Epson Printer - changing print size
Started Apr 27, 2013 | Questions
davwilso
New MemberPosts: 1
Apr 27, 2013
I have an epson stylus photo R1900 printer. I'm trying to change the print size from 8 x 10 to 11 x 14 but I keep getting 8 x 10 prints. I'm using lightroom 4.3 print function.
Chris R-UK
Forum ProPosts: 14,812Gear list
Wrong paper size?
In reply to davwilso, Apr 28, 2013
You may have the wrong paper size set in the printer driver.
In LR go into the print module and click on Page Setup at the bottom left and check that you have the right paper size set.  Changing the page size here should change it everywhere else but just to make sure click on "Properties" and check that the right page size is set there as well.
If the page size is big enough you should now be able to set your print size to 11x14.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
