Do I really need prime portrait lens?
Started May 2, 2013 | Discussions
Tepacca Contributing Member • Posts: 722
I have Nikon 70-200mm f4 VR
Will primes like Nikon 105mm DC or Nikon 85mm 1.4 produce a much better results for portraits? I do not think these would be sharper but will bokeh be that different to justify buyung a new lens?
 Tepacca's gear list:Tepacca's gear list
Fujifilm X-T1 Fujifilm X-M1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Boschje Contributing Member • Posts: 667
Re: Do I really need prime portrait lens?
It all comes down what your own "demands" are but in my case: Yes you need a dedicated prime lens, I have the 85 F/1.4 myself.
RichyjV
RichyjV Contributing Member • Posts: 751
It depends where you shoot your portraits. If you are always lit well in a studio then you wouldn't really *need* a prime, you are right that your 70-200 f4 is a very sharp lens so it depends on light and your output. Some people prefer zooms even in studio shooting. However if you are ever shooting in low light then a prime would be vastly superior; it doesn't have to be f1.4: f1.8 or f2 is fine as well. So does an 85mm 1.4 take *better* shots than the 70-200f4? well yes it does by a (smallish) margin at 85mm, if you check your metadata and find of your last 10000 shots that many were around 85mm then that would seem like a sensible move. For me, mine are all over the place in focal length (but I do use primes too), so it all depends on what you are shooting and where and what effect you want. There is no such thing as a perfect portrait focal length, its whatever you can make work.
These are great lenses you are talking about, but people were taking great portrait shots years before any of these were around, so (if the fast-for-low-light isn't a dealbreaker) the main limiting factor as always is the photographer.
slimandy Forum Pro • Posts: 16,389
No you don't need one.
But you would be better off with one.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Fujifilm X-T1 Fujifilm X-E1 Nikon D700 Nikon D200
Bjorn_L
Bjorn_L Veteran Member • Posts: 5,769
As the others have said only you can answer the question on what you need since it will be your money you send to address this.
That said, I wold find an f/4 lens to be too slow for my only portrait option.  I have a 70-200 f/2-8 which is my main portrait lens and an 85mm f/1.8 as well.  Which one I use depends on what my goals are.  For me, I find 100-200mm range at f/2.8 to most often give me the look I am after.  Most of the time I go to 200mm since that gives me better subject isolation.  Consider a 1.8g lens as they are not very expensive and so you risk less if you end up not using it as much.
See my plan (in my profile) for what I shoot with. See my gallery for images I find amusing.
 Bjorn_L's gear list:Bjorn_L's gear list
Canon PowerShot SX30 IS Sony Cyber-shot DSC-RX10 Nikon D700 Panasonic Lumix DMC-GH3 Nikon D750 +19 more
LCohen777 Forum Member • Posts: 86
Yes, primes are better.  The 105mm DC is tack sharp with great bokeh and built like a tank.
Cytokine Contributing Member • Posts: 661
I think in your situation I would either:
a) upgrade to the 70-200 VR f2.8.
b) Enjoy the lightness of the f4, which will have pretty good bokeh at the long end, and buy a used 85mm 1.4D  or a new 1.8G. .....When you can afford it go for the 200mm macro, this allows you to be further away from the subject and stop you blocking out light, and scaring off small creatures.
The 85 1.4d seems to come with a free impressionist painter that creates the most amazing backgrounds and bokeh, that will surprise and delight you.
Don't be talked into some brand that cost $300. The raw glass in the Nikon cost more than that before it was ground polished and coated. The Sigma 85 1.4 looks good on paper but it is an optical design closer to the canon 1.2L Mk2  which costs over $2000 done properly and is good, but the Sigma looks horrible on the samples I have seen. (too harsh).
I think one of the Nikon 85 1.4's will teach you allot about depth of field, and amazing blur and bokeh, and allow great portraits and just about anything else.
Here is a hand held snap shot of some flowers in windy conditions taken hand-held in failing light.
The 85's are so much fun! and will open a new world of photography to enjoy.
John
Nikon 85mm 1.4D @ f2.8
Art Jacks Senior Member • Posts: 2,196
I may be out of step but I  describe my lens by their focal length rather than the popular perception of what the should be used for, if the shot requires a 85 I will use the 85 no matter what the subject is, I do not approach a shot with the ' I am taking a portrait therefore I need to fit a telephoto lens etc ' I am fortunate to own ( as an amateur ) the 85 1.4 G Nikon lens, this lens I find is used for many of my landscape images, my 35 1.4 G is often used for workplace type portrait  shots, both are producing stunning technical quality images, the artistic quality is open to discussion
Tepacca OP Contributing Member • Posts: 722
I agree with you that these 2 primes will allow to make grate pictures in terms if IQ. But my question was whether one with 70-200 f4 zoom will feel the beed for 85mm 1.8 (or 1.4)z
Do you have such a zoom?
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,599
It depends - partly on whether or not you can afford an extra specialist portrait lens.
The 70-200 f4 has comfortably better image magnification in close focus and excellent wide open f4 optical quality particularly at 200mm.
Nikon's MTF show the 105 DC as quite sharp wide open and somewhat lacking on fine detail rendition, which can help with skin past it's best. The DC enables you to soften foreground, or background, or the entire image (but not at apertures smaller than f5.6) using the DC function.
The 85mm f1.4 wide open is similar to the 105 DC except the corners fall off a bit at f1.4.
You do not have depth of field options wider than f4 with the zoom, but it has VR.
Nikon, unlike Canon, do not give f8 figures to help with comparisons at the same aperture.
If you can afford "the best of both worlds" you should have two lenses.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Skytalker
Skytalker Forum Member • Posts: 74
I have both the 85 1.4D and the 70-200 F/2.8. I found I mostly shoot portrait with the 70-200 since it pleases me more. The focal length I like is 150-200mm.
The statement that one would need a prime for a potrait is obsolete.
Try to shoot with your 70-200 f/4 and have a look at the results. If not happy you can always buy a 85 f/1.8.
website: www.jkovacsphotography.com
 Skytalker's gear list:Skytalker's gear list
Nikon D300 Nikon D3 Nikon D4 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +9 more
JVPhotography Regular Member • Posts: 261
Yes, the 105 DC renders tone, skin, sharpness, bokeh differently than anything else. It's a special lens.
If you can deal with the focus, (+20 af tune ) it will likely be one of those lenses you never sell. I won't sell mine until I can't shoot anymore. The images it renders are so lovely, there is nothing you can buy to trade up but there are a lot of lenses you can buy to trade down.
QWK SVT Forum Member • Posts: 58
The zoom will never open up more than F4, and the prime will never cover the range of the zoom...  Different tools, for different results.  The prime is also far less conspicuous; less intimidating for many not used to a large lens pointed at them...
Personally, I have the 70-200VR2, and still use the prime ALL the time.  In fact, my sigma 85 F/1.4 is virtually always attached to one body, or another.  I sue the 70-200 for moving targets, or events...  The 85 for anytime I can get my subect to hold still for a couple seconds.  When you want to really narrow your focus to just the sujects, eyes, nothing else will do (this was wide open on a D700)!
