New article on color management
Started Apr 26, 2013 | Discussions
Jeff Schewe
Regular MemberPosts: 400
Re: Camera-->sRGB versus Camera-->ProPhoto-->sRGB
In reply to crames, May 1, 2013
crames wrote:
I'm pretty sure they both should be v4 in order to make use of the perceptual Profile Connection Space.
Actually, the profile connection space has nothing to do with rendering intents...in the case of the sRGB Perceptual profile, the rendering intent is used in the receiving color space. So you can convert from a standard v2 ProPhoto RGB into the v4 sRGB perceptual profile and take advantage of te gamut compression of the perceptual rendering intent. I have it an use it...it's useful for images with highly saturated red and blues.
Jeff Schewe
crames
Regular MemberPosts: 192
In reply to Jeff Schewe, May 1, 2013
Thanks for the info, Jeff. Good to know it works with v2 ProPhoto RGB.
I was thinking of this statement on the ICC's sRGB download page :
"The sRGB v4 ICC preference profile is a v4 replacement for commonly used v2 sRGB profiles. It gives better results in workflows that implement the ICC v4 specification. It is intended to be used in combination with other ICC v4 profiles."
I guess you don't have to use a v4 source profile, but potentially the results are better if you do?
More details here: Using the sRGB_v4_ICC_preference.icc profile
Cliff
Jack Hogan
Veteran MemberPosts: 4,931Gear list
In reply to gollywop, May 1, 2013
gollywop wrote:
As to a choice between the bottom two, each has its value (but there is no question about which is the easier to produce).
Good show Gollywop. This is the link to your flower dng file and this is the accompanying text:
"This file is underexposed about 1EV according to RawDigger.  It was shot with UniWB (hence the greenish tint).  A WhiBal card shot in the same light indicates a WB (for ACR) of 4900/3, and that is what I used for the image as posted.  It is also clear that the image as posted was cropped."
I've been thinking about the wild guesstimates during conversion mentioned earlier, and I've found that they can be really apparent.  Here is an example: note the clipping in the right petal in ProPhoto-->PP-->sRGB compared to sRGB-->PP (I know that GIF's are not ideal, but they make animation simple - hope it works).  Here are the Original TIFFs which are much better for comparison: ProPhoto , sRGB .
If the animation works the two images should alternate every 4 seconds
Perhaps the reason is that adaptive editing programs are a little more sophisiticated in dealing with boundary conditions than color space conversions/CMSs, which I assume blindly apply their formulas.  Here is the path that a color on that petal took in xyY space:
1. Opened NEF in CNX2 either in ProPhotoRGB and in sRGB
2. Changed Picture Control from Neutral to Landscape
3. Applied CEP3 Tonal Contrast at default values
4. Converted ProPhotoRGB image to sRGB
Path of sample color during processing
And here is another sample color from the left side of the flower: this one was luckier than the next.
More space waks
Here is a sample color's trip on the Blue Ball image with the purple shift going from ACR 6.7 Standard through CEP3 Tonal Contrast - this one was doomed from the start.  It seems to me that the hue shift was introduced by ACR when it applied the color spaces originally.
It seems to me that despite the fact that I selected 'perceptual' intent, when programs/CMMs convert to sRGB they simply bring whoever is out to left field back to the edge.  While instead if you are working within the smaller space to start with, the editing programs are a bit more mindful about not hitting the ceiling.  What do you guys think?
Jack
Jeff Schewe
Don't know if there's any benefit...but v2 PP RGB to v4 sRG allows the use of both perceptual and relative colorimetric renderings. I've seen some improvement in using perceptual with some images–particularly saturated reds & blues.
Jeff Schewe
Jeff Schewe
In reply to Jack Hogan, May 2, 2013
If you are working with device based matrix color spaces defined with v2 ICC profiles, there is no perceptual renderings–even if an app allows you to select it. It's always, only relative colorimetric.
If you want to use perceptual in a working space transform, you need to be using a v4 color space profile that HAS a real perceptual rendering intent. You'll want to get the sRGB_v4_ICC_preference_displayclass.icc profile available on the ICC web site. Otherwise, yes, a PP RGB>sRGB transform will always clip out of gamut color.
Jeff Schewe
Jack Hogan
In reply to Jeff Schewe, May 2, 2013
Jeff Schewe
Ah, that's why.  Good to know, thanks Jeff.
crames
In reply to Jack Hogan, May 3, 2013
Is there a TIFF that hasn't been converted to sRGB and is still in ProPhoto?
Cliff
Jack Hogan
In reply to crames, May 3, 2013
Here is the original NEF and here is the equivalent TIFF in ProPhoto (opened in ProPhoto, Picture Control Landscape, CEP3 Tonal Contrast applied at default settings).
Cliff, the links to the two intermediate color spaces by jc mentioned in the LuLa thread no longer work.  I've sent you a PM with my email address.  Would you mind emailing them to me?
Jack
xpatUSA
Senior MemberPosts: 6,376Gear list
In reply to Jack Hogan, May 17, 2013
Jack
For what it's worth, I found a JPEG in ProPhoto of your flower up there and here's a 2D gamut diagram of it, courtesy of my new toy:
Lab color space, sRGB profile shown. Looks like a good candidate for perceptual intent?
Ted http://kronometric.org
SD9, SD10, EF-500, GH1.
Panasonic Lumix DMC-LX7 Sigma SD10 Sigma SD14 Sigma SD1 Merrill Sigma 50mm F2.8 EX DG Macro +3 more
Iliah Borg
Forum ProPosts: 18,656
In reply to Detail Man, May 19, 2013
All raw converters ultimately have to take the demosaiced raw camera coordinates (RGB or GMCY) and map them to XYZ or Lab
Thу above is incorrect.
Detail Man
Forum ProPosts: 16,175
In reply to Iliah Borg, May 19, 2013
All raw converters ultimately have to take the demosaiced raw camera coordinates (RGB or GMCY) and map them to XYZ or Lab, though it may be only an intermediate step. This is especially true for raw converters that use ICC profiles, where either XYZ or Lab D50 is the working space. The final mapping from XYZ to any of the standard RGB spaces is just a linear transform plus an encoding curve. The lookup tables provide a mechanism for non-linear corrections (e.g., if you need to tweak deep saturated reds differently than less-saturated reds, something the earlier matrix-only profiles obviously could not do).
- Eric Chan, Reply #51 on: July 28, 2008, 08:31:26 PM
http://www.luminous-landscape.com/forum/index.php?topic=26524.msg211284#msg211284
(Perhaps) one exception being RAW Photo Processor (RPP) ?
RudivanS
Veteran MemberPosts: 4,428Gear list
Yes, RPP is my go-to when time allows - well worth a donation for full access.
RPP-Overview
Rudi - freelancer
'15 years in bladerunner Tokyo - back in sunny Sydney now'
 RudivanS's gear list:RudivanS's gear list
Nikon D4 Nikon D800E Canon Pixma Pro-10
Iliah Borg
In reply to Detail Man, May 28, 2013
The "have" part is totally wrong. Fantastically wrong.
Detail Man
In reply to Iliah Borg, May 28, 2013
Interesting. I wanted to attribute the statement to its author (Eric Chan). I wonder if any digital cameras exist that may take such approaches. You mentioned that in your understanding this might (at least in the case of the Olympus E-M5) be a typical in-camera processing scenario:
Iliah Borg wrote:
Yes. Essentially (simplifying and omitting any secrets of trade) what happens is:
Apply WB; run 1st stage NR and sharpening; perform demosaicking; convert from camera colour to XYZ; apply 2nd stage of sharpening on Y; convert to LCH; apply tone curve to L; apply saturation to C; apply "look" to H; apply 2nd stage of NR over L and C; smooth H; apply convert to output space (like sRGB or AdobeRGB).
http://www.dpreview.com/forums/post/42201474
exdeejjjaaaa
Veteran MemberPosts: 7,469Gear list
In reply to Detail Man, May 29, 2013
Interesting.
I think IB is nitpicking to certain extent on Eric... software developer certainly can avoid using XYZ or Lab for any internal postdemosaick operations and can avoid using any CMS transforms involving PCS = XYZ or Lab if he wants to (code something different all by himself) and Eric Chan for sure knows that but he was not writing that text for IB and so was not that careful w/ wording (or was carried away by what was/is generally accepted)
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +19 more
Iliah Borg
In reply to exdeejjjaaaa, May 29, 2013
Interesting.
And it is not nitpicking. It is a serious thing to consider.
if he wants to
Not the matter of what one wants but the matter of what is better.
Iliah Borg
Re: Does Melissa "Gloss Over" Image Noise ?
and which is stated here by Eric Chan to precisely comport with that ProPhoto RGB specification, but has been measured by Bill Janes using Imatest to appear to not comport:
http://forums.adobe.com/message/4895109
He should have used a synthetic target instead.
