5D mk I AF points don't illuminate when focusing..
Started Apr 29, 2013 | Questions
ojobson New Member • Posts: 8
In anything other than full auto mode on my newly acquired 5D mk I, the chosen/in-use AF point does not illuminate to show which area of the image is in focus or to show which AF point is in use. On my old 400D, this behaviour was very useful.
When I press the AF-WB button I can select auto AF points or a particular point. The AF points clearly light up red in the view finder when I do this.
In full auto mode the AF points that the camera selects will be illuminated red.
Can anyone shed any light? I've read the manual several times and googled exhaustively, but I can't find an explanation for this. Is this normal for the 5D, is it broken, or am I missing something?
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X) Canon EOS 5D
Jim Cassatt Veteran Member • Posts: 4,851
Re: 5D mk I AF points don't illuminate when focusing..
Could you possibly have it on AI servo focusing mode?  Also check the programming of the * button. If set to lock focus, pressing the shutter button will have no effect.
 Jim Cassatt's gear list:Jim Cassatt's gear list
Fujifilm X10 Canon EOS 40D Canon EOS 300D Canon EOS 5D Mark III Fujifilm X-E1 +18 more
ojobson OP New Member • Posts: 8
I've tried all the AF modes, and the * isn't engaged. When I half press the shutter button the camera beeps and the cicle at the bottom of the view finder illuminates to indicate that AF has focused, but none of the AF points flash to let me know where (or to indicate my manually pre-selected AF point).
It's most odd.
Schwany
Schwany Forum Pro • Posts: 10,055
It's most odd.
Never mind
I've seen this, but I can't remember exactly why it happens, and what results when it happens. Need to check.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EF 24mm f/1.4L II USM +14 more
JLim22 Regular Member • Posts: 495
You're probably in AI Servo mode.
You need to be in One Shot, or AI Focus to get the focus points to lit.
 JLim22's gear list:JLim22's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 35mm F1.4 Zeiss Batis 85mm F1.8
Thanks but unfortunately I've tried them all with the same result. I understand the difference between the modes as it's similar with my 400d. Don't understand why this is happening on the 5.
In fact, even in AI Servo my 400d would still show a red dot in the appropriate spot when using a manually selected AF point. Granted, in auto AF it wouldn't. On the 5D I don't get any AF points illuminating on focus in any mode apart from when running the camera in full auto mode (the green square on the mode dial).
Thanks - I'd really appreciate that as I'm starting to question my sanity now...!
Ok, here are the steps I tried:
Clear all settings. (did this a few times)
Take all the batteries out and leave the camera for a few hours. ('all' meaning the main battery and the backup lithium battery).
Finally, I restored the firmware (I was already on 1.1.1).
The final step did the trick. No idea what was up, but I now have my AF points!
Happy days.
Thanks for your responses, this seems to be a pretty active forum.. I may stick around!
nadley New Member • Posts: 9
You might have set the value of custom function 10 to 1. This will disable the red AF points.
Schwany
I am a failure to communicate
Ha, I'm no bell weather for sanity. Furthermore, I think I'm wrong about it. What I noticed just now trying to duplicate it was that the AF point does not stay lit for more than a fraction of a second. Leaving me wondering if I am actually focused in the right part of the frame.
If you're getting the solid green light, you're probably focused. Maybe you missed the light firing looking somewhere else in the frame for overall composition. That must have been what I was experiencing, because I can't duplicate it any AF mode while paying strict attention to the selected AF point. It always blinks at least once, sometimes twice in AI Focus.
I often can't see the AF point light up shooting motorsports with a 1DMkIV, because I'm concentrating on framing and tracking more than I am concentrating on the AF point. Same with the 5DMkII the one time I used it for anything moving. I just don't notice the AF point lighting up. Excuse my confusion.
If your outer points are really not lighting up at all, either there is something wrong with the camera, you have the AF illumination turned off, or the 5D doesn't work like the 5DMkII.
Thanks - I only just acquired the camera so may have been something the previous owner did; however, having said that I did reset all the custom functions and this did not change anything.
Re: I am a failure to communicate
Yeah, it was odd - the AF points worked fine only in full auto - any other mode and it they didn't do anything. I ended up re-installing the firmware and the AF points are now working as they should be. I have no idea what was causing it to happen though...
Since I couldn't originally find any info on this I just now performed a few searches (cleared browser cache) and managed to find this forum thread on a google search (1st position too) - so anyone else with the same issue should now be able to get resolution. That does make me happy.
Schwany
That's good news
You fixed it, and all is well again. Can't ask for more than that.
