prosumer camcorders - sony vs canon autofocus
Started May 1, 2013 | Discussions
polarizer
Contributing MemberPosts: 840Gear list
May 1, 2013
which camcorders are better at following sports action in auto focus mode?
thanks for your help
 polarizer's gear list:polarizer's gear list
Nikon Coolpix A Sony Cyber-shot DSC-RX10 Sony Alpha 7 Sony FE 55mm F1.8 Sony FE 28mm F2
Cy Cheze
Senior MemberPosts: 2,028
Re: prosumer camcorders - sony vs canon autofocus
In reply to polarizer, May 1, 2013
There is no generic difference between one brand and another in terms of the quality of action video you get.  The difference is in how you are tracking the action and what the action is.
If you try to shoot tightly cropped shots of athletes bounding about a field, the task is hopeless if you are holding the camera by hand, have no idea what direction the action will take, can't see the LED under the bright sun, or can't see the ball or small details in the tiny EVF.  The result will be very shakey and unwatchable, no matter how good or bad the AF.
Generally, camcorder AF is reliable across most better brands, if you have good light and shoot at a relatively wide angle.  The results are less reliable if the light levels are low, if you are shooting in zoom, or if the camera's AF gets confused by objects closer to or farther from the one you want in focus.   Theoretically, expert manual focus would solve everything, except that good focus is hard to "pull" on the fly in a fast moving, spontaneous event you can't re-take.  Focus assist or fringing tools are hard to operate or adjust while the players dash to and fro, in and out of the focus plain.  Most action video must, therefore, be shot with relatively deep focus.  POV video of sports events or extreme stunts typically uses very wide angle, fixed focus, and zero manual control.
polarizer
In reply to Cy Cheze, May 1, 2013
thank you
hopefully the larger DOF will be better than my m43 - tripod and don't zoom in too much - got it!
pj650v for $1050, G20 for $900 or x920 for $1000 will all have similar AF?
lancespring
Veteran MemberPosts: 3,403Gear list
In reply to polarizer, May 2, 2013
All 3 of those camcorders have an autofocus tracking feature.  Just enable it, and then touch your subject on the LCD.   The camera will then track the subject as he moves and stay focused on him.
It works quite well with my Canon Vixia HF G10.   As far as whether one brand has an advantage over the other, who knows?  I don't know if anyone has ever done such a comparison.
 lancespring's gear list:lancespring's gear list
Sony Cyber-shot DSC-RX10 Nikon D600 Tamron SP 24-70mm F2.8 Di VC USD +1 more
