"Personal item"-sized bag for OM-D + DP2M + iPad + phone + chargers?
Started May 1, 2013 | Questions
curiouspeter New Member • Posts: 23
I am shopping for a personal-item-sized travel bag for my cameras and other electronic gadgets. Here is the challenge...
It must be able to fit:
  1. Olympus OM-D body
  2. 12-50mm kit lens
  3. 45mm f/1.8
  4. Sigma DP2 Merrill with hood
  5. iPad 3
  6. Samsung Galaxy Note phone
  7. Charger for iPad
  8. Charger for Note
  9. Charger for OM-D
  10. Charger for Sigma
  11. Extra batteries for Sigma
Also, the external dimensions should not exceed 15 in by 10 in by 5 in.
Will it be impossible?
I am looking at the Hadley Pro and the Domke F803. Will either of these work? Any other options?
Thanks!
Sigma DP2 Sigma DP2 Merrill
Bobby Handal
Bobby Handal Veteran Member • Posts: 5,450
Re: "Personal item"-sized bag for OM-D + DP2M + iPad + phone + chargers?
Take a look at the Lowepro Urban photo sling 250, I enjoy mine so much I bought two !!
http://www.lowepro.com/urban-photo-sling
good luck in your quest.
  2. 12-50mm kit lens
  3. 45mm f/1.8
  5. iPad 3
  7. Charger for iPad
  8. Charger for Note
  9. Charger for OM-D
Thanks!
www.photoexpedition.net
www.fotoclubhonduras.com
 Bobby Handal's gear list:Bobby Handal's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-TS3 Sony Cyber-shot DSC-HX400V Ricoh WG-M1 Nikon Coolpix P900 +55 more
Adrian Tung Veteran Member • Posts: 3,052
  2. 12-50mm kit lens
  3. 45mm f/1.8
  5. iPad 3
  7. Charger for iPad
  8. Charger for Note
  9. Charger for OM-D
Thanks!
No experience with the Domke, but the Hadley Pro will definitely fit.
Edit:
To be more specific, the Hadley Pro comes with two vertical dividers and two small horizontal "trapdoor" flaps. The vertical dividers will split your bag into 3 tall sections.
Put the OM-D with one lens mounted in the middle section. You can put chargers in one section, cover them up with a trapdoor flap, then put the 45/1.8 on top of that.
Then put a bunch of other stuff (batteries, etc) in the last section, cover it up with the trapdoor flap, and put the DP2 on top of that.
Ipad fits in the inside of the bag, between your gear and your waist/hip.
Phones and other accessories can populate the two front pockets of the bag.
 Adrian Tung's gear list:Adrian Tung's gear list
Nikon Coolpix A Canon EOS 10D Canon EOS 5D Mark III Sony Alpha 7R Canon EF 35mm f/2.0 +11 more
curiouspeter OP New Member • Posts: 23
Thanks! I will check that out... although it may be a bit too thick.
  2. 12-50mm kit lens
  3. 45mm f/1.8
  5. iPad 3
  7. Charger for iPad
  8. Charger for Note
  9. Charger for OM-D
Thanks!
Edit:
Wow. Thanks for the specific information. It does look like a very nice bag, and it does not scream camera bag.
(unknown member) Veteran Member • Posts: 3,348
Best travel item ever is a vest or jacket from Scottevest.
Almost all of that list would fit in the pockets....and clothing is not subject to weight restrictions!
I never fly without one - if they challenge my carry on weight I simply empty stuff into the Scottevest until it passes, then put it back in later on.
