Leica M (240) sensor fault?
Started May 1, 2013 | Discussions
DutchmanPieter2003 Regular Member • Posts: 205
After 200 photos taken with my new Leica M type 240 a small stripe over the length of the photo appeared. What can it be? A software fault, a sensor fault? i am disappointed.
In this photo you can see this phenomn. I will send the camera to Leica and i hope they can fix it.
http://www.flickr.com/photos/25963972@N03/8698815677/sizes/o/in/photostream/
 DutchmanPieter2003's gear list:DutchmanPieter2003's gear list
Leica M Typ 240
Daedalus2000
Daedalus2000 Veteran Member • Posts: 6,261
Re: Leica M (240) sensor fault?
It looks like a sensor problem, but I am not sure. I find it strange that it goes down at an angle.... Did you check the sensor for any hair on it? Also, did you try to clean it?
Prosophos had a similar problem with his first MM
http://prosophos.com/2013/02/23/leica-monochrom-test-shot-surprises/
but yours looks to have a stronger effect...
Unless of course, you did not followed bosjohn's experience and you were having spaghetti while you were changing lenses:
http://www.dpreview.com/forums/post/51374808
Sorry, I make a joke, I just try to make you feel better. Leica will fix it and all will be good soon again.
Best, D
DutchmanPieter2003 OP Regular Member • Posts: 205
It is a straight line but because i rotated the horizon a little i introduced an angle, sorry i should have mention it. Yes it is possible that by cleaning the sensor at camtech, the repair center of Leica in Holland i got this on the sensor, because before that i had some dust on the sensor when received the camera for the first time. By the way i never clean my sensors by myself i always let it done by professionals. Thank you for your fast answer. I really appreciate it.
Leica M Typ 240
Leica M Typ 240
Daedalus2000
Another example: http://www.flickr.com/photos/25963972@N03/8698998085/sizes/o/in/photostream/
I am not an expert but if it is straight it means it is unlikely to be something external on the sensor, so it must be a sensor issue.
A bit unlucky, but at least you know that Leica will take care of it, so do not worry.
Let us know know how it goes and I am sure more knowledgeable people here will give you more feedback.
D
Artichoke
Artichoke Forum Pro • Posts: 12,053
maybe its not the sensor
similar issues have happened with the M9/M8 due to writing the file to the card
try changing cards & see if the problem persists before shipping it off
pbase & dpreview supporter
DPR forum member since 5/2001
my PBase Galleries
"Avoid making a commotion, just as you wouldn’t stir up the water before fishing. Don’t use a flash out of respect for the natural lighting, even when there isn’t any. If these rules aren’t followed, the photographer becomes unbearably obtrusive" -- attributed to HCB
 Artichoke's gear list:Artichoke's gear list
Agfa ePhoto 1680 Fujifilm FinePix S3 Pro Leica M8 Nikon D3X Leica M9 +12 more
Re: maybe its not the sensor
Yes i did that. I tried several cards and still the same result.
Leica M Typ 240
Adam Moore
Adam Moore New Member • Posts: 11
My New M240 has a faulty vertical line of 280 pixels to the lower left from the center. It is noticeable on every image to different degrees. I have also had to send my new 50mm Summilux ASPH back as I noticed it was out two minutes after putting it on my M240. I am very disappointed at the moment as they were both obvious faults. I range Leica service in Germany, they didn't seem surprised or offer any apology, and simple told me to send it in and the would re-map the sensor. I don't know if I am happy with this. The test certificates that that came with the items obviously don't mean a thing, who knows after a few weeks of being without my brand new camera and lens they will come back any better. The thing that they can't repair is my feeling of disappointment that Leica name no longer represents the precision and quality I believed it once did.
It sad that I had aspired and saved so long for what was to be my ultimate camera outfit, and now I am considering selling it as soon as it returns from Leica.
 Adam Moore's gear list:Adam Moore's gear list
Sigma DP2 Merrill Fujifilm X100S Ricoh GR Sony Alpha NEX-C3 Sony Alpha 7R +14 more
(unknown member) Senior Member • Posts: 2,216
A bit unfair on Leica...
Adam Jason Moore
http://adamjasonmoore.com
In the old days every component in a Leica was manufactured under their strict control; but now they must rely on third-party electronic components of immense complexity like the sensor and processor.  Like most electronic components, these are extremely reliable, but the nature of the manufacturing process means that there will be a few failures early in the components' lifetime (the "bathtub" curve).  If you sit down and think about the complexity of a 24MP sensor it is truly mind-boggling: there are 24 million complex little electronic circuits in there - 24 million - all with power lines, control lines, and signal lines connecting them.  It's just the nature of modern integrated electronics - nothing to do with some Leica dropping the ball on quality...
J.
 Joe Pineapples's gear list:Joe Pineapples's gear list
Ricoh GR
BSweeney
BSweeney Contributing Member • Posts: 903
In CCD based sensors, this could be the result of a bad pixel and shifting others across it.
CMOS- if I were to guess, it could be bad memory, bad memory address line, something that requires accessing memory that ends up "in a bad place". FIRST: try a different brand SD card, one with a small size. Stick to an 8GByte card with 10x or slower speed. IF the problem persists no matter what SD card is used, Send the camera in for repair, this is an electronics problem.
 BSweeney's gear list:BSweeney's gear list
Leica M8 Nikon D1 Nikon D1X Leica M9 Olympus PEN E-P2 +5 more
oanne Puyat New Member • Posts: 1
I was just wondering how you were able to resolve your problem with the Leica M (240) sensor? I am having the same problem.
