How to create mat/double mat as a template?
Started May 1, 2013 | Discussions
andyus08 Regular Member • Posts: 241
Hi,
I'd like to create a mat/double mat and put it in a template or something so that i can just add/attach picture to.  What i mean is that i have a bunch of 12x18 pictures and it will be time consuming if i do mat/frame for every single pic.
Any tutorial, video , or link would be greatly appreciated.
Thanks.
JJMacks
JJMacks Forum Pro • Posts: 10,288
Re: How to create mat/double mat as a template?
Try action central there are many framing and mating action there
JJMack
 JJMacks's gear list:JJMacks's gear list
Canon EOS-1D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/2.8L IS USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS USM +3 more
drh681
drh681 Forum Pro • Posts: 16,819
What about this...
Photograph some mats and save the images as .psd files.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
You got a camera, now go out and get a life; or at least a picture of one!
 drh681's gear list:drh681's gear list
Nokia Lumia Icon
ericN2
ericN2 Forum Pro • Posts: 16,509
If it can be assumed that all the pics you want to Frame this way are the same size to start with, it seems a good and easy solution would be to make an Action..or if necessary find an Action that gives the Frame you want, then adjust it if necessary for the dimensions you want .. then just make sure that all the pics you want to Frame are in one folder and do a Batch Action on each pic - using the pre-set Frame Action..  ??
Apart from a Frame Action of various types/styles I also have and use sometimes a rather nice Frame SCRIPT that is loaded into my CS and with which you can very easily do a big variety of Frames to suit any pic you choose.  MAY be a little bit less easy to run on a Batch (never tried it that way) but it's excellent to produce a varied Frame in sizes and color ..  sample here ..
Drop Shadows and Bevels can be chosen if you wish to have the Frame with those ...
/eric
Staffordshire, UK
PaulinDE Regular Member • Posts: 302
I have an action for CS6 which creates a double mat as shown below.  Should you be interested, drop me a private message, will gladly share.
Paul
 PaulinDE's gear list:PaulinDE's gear list
Nikon D300 Nikon D810 Sigma 50-500mm F4.5-6.3 DG OS HSM Epson Stylus Pro 3880 Adobe Photoshop CS6 extended +2 more
andyus08 OP Regular Member • Posts: 241
Hi PaulinDE,
Sorry it took a while to get back forum. And yes, i'd like to have action if you can share. It looks really nice and similar to what i'm looking for even though i just need a single mat.
thanks.
Thomas Niemann Veteran Member • Posts: 4,335
Here you go...
An action for a double matte can be downloaded from the Introduction page at this site.
Roger Roberts
Roger Roberts Junior Member • Posts: 48
Re: Here you go...
Wow, thanks a lot, a very good site and actions.
VicC Senior Member • Posts: 1,557
Thomas
Hi there, nice site many thanks. Vic
Doug R Senior Member • Posts: 1,471
