D800 PROBLEM or Im just missing something
Started Apr 28, 2013 | Questions
Photopingwen Junior Member • Posts: 39
Shooting a wedding yesterday on D800 when suddenly shutterspeed was all the same no matter the setting... It sounded COMPLETELY different than it had all day. It sounded like the shutter (mirror) was just flapping up and back down quickly... THEN at the same time... I could not longer get accurate WB???? It was greenish. I am stunned as I have gone through EVERYTHING I know to do to try and fix it... I can't get long exposure NOTHING in the shutter speed changes NO MATTER WHAT I DO!!!
ANNOYED
THANK GOODNESS for back up cameras is what I thought after this happened yesterday.
Photopingwen
Nikon D800
reginalddwight Senior Member • Posts: 2,003
Re: D800 PROBLEM or Im just missing something
ANNOYED
Yes, that's what backup cameras are for.
Fortunately nothing like that has happened to me yet, though it is a concern of mine.
Did you perform a camera reset?
Photopingwen OP Junior Member • Posts: 39
Reset was my first thought... BUT I can't find it????
Photopingwen
Press and hold the QUAL button and + /- bracket button simultaneously for a few seconds.
Good Grief!!! THANK YOU!!! You solved the problem!
Well HALLELUJAH!!!! Good grief thank you !!! FIXED ... And BAM that's why I am a member of these forums.
Photopingwen
Recant... Shutter fixed... GREEN CAST ... STILL there
Photopingwen
AZBlue
AZBlue Contributing Member • Posts: 866
Photopingwen
Would appear to be a hardware issue at this point. Have you tried re-attaching your lens or using a different lens? Do you have the "quiet shutter release" setting enabled? Could something be physically interfering with your camera's shutter mechanism? Sorry to hear.
"I've been in more laps than a napkin" - Mae West
 AZBlue's gear list:AZBlue's gear list
Nikon D800 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 20mm f/2.8D Sigma 150mm F2.8 EX DG OS Macro HSM +1 more
TOF guy MOD Forum Pro • Posts: 12,823
Check WB setting
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +5 more
Robin Casady Forum Pro • Posts: 12,898
Reset and Restore Saved Settings
Just to add a suggestion:
Reset witll wipe out all the menu settings you have made. To save having to redo them all by hand, save them to a CF card that you don't use for anything else.
If you've got an old <8GB card left over from previous cameras, format it in the camera. Set the menus the way you want them, and make sure it all works well. Then save the settings from the Setup Menu.
After a reset you can quickly load these setting and go back to shooting.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
OldDigiman Senior Member • Posts: 1,956
Re: Reset and Restore Saved Settings
And reset will not wipe out all settings, tho I don't know which ones remain unaffected.
___________________
ODM
www.ahfairley.com/gallery/index.html
www.olmstedactupuncture.com
