Can't delete Aperture trash, any ideas?
Started May 3, 2013 | Questions
increments Regular Member • Posts: 278
Hi,
I recently began the process of upgrading my 2009 Macbook Pro to Mountain Lion.
Step 1 was install Snow Leopard and update apps to the latest versions supported. i thought that had all gone reassuringly well...
OS and Aperture both working as well as with Leopard or a bit better.
Today though, I finished working on my latest project and tried to delete the photos in the Aperture trash. Unfortunately, when I select "empty Aperture Trash" nothing happens. The usual dialogue box doesn't even appear.
I've tried repairing and rebuilding Aperture libraries/permissions, as well as doing the same for my hard disk.
No joy.
I've looked on the apple support pages and have seen this happen to a few others, who have ended up doing clean installs.
If anyone has any ideas that would avoid having to do a clean OS install, I'd be very grateful.
Derek
Jacques Cornell
Jacques Cornell Veteran Member • Posts: 6,345
Drive permissions, new library
increments wrote:
Hi,
No joy.
Derek
Using Aperture since v1.0, I've never seen this, but here's a thought. If the photos are referenced and kept on an external hard drive, you might select the drive, hit command-I (Get Info), and make sure the "Ignore ownership on this volume" box is checked.
If that doesn't work, try making a new, empty library, then importing the problem library into it. This has helped me once or twice with corrupted libraries.
'No matter where you go, there you are.'
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +27 more
Sonyshine
Sonyshine Senior Member • Posts: 7,832
Re: Drive permissions, new library
Its easy to use something like Clean My Mac to get rid of old aperture and iphoto trash.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
increments OP Regular Member • Posts: 278
Thanks for your suggestions Majikthize.
Unfortunately no joy so far. I think I'll see what happens when I get Mountain Lion in a couple of weeks.
In case this sheds any light on light on the matter, this is the most comprehensive support discussion on the Apple Support pages
https://discussions.apple.com/thread/3715309?start=0&tstart=0
Thanks again for trying.
Derek
Thanks Sonyshine,
If upgrading to Mountain Lion (in a couple of weeks) doesn't fix it, then I'll give it a go.
Derek
Thanks all for your input.
For the sake of tidiness, the problem resolved itself when I updated from Snow Leopard to Mountain Lion.
I take this to mean that the problem was within the system files rather than a problem with Aperture itself.
Derek
