6d too much detail
Started Apr 25, 2013 | Discussions
GHwell Senior Member • Posts: 1,944
6d too much detail
after comparing the close ups of my wedding couple  the old 5d gives a better smoother skin than the 6d.   The 6d has too much detail showing every fine hair on the womans face.   I am sure that is not going to please her.   Male skin looked very rough and the skin pores were hugh.
Canon EOS 5D Canon EOS 6D
Johnyguy Regular Member • Posts: 203
Re: 6d too much detail
Have you been thinking to get the original rebel film camera to fix the issue you have its much cheaper than the 6D!
Great Bustard Forum Pro • Posts: 33,065
Apply a lot of NR (noise reduction)...
...or use the 5D.
bgbs Senior Member • Posts: 2,827
Export smaller files.
Scott Larson Veteran Member • Posts: 5,663
Your lenses are too clean.
 Scott Larson's gear list:Scott Larson's gear list
Canon EOS-1D Mark III Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +12 more
Brad Evans Contributing Member • Posts: 616
Easy to solve problem...
Use a bit of negative Clarity in Lightroom or ACR. You'll then create more flattering portraits...
Brad
Brad
Urban photoblog: http://www.citysnaps.net
MrScorpio
MrScorpio Senior Member • Posts: 1,365
These effects are likely to be morea result of the size and placement of the light source than the tech specifics of the camera. You can get super smooth skin with a D800 when using light correctly.
The sun on a sunny day often produces terrible skin, but the same sun on an overcast day produces nice soft skin as the whole sky then acts like a giant softbox.
For extremely good reading on the subject I recommend the book "Photographic lighting, science and magic".
BR
Marcus
 MrScorpio's gear list:MrScorpio's gear list
Olympus OM-D E-M5 Canon EOS 6D Nikon Df Canon EF 35mm f/2.0 Canon EF 50mm f/1.4 USM +14 more
rstone Contributing Member • Posts: 513
Brad
Brad
Agree, or alternately, any good wedding/portrait photographer should have one of the below.
http://imagenomic.com/pt.aspx
http://www.portraitprofessional.com/?gclid=CKLyx8mU57YCFUNgMgodY10APA
 rstone's gear list:rstone's gear list
Canon EOS 70D Canon EF 24-70mm f/2.8L USM Tamron SP AF 90mm F/2.8 Di Macro Sigma 8mm F3.5 EX DG Circular Fisheye Canon EF-S 18-135mm f/3.5-5.6 IS STM +2 more
ASR45
ASR45 Forum Pro • Posts: 34,890
As the saying goes the Camera never lies LOl
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
andrewsf Contributing Member • Posts: 539
7
Perhaps you just need to learn to process the images or light the subject better? Saying a camera captures too much detail is almost the dumbest thing I've ever read on this gear obsessed forum.
 andrewsf's gear list:andrewsf's gear list
Canon EOS 400D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +1 more
Rick Knepper Forum Pro • Posts: 13,160
This is what Photoshop et al are for
I'm sure you don't want a camera that smoothes skin simply because it isn't capturing enough detail.
Plus, at normal print sizes for wedding albums, I can't imagine the issue.
However you resolve this issue and you will, having the ability to capture more detail is good to have for those times when you need to capture more detail.
Rick Knepper, photographer, non-professional, shooting for pleasure, check my profile for gear list and philosophy. TJ said, "Every generation needs a new revolution".
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R +2 more
leroyvanhee Senior Member • Posts: 1,828
Try Nik Software 'Sharpener' or any other app that includes a 'Structure' control. Turn down the Structure characteristic and paint that adjustment on skin where you want less detail.
gfspencer Contributing Member • Posts: 517
This is a first.  I have never heard anyone complain about a camera being too sharp.
You were complaining about the 6D manual earlier.  Did you read it? You could shoot in JPEG and put the camera in portrait mode.
 gfspencer's gear list:gfspencer's gear list
Canon EOS 7D Canon EOS 6D Canon EF 50mm f/1.2L USM Canon EF 16-35mm f/2.8L II USM Canon EF 28-135mm f/3.5-5.6 IS USM +5 more
keithinmelbourne
keithinmelbourne Contributing Member • Posts: 691
I think you're on the wong forum. There is a comedy one. Right? (nt)
 keithinmelbourne's gear list:keithinmelbourne's gear list
Fujifilm X20 Panasonic Lumix DMC-LX100 Canon EOS-1Ds Mark III Canon EOS 6D Canon EOS Rebel SL1 +19 more
Learnphotography
Learnphotography Forum Member • Posts: 56
I feel that my 6D handling and ergonomics are so user friendly that I have problem with it.
Ubiquity99 Regular Member • Posts: 138
Smear some Vasoline on your lens. /s
GHwell OP Senior Member • Posts: 1,944
Re: I shoot raw 95 % of the time
I know how to do post.   Been doing it for 12 years. Built my company on doing restoration and touch up.    I like to get it right in camera with as little post as possible.   I will stick with the 5d for portraits and the 6d for low light and video.  That is why I purchased anyway.   PS I just did a dog breeder and got the same complaint that the pictures were too sharp.     I shot them with the 5d in raw.  I had to soften every shot to make the sale.
Re: Dead serious
I was not pleased with the skin
sean lancaster
sean lancaster Veteran Member • Posts: 6,761
I was operating under the assumption that the first post was a joke. Now I realize it wasn't.
Since PP is out of the picture, perhaps you could buy a cheap, used, 3rd party zoom lens and I assure you that you'll get less sharp images.
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony Alpha 7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 +4 more
NancyP Veteran Member • Posts: 5,280
It's all in the post-processing. Still, if the 5D saves you time, that's the camera for you!
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
