Best camera $200 or under?
Started May 2, 2013 | Discussions
GatorDeb1
New MemberPosts: 4
May 2, 2013
In order of importance:
* 1080p HD recording a MUST
* Image quality
* Low light quality
* Battery life
$200 firm. Just want to get the most bang for the buck.
Thanks!
AlbertInFrance
Senior MemberPosts: 4,586Gear list
Re: Best camera $200 or under?
In reply to GatorDeb1, May 2, 2013
What are you going to point it at?
Albert
Every photograph is an abstraction from reality.
 AlbertInFrance's gear list:AlbertInFrance's gear list
Canon PowerShot G15 Fujifilm X-T1 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Draek
Senior MemberPosts: 2,028Gear list
Dunno; none, probably. All the decent sub-$200 cameras I know, like the Powershot A1400 or Sony H90, are limited to 720p by virtue of their CCD sensors.
Perhaps you'd share some models you've been researching thus far?
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Canon PowerShot A1200 Samsung TL500 Sony Alpha DSLR-A390
lenshoarder
Contributing MemberPosts: 609
If IQ is of import, get a mirrorless.  You can find Pentax Qs, and older M43 cameras in that range.  If you are OK with use, GF2 + 14-42mm kits can be had for $100+.
GatorDeb1
New MemberPosts: 4
In reply to GatorDeb1, May 3, 2013
It's to take pictures of a trip.
So far I like:
Canon PowerShot SX260 HS
Panasonic Lumix SZ7
Canon PowerShot ELPH 330 HS
Nikon COOLPIX P310
Cosmo Not
Junior MemberPosts: 28
Spend a little more, get much more. $288 for a k-01 on amazon. http://www.amazon.com/gp/aw/d/B0076396OA/ref=mp_s_a_1?qid=1367591856&sr=8-1&pi=SL75 . There are many inexpensive lenses available, and the k-01 IQ is on par with $1000 DSLRs. It also has focus peaking. Best bang for the buck there is right now.
Cosmo Not
In reply to Cosmo Not, May 3, 2013
Correction: there is a yellow one for $249.
GatorDeb1
New MemberPosts: 4
That's for the body only, i.e. almost $100 more and unusable.
Bouldergramp
Regular MemberPosts: 321Gear list
 Bouldergramp's gear list:Bouldergramp's gear list
Samsung EX2F +3 more
Cailean Gallimore
Veteran MemberPosts: 6,082
On a very tight budget like yours, I would consider second-hand or refurbished.
Cy Cheze
Best camera $200 camera = discounted $350 camera from prior year
Look for 2012 models that are being discounted to make room for 2013 replacements.  Some prices may indeed fall by close to 50%.  Some will offer decent features, including the video resolution you want, but just about all will have 1/2.3" sensors that struggle in low light.  Look for one with a wide-end aperture faster than F/3.5.  If you find a model with an aperture wider than F/2.8 it should shoot better in low light than others, though nothing spectacular.
These days, many people would simply use $200 to upgrade their phone.
GeraldW
Veteran MemberPosts: 6,843Gear list
Re: reply to GatorDeb
Out of that group, I can personally recommend the SX260HS.  Remarkably good image quality, even at ISO 1600.
The rear LCD is usable in full sun if you take your sunglasses off.
I set mine to Program, turned iContrast to Auto, set ISO to Auto, and in the My Colors menu, went to Custom and set sharpening to +1.  Excellent results.
I have the older S90 as well, and compared the two on indoor shots at 100 mm (equivalent) where both have an f/4.9 aperture, and ISO 1600.  The SX260HS was noticeably cleaner looking with less noise and without the S90's yellow blotches.  The S90 is a little older now; but has a larger sensor with fewer pixels which should give it an edge over the smaller sensor in the SX230HS.  Apparently, the advances in sensors and processing have more than made up for that advantage.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot G15 Panasonic Lumix DMC-FZ1000 Canon PowerShot S95 Canon PowerShot ELPH 330 HS Canon PowerShot SX50 HS +1 more
Dr Hal
Contributing MemberPosts: 941Gear list
In reply to AlbertInFrance, May 3, 2013
In order to purchase the BEST camera $200.00 or under, one would have to buy a refurbished or used camera.  The best thing to do is keep checking on ebay and also the used forum here.  What is one person's BEST cameras is not another's.  It is all relative, however you will be able to purchase a GOOD camera if you shop carefully.
Hal
 Dr Hal's gear list:Dr Hal's gear list
Sigma dp2 Quattro Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH2 Panasonic Leica Summilux DG 25mm F1.4 +5 more
brianj
Forum ProPosts: 14,657Gear list
In reply to GeraldW, May 3, 2013
I agree with this, I bought a SX260 for $AU200 and have been pleasantly surprised by its ability.
To GeraldW:  I agree with the settings you recommend, but mine are IContrast=ON and also set My Colors contrast to +1 and use Centre Average Metering and EV=-.3 as defaults.  There is a wonderful sweet spot achieved then with vibrant colors and very little highlight clipping which I have not been able to better.
My SX260 album: http://www.dpreview.com/galleries/5128303546/albums/sx260hs
Brian
 brianj's gear list:brianj's gear list
003tvd
Contributing MemberPosts: 877
Re: Best camera $200 camera = discounted $350 camera from prior year
In reply to Cy Cheze, May 3, 2013
I'm seeing new Nikon P310's for $199 CDN. It's well built, and has an f1.8 lens. Not as much zoom as some others. Has been replaced, so maybe there's good deals to be had.
OpticsEngineer
Senior MemberPosts: 4,201Gear list
In reply to GeraldW, May 4, 2013
I agree SX260.  Available as factory refurbished on the Canon web site for $209.
to get there, I usually google "Canon camera factory refurbished"
 OpticsEngineer's gear list:OpticsEngineer's gear list
Olympus XZ-2 iHS Fujifilm XF1 Canon PowerShot G7 X Olympus Tough TG-4 Sony SLT-A65 +21 more
GatorDeb1
New MemberPosts: 4
In reply to GatorDeb1, May 10, 2013
I ended up going with the Panasonic Lumix DMC-ZS15 for $170.
DaveOl
Senior MemberPosts: 2,858Gear list
Even though it's too late since you just bought a camera, Cameta sells refurb Nikon One J 1's for
$ 209.  I'm not sure about what the video is.  That includes the 10-30mm kit lens.
 DaveOl's gear list:DaveOl's gear list
Nikon D300S
