HS50EXR Firmware Update Released
Started Apr 25, 2013 | Discussions
DonDeJ Junior Member • Posts: 28
Fuji has released firmware update 1.01 for the HS50EXR. You can get it here:
http://www.fujifilm.com/support/digital_cameras/software/firmware/s/finepix_hs50exr/index.html
From Fuji:
1. Operability of Eye-Fi card is improved.
2. Disconnection of objects shown in Motion Panorama images by vertical direction shooting is improved.
Don
darrin16 New Member • Posts: 23
Re: HS50EXR Firmware Update Released
Thanks for letting us know!
tman1991 Contributing Member • Posts: 742
From Fuji:
Don
Good they are updating firmware..
But these are like 2 features who uses?
 tman1991's gear list:tman1991's gear list
Fujifilm X-T1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +4 more
From Fuji:
Don
I agree, but there is always something good about getting off that v1.00 firmware.
haole New Member • Posts: 4
I just Dl a copy of this firmware for my Windows OS.
From the instructions it says its suppose to be:
"File name FPUPDATE.DAT
File size 26.1MB
If the file size does not match the figures given above, download the firmware update file again."
Mine is 26.0 MB (27,362,512bytes).
I suppose I need to keep Dling until I get one thats 26.1MB then.
Has anyone else here got the specified 26.1MB file size yet?
 haole's gear list:haole's gear list
Fujifilm FinePix HS50 EXR
I had no issue downloading and installing.
I just Downloaded it again, same size.
File hashes on my 2nd one:
MD5: D70C2FC4F114C7EF8E6E42FF642F51FF
SHA-1: B45F3E1685A6789DE4801A41F5818B3FA731CBF8
Pitty fujifilm doesn't provide hash files so we can compare them on a firmware update that they say:
"Precaution
1. If firmware updating fails, the camera may no longer operate correctly in some cases. Carefully read the notes provided here."
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
That file is OK to install, once downloaded it's 27,362,512bytes.
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
DickyAus Senior Member • Posts: 1,559
I downloaded using Windows 7 and Firefox but to folder rather than the desktop as instructed - the file was 26.3Mb; I copied it to a formatted SD card and Windows then said it was 26.1Mb as advertised. Who believes Microsoft anyway? It installed just fine and the camera works OK.
Someone earlier in the thread said the updates were to features no-one used - if you haven't used vertical panoramas you haven't lived.
 DickyAus's gear list:DickyAus's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro
MitchyK7 Regular Member • Posts: 131
Well this was a great update, i had no problems with vertical panorama's before, but now i can't take any. It says shooting interrupted every single time. lol. Great work Fuji, as usual...
jcmarfilph Veteran Member • Posts: 7,592
No matter how great it is, I always shoot multiple parts of the scene and stitch it manually.
Some samples from HS camera....
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
Hold camera in normal orientation and it will work fine. If you rotate the camera 90 degrees and then try to pan vertical plane you will get the interrupted message.
DonDeJ OP Junior Member • Posts: 28
You're welcome.
Don
I am holding it in normal orientation, it was working before, and now it's not.
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,335
really?
darrin16 wrote:
From Fuji:
Don
You risk two things by upgrading firmware:
1) Firmware team brain fart. This is not uncommon.
2) Bricking the camera. It happens.
The features they are fixing are so obscure that the firmware team did not test them adequately in the first place. Right?
It is a personal choice whether to apply a firmware update, but the stock advice for BIOS and firmware is always the same -- if you do not experience the issues described, the risk is not worth it.
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GF3 +16 more
Kim Letkeman
wow ...
I wrote that before I read the thread ... so the brain fart scenario applies. Anyone happy they upgraded?
Three test shots after my update.
1. Top to bottom direction, Vertical pan - normal camera orientation:
Not a very good subject, but no tall objects around.
2.Top to bottom direction, Horizontal pan camera rotated through 90 degrees:
3. Left to right direction, horizontal pan normal camera orientation:
Perhaps release 2 firmware will cure your problems when it arrives.
Dicky.
