Play high ISO with 60D indoor.
Started Apr 28, 2013 | Discussions
Jocka
Regular MemberPosts: 124Gear list
Apr 28, 2013
with this ISO level ..this pics are good enough (for me at least).
thanks to 60D
 Jocka's gear list:Jocka's gear list
Canon EOS 60D Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF 70-200mm f/4.0L USM +3 more
Canon EOS 60D
Loose_Canon
Regular MemberPosts: 311Gear list
Re: Play high ISO with 60D indoor.
In reply to Jocka, Apr 28, 2013
What balance is a bit off in the second... anyway, if you photograph in Raw and do some careful noise removal, you can go much higher. Here's one at 5000:
N.
 Loose_Canon's gear list:Loose_Canon's gear list
Fujifilm X100S Canon EOS 6D Canon EF 50mm f/1.4 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 24-105mm f/4L IS USM
Jocka
Jocka OP
In reply to Loose_Canon, Apr 28, 2013
thanks for response
at that time i just tried shot in jpeg and see what's the result, and no any pp for all pics.
for the 2nd yes i could not change the wb in dpp since it's jpg. . .  :).
Loose_Canon
I use lightroom, not DPP, but many programs let you play with the white balance of jpegs too, even Picasa. I'm relatively new to the Raw world and only purchased lightroom a few months ago (worth every penny!)... I did basic manipulations on jpegs for years, but I didn't go above about 3200 ISO. The results using Raw with 5000 ISO amazed me.
N.
Jocka
Jocka OP
Hi
many thanks for sharing.
the last one i push until 6400, and still OK for me.
Jocka
skanter
Veteran MemberPosts: 9,653Gear list
N.
Nice ! What do you use for NR?
Sam K., NYC
 skanter's gear list:skanter's gear list
Adobe Photoshop Lightroom 5 Canon EOS 70D Sony a6000 Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM +10 more
Ed Rizk
Senior MemberPosts: 1,740Gear list
In reply to skanter, Apr 28, 2013
skanter wrote:
N.
Sam K., NYC
Same question from me.  I don't get very clean shots above 3200 with Aperture.  I feel a very painful software change coming on.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 60D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS II
Y0GI
Veteran MemberPosts: 5,228Gear list
In reply to Jocka, Apr 29, 2013
Jocka wrote:
thanks for response
You CAN adjust WB in DPP!  Here's the instructions copied and pasted from the DPP help file:
When there are no white areas in your image, you can adjust the white balance by clicking on a grey point of the image in step 2. This has the same adjustment result as selecting a white point.
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Flying Fish
Veteran MemberPosts: 4,467Gear list
adjusting wb of jpegs
Those are nice.  I've had similar results with my T2i.  You can adjust wb in jpegs, but not directly as far as I know.  You do it by adjusting the color balance using the RBG scale.  Canon's free software will do that and it's quite effective and quite easy to use.
FF
 Flying Fish's gear list:Flying Fish's gear list
Canon EOS 7D Canon EOS 550D Canon EOS 6D Canon EOS 7D Mark II Canon EF 400mm f/5.6L USM +3 more
Jocka
Jocka OP
In reply to Y0GI, May 2, 2013
Adjusting Color Tone Using Click White Balance When there are no white areas in your image
Y0GI wrote:
Jocka wrote:
thanks for response
  1. Click the [ ] ("Eyedropper") button.
    • When you move the cursor over the image, the cursor  changes to [ ] ("Eyedropper") .
  2. Click on a point that is to be the standard for white.
    • The color of the image is adjusted with the point you selected as the standard for white.
    • If you click on another point in the image, the white balance is adjusted again.
    • To finish click white balance, right-click with the mouse or click the [ ] ("Eyedropper")   button again.
You can adjust white balance using a selected part of an image as the standard for white to make the image appear natural. Using click white balance is effective when using it in parts of an image where white color tone has changed under the influence of a light source.
  • The coordinates of the cursor position and the RGB values (8-bit conversion) of the image are displayed in the lower-left of the window.
  • The image is adjusted based on the average value of 5 x 5 pixel range from the clicked point.
  • The histogram display changes according to adjustment. You can also fix the histogram display to the display before any adjustments. (Tool Palette)
Yogi
dear FF & Yogi, many thanks for your sharing...i'll try it. btw thanks to this forum too .
