Problems with Nikon scanner and Mac
Started May 3, 2013 | Questions
Bjoernar Pedersen
Bjoernar Pedersen Regular Member • Posts: 402
I have a Nikon Coolscan V ED (also named Coolscan 50 ED in some countries) which used to work fine with my iMac. (24" w. mountain lion and Vuescan software)
After connecting it to a new Imac (27" with same software) I can´t communicate with it anymore. It is not seen i Vuescan, and not seen in as a USB device either. Same problem when I connect to the old Imac as well, and even to an Mac mini with OS x 10.6.
I have tried with 2 different USB-cables as well, and one of them is tested to work fine when connected to a USB printer.
To me it sound like a hardware problem with the scanner, but maybe there are other options?
Is there a way to check the scanner for hardware failure without sending it for repair?
Bjoernar
Daniel Bliss
Daniel Bliss Senior Member • Posts: 1,794
Re: Problems with Nikon scanner and Mac
I have the same scanner at work though I haven't used it in a while.  I check Monday to see if it works, and get back here.
Daniel Bliss
just occurred to me . . .
perhaps something with USB 3 -- maybe the power the cable carries, or just maybe something in firmware -- disagrees with the scanner.  Have you tried running it through a USB 2 hub?
rgolub
rgolub Senior Member • Posts: 2,061
1)  Are you running the newest version of VueScan?  Had a similar problem on an older MacPro under 10.7.3 - the newest version works fine.
2)  Check ports, don't run from a hub (just typical USB troubleshooting), change cables.
RG
www.lostrange.com
 rgolub's gear list:rgolub's gear list
Nikon D700 Nikon D4 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +12 more
TheDanS
TheDanS Forum Member • Posts: 55
Remember with Vuescan the scanner has to be hooked up and powered on before opening the software. If not, Vuescan wont see it and install a compatible driver. The fact it now wont work on your old imac or a mini leads me to believe bad usb cable, or it needs sent in for repair.
 TheDanS's gear list:TheDanS's gear list
Fujifilm FinePix X100 Canon EOS 7D Olympus PEN E-P3 Sony a6000 Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
