Fixing a stiff aperture and focus ring on pentax-a 50mm 1.7 ??
Started May 3, 2013 | Discussions
Louno Regular Member • Posts: 101
Hi,
I got a legacy lens for my sony nex-3n, the lens is in good condition everything is clean inside... BUT the focus and aperture rings are somewhat stiff, its still very useable, but when i'm trying to really focus precisely it can be a bit annoying.
Going from around f4 to f.17 it gets progressively harder to precisely turn the aperture ring. Same for the focus ring, it is smooth most of the time except towards the end when there is more friction...
Can I try to put a tiny bit of lube in between the rings? I have some lube called Tri-Flow , it's clear colored. I also have some WD-40 ... I was thinking maybe using like a dental floss string and dip it in lube and then pass the string in between the rings ?... i dunno... obviously im a total noob
 Louno's gear list:Louno's gear list
Sony Alpha NEX-3N Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +1 more
Sony Alpha NEX-3N
lenshoarder Contributing Member • Posts: 609
Re: Fixing a stiff aperture and focus ring on pentax-a 50mm 1.7 ??
Don't even think about it. A light oil like that is going to evaporate and haze up your lenses. Then you'll have to take it apart for a proper cleaning. So why not do that now? The grease has probably dried out. It's not worth paying to get CLA'd so open it up and clean everything out then relube it. Get some decent lube and you'll be set.
