Canon inkjets: maximum paper length
Started Apr 29, 2013 | Discussions
m.holmes Regular Member • Posts: 271
Hi all,
I happen to own several inkjet Canon printers, of various "degrees". I recently tried to print on a paper stripe approximately 150 x 1000mm, but Canon drivers report that the maximum paper length is somewhere above 600mm.
Is there any workaround?
Edwin K Forum Member • Posts: 87
Re: Canon inkjets: maximum paper length
If your printer has a banner printing option, I think Qimage allows printing to any length.  Qimage trial software is available for download so you can see if it works for you before spending $.  You may wish to post your question to the Qimage forum here, http://www.ddisoftware.com/tech/
Good luck.
Ed Knight
Tom-C Senior Member • Posts: 1,160
Your only chance would be to find a RIP that supports longer lengths with your printer.  PrintFab which helps for some Epson printers has the same 23 inch limit for Canon printers.
Tom
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark III
