Event Log warning
Started Apr 26, 2013 | Discussions
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
Event Log warning
I am getting this error regularly:
Name resolution for the name wpad.gateway.2wire.net timed out after none of the configured DNS servers responded.
Can someone advise?
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Bouldergramp
Bouldergramp Regular Member • Posts: 337
Re: Event Log warning
Can someone advise?
Thanks,
Digitalshooter
If you do a Google search for:
you will find many people have or had the same problem.
Bouldergramp
 Bouldergramp's gear list:Bouldergramp's gear list
Samsung EX2F +3 more
digitalshooter
digitalshooter OP Forum Pro • Posts: 19,604
dont see your response? (nt)
Thanks,
Digitalshooter
Bouldergramp
Something didn't work right.  My comment was missing:
If you search on the above line of text, you will find many people have or had the same problem.
Bouldergramp
Jim Cockfield Forum Pro • Posts: 16,333
Click "show signature"
The response was in the signature section of the post.  If you click on "show signature", you can see it.
Anytime the forums see two dashes in a row, it automatically assumes that's the start of the signature section of the post.  Note how your signature looks when making a post and you'll see them.
So, make sure to click on "show signature" to make sure you see all of a post here (and avoid the use of consecutive dashes in your posts if you don't want for them to cause that kind of issue with posts here, where the forums software assumes they're being used to start the signature section of a post).
JimC
JamesMortimer Senior Member • Posts: 1,492
There's nothing to advise - the dns servers can't find a matching IP address for that name.
It usually means that the site is gone from the web, either killed off by it owners or their host, or is just temporarily dead (bad server or host doing upgrades).
If it's important, try again each day.. If it's temp it'll be back.
digitalshooter
Thanks but I am not trying to access it (nt)
Thanks,
Digitalshooter
Re: Thanks but I am not trying to access it
OH!!
I see now - you don't go there but still found that in your log? (you didn't make that clear)
In that case I'd suggest that it's just an internal connection (in a web page).
You may have gone somewhere that refers on a cookie to that page, the way that google does with various thing, facebook does with others, ad servers, etc.
Even porno sites refer on to ad servers and even google.. My favourite one tries to refer to a few advert sites (host file blocked though, hehehe)
If you are worried, download malwarebytes antimalware and run it (just run it as a freewaare user, trial version, it'll still tell you if you have "caught something" - I DOUBT you have, but better to be safe).
Run it, scan, then see if it detects anything, then uninstall it.
I thinks it's just referrer stuff, but you never know.
digitalshooter
add these from today
Name resolution for the name g2.img-dpreview.com timed out after none of the configured DNS servers responded
Name resolution for the name images.doityourself.com timed out after none of the configured DNS servers responded.
Thanks,
Digitalshooter
digitalshooter
update with more information
I get these errors when my IE hangs waiting for a response from the server.  In other words, if I go to a website, sometimes it appears without issue.  Other times I get a delay and a message that says waiting for a response from ..............
Thanks,
Digitalshooter
Re: add these from today
Thanks,
Digitalshooter
Those two are image hosts, the first is probably for the little icons for talky box and such, maybe some camera pictures, etc.
Maybe the server is having troubles, disabled, or just plain overloaded and not responding.
I'd say the second is a similar thing, just a plain ordinary hosy for images of some sort - and not responding to a request.
The lock-up thing you can't do too much about (My Opera does the same thing, calls for something and waits for a response, and waits..).
There might be a way to reduce the time it waits for a no-response signal, but I don't know where that would be, sorry.
Goole might help though.
