Other NX300 owners, question about touch sensitivity
Started Apr 27, 2013 | Discussions
chrisrabe
Regular MemberPosts: 425Gear list
Apr 27, 2013
With regards to responsiveness of touch screen, do you find yourself having to frequently tap the screen several times to get it to respond?
I am still sure on the first camera (that got returned for garbled screen), the screen was far more responsive.
While things generally feel a bit more responsive since the firmware update, I still find myself typically having to tap the screen a couple of times to get it to respond.
 chrisrabe's gear list:chrisrabe's gear list
Sony a6000 Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony FE 70-200 F4 +2 more
Samsung NX300
tecnoworld
Veteran MemberPosts: 6,261Gear list
Re: Other NX300 owners, question about touch sensitivity
In reply to chrisrabe, Apr 27, 2013
I tested two samples, one was much more sensitive than the other.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
chrisrabe
In reply to tecnoworld, Apr 27, 2013
Thanks. Glad to know someone has had the same issue.
Now just not sure if I should return it... it is quite frustrating. The touch screen is something that could be awesome, and find myself often trying to use, but I just get so darn annoyed having to tap the screen several times.
jeffsvisions
Senior MemberPosts: 1,467Gear list
as per all the reviews i have read they say the touch sensitivity is very light and you can do it by accident just by letting you finger come in contact with the screen.
The best picture is the one you take.
Jeff
 jeffsvisions's gear list:jeffsvisions's gear list
Fujifilm X10 Fujifilm X-S1 +2 more
tecnoworld
I'd suggest you to go and try another sample, so to compare directly!
viking79
Forum ProPosts: 14,104Gear list
Nope one touch.  Too sensitive sometimes.  It is capacitive though so pushing harder won't help.  If you have trouble you could just test it with some lotion for ESD (Electrostatic discharge), maybe even regular lotion would help (just to test).  Some people's hands don't work great with capacitive screens if they are overly dry or something.
That is interesting, maybe something is up?  Also realize there are times when the touch screen is locked out (like just after taking a shot).  If the first one worked better it could be a sample difference, but that seems to be a lot of variation.
Mine triggers a split second before I touch it.  Also I don't think it is a multi touch screen, so if your hand is resting up against the side it could block out a press somewhere else, so make sure only one finger is on the screen.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
viking79
In reply to viking79, Apr 27, 2013
I was just out tonight and did exactly what I said, I had my palm supporting the camera in the lower left portion of the screen and it was blocking the touch screen from working even though it wasn't doing anything else.  So double check you don't have another hand touching the screen somewhere
Eric
Raf007
Regular MemberPosts: 178
In reply to chrisrabe, Apr 29, 2013
My NX300 is responsive, I never had to tap the screen several times. Apart that it locked up three or four times and I had to switch the camera off/on I have no complains.
After reading posts about problems with NX300 it seems that Samsung has some problems with the quality control.
chrisrabe
In reply to Raf007, Apr 29, 2013
I think most of those posts are from me
I updated the firmware again the other day, and it seems a bit better, but not perfect.
Still can't help but think it's a bit sluggish though.
Maybe I am expecting too much...
