NEX for Aerial photography
Started Apr 30, 2013 | Discussions
macsoft4 Regular Member • Posts: 159
Hi!
I'm in the market for a Quad RC flying machine to use for shooting video with my NEX 7.
What is the best option that can steadily fly my NEX 7 and not burn a hole in my wallet?
I see lots of DYI solutions, but i would like to go for a ready to fly one.
thanks
Sony Alpha NEX-7
GaryR60 Contributing Member • Posts: 656
Re: NEX for Aerial photography
One that holds up well in a crash.
macsoft4 wrote:
Hi!
thanks
DtEW Senior Member • Posts: 2,167
macsoft4 wrote:
Hi!
thanks
Given how much some quad (and hex) copters cost, the NEX-7 might be one of the cheaper components to be wrecked in such a misfortune.
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Sony a6000 Samyang 14mm F2.8 IF ED MC Aspherical Samyang 24mm f/1.4 ED AS UMC Sony E 50mm F1.8 OSS +17 more
macsoft4 OP Regular Member • Posts: 159
True. they are expensive.
That is why I wanna do my research before I open my wallet.
But they do offer a magnificent point of view for some video shots.
Will be cool to try aerial photography too.
I had a well-heeled friend (a lawyer shooting a Phase One digital back) ask the very same question in reference to a hexcopter.  He was intrigued by the size of my 5N, which I showed could be used with a small, stabilized lens (SEL35F18) without my EVF.
(A fast lens with optical stabilization are probably given pluses.)
I am uncertain if PDAF would be any advantage in this application... but if so, the NEX5R might be worth considering.
The ultimate size/weight combo would be the SEL20F28/SEL16F28 (the latter will have soft corners that might not be relevant for video, but it needs to be noted that the wingsuit guys who flew through the building in Rio used the SEL16F28 w/NEX-5 on a helmet mount) as they are the lightest lenses for E-mount, with an aluminum mount (everything else is brass)... plus a tiny body such as either the 3N or the old C3.  But you give up ISO100 and other features.
The 7 is of course the most massive E-mount body, but that's not to say it's a huge difference.  But if you want wide-angle, the corner color-shifting might be harder to process out for video.  (Somebody else will have to chime in about that.)
kiwicrispin Junior Member • Posts: 36
With NEX-7 Video capture reliability being pretty bad in terms of the overheating issue, I wouldn't go to all the trouble of building/buying this to use it with a NEX camera with video in mind (and I own a NEX-7)......
Well I shoot video a lot with my NEX 7 and never once saw the overheating message.
Also.. you have 4 to 6 powerful "fans" lifting the device.. you don't get better cooling system than that
You know, I totally missed the fact that your original post was asking about a recommendation for a flying machineinstead of a photographic setup for such a flying machine.  Oops.
LOOL my bad.. the title is misleading
Pal2012 Regular Member • Posts: 368
 Pal2012's gear list:Pal2012's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sigma 120-400mm F4.5-5.6 DG OS HSM +4 more
fquails Regular Member • Posts: 170
Post this question on Helifreak.com....there is a section there for Aerial Photography.
That site helped me earn my wings in RC helis....
 fquails's gear list:fquails's gear list
Nikon D200 Nikon D700 Nikon D7000 Sony Alpha NEX-5N Sony Alpha NEX-7 +14 more
originalsauce Forum Member • Posts: 69
does anyone else have problems using an ipad to post replies? Just lost everything I previously wrote.
I dnot own or have first hand experience with a rc drone but I did a fair bit of research into ready to fly ones as I was interested in getting one.
The two I solutions that I came up with included both drones from DJI.
1) DJI Phantom with a GoPro (£800)
2) DJI s800 (£6000)
both products you can get cheaper but these are bundle prices and extra things I wanted. E.g video output through goggles. The return of the drone to 'home' when connection was lost or battery was low was a plus for me.
The one area I spent some time reading up on was how to reduce jello. E.g getting a prop balancer and balancing out the propellers reduced it quite a bit. Certainly for the Phantom which was the initial setup I wanted.
Thanks for the link, But the idea is that it can carry a NEX 7
Yeah, I know but for its low low cost and all that it does, I thought it might be worth considering for you.
kazkioken Contributing Member • Posts: 541
You want to do plenty of research.  But basically this is a pivotal moment in aerial photography with lots of brushless gimbals coming out on the market now and soon.
Visit http://www.rc-drones.com for some quads, hex's and octo's that can carry a NEX.  I prefer to use the RX100 because of it's onboard stabilization and it has slightly cleaner video than my NEX5n or 7.
Here is a great thread with all the brushless gimbals that will be coming out soon:
http://www.rcgroups.com/forums/showthread.php?t=1865315
You will need a quad or hex that can carry the weight of a midsized camera + the gimbal.  A Phantom won't do it you need something with more power and carry capacity.
Also keep an eye out on http://www.tppacks.com the site will get updated soon and they will sell a brushless gimbal for the RX100 and NEX cameras along with the quads, Y6's, etc.
Pivotal, you say?
In terms of the OP's ask for low cost...the cheapest would probably be a used DJI f550 hex (or new or kit) with one if the 2 axis servo gimbals - moving up to brushless would cost bit more
http://www.500px.com/kazkang
