a D7000, and a D90).
 MRM4350's gear list:MRM4350's gear list
Nikon D90 Nikon D7000 Nikon Df
D5100 16 megapixels
D5200 24 megapixels
D7100 24 megapixels
heh heh....Sandi writes 7200 and I just blindly follow suit. Yes, of course, we both meant the D7100.
eddyshoots
DavidPonting Regular Member • Posts: 268
The feature set of the D80 is much closer to that of the D7100 (dual controls, top LCD, body size &c), so for that reason alone I would argue that you will want to upgrade to that rather than lose those features. You then don't need to worry about lens compatibility! (Though 24MP is a lot - I'm not sure how well your lenses would resolve any 24MP sensor, D5200 or D7100...)
GlennW Senior Member • Posts: 1,922
thanks,
Sandi
The Nikkor will function on either camera.  You will have an option to get the 18-105 kit lens that may be a better lens on a 24mp camera. You may also want to upgrade to 16-85 if that suits your shooting style.
The Tamron with the AF-D style AF will be best on a 7100 over the 5200. You may also get a package deal to include a Nikkor 70-300 VR when you buy your camera.
Because of the extra controls, AF-S, commander flash, the 7100 does carry a premium price over the 5200. If your budget does not allow for lens upgrades + Camera, you could go with the 5200 with the 18-105 kit lens & use that to rebuild your collection of good glass.
For a casual shooter, the less expensive 5200 may be fine for you. Both cameras get high IQ scores.
I Shoot RAW
 GlennW's gear list:GlennW's gear list
Nikon D5300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +4 more
breakaway01 New Member • Posts: 17
Sandi,
I think you will get more useful advice if you can tell us why you want to upgrade. Other than low-light image quality, what aspects of the D80 do you think you would like to be improved?
Escape Regular Member • Posts: 346
Doesn't the D5200 have AF-S, too?
 Escape's gear list:Escape's gear list
Panasonic Lumix DMC-LX7 Nikon D5200 Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 50mm f/1.8G Sigma 17-70mm F2.8-4 DC Macro OS HSM | C
