Need help!!...big prints!!!
Started Apr 25, 2013 | Discussions
Vinny311
Vinny311 Forum Member • Posts: 75
Hi there people...
Going to shoot a Love Story on sunday morning and the couple wants some of those photos to be printed 4', 5' or 6' for the wedding...first timer here!..
My question/info...
  • Camera/equipment settings to do it the right way?...do I have to change the settings in my camera??...
  • Will edit in PS5...
  • Various locations, rain forrest, beach and a colonial house (Love my island Puerto Rico!)
  • Any suggestions?
In any case this is relevant, the equipment I will use:
  • Sony a580
  • 70-200mm 2.8 G
  • 50mm 1.7 Minolta
  • 16-50 2.8
  • Speedlites + softboxes + reflectors
Old glass...timeless beauty (Minolta Lenses)
 Vinny311's gear list:Vinny311's gear list
Sony Alpha DSLR-A200 Sony Alpha DSLR-A580 Sony SLT-A77 Sony Alpha 7R Sony 70-200mm F2.8 G +11 more
Sony Alpha SLT-A58
fft81 Contributing Member • Posts: 942
Re: Need help!!...big prints!!!
Vinny311 wrote:
Hi there people...
My question/info...
  • Any suggestions?
  • Sony a580
  • 70-200mm 2.8 G
  • 50mm 1.7 Minolta
  • 16-50 2.8
Pixel peepers will say that 16 MPx Sony a580 is not enough for 4' tall image. You definitely want to get every pixel count; this means use f/4 or smaller aperture. Add light as needed. To reduce DOF at smaller apertures like f/4 or f/5.6 use longer FL on your 70-200. Is a560 a cropped sensor? If it is, you may be able to get away with f/2.8 for sharpness requirements. Use lowest ISO that the existing light can permit.
If you have control of the environment try to reduce the fine detail that exists in the environment; this way on large printed image you don't see a square where eye expects to see a small flower; you see a gradient of squares where eye expects to see gradient of colors.
Peter Patricelli Regular Member • Posts: 329
From the standpoint of any adjustment in shooting for an anticipated huge enlargement, it should go without saying that it is all about resolution, information density, and sharpness since any image softness is going to be magnified hugely by xtreme enlargement.  The best technical enlargement result is going to come from choice of camera, and simple MP size is not the whole story, lens resolution.....and then technique to maximize what the hardware of capable of.
If you are used to only shooting for internet/web or small pictures you might not know where the maximum sharpness settings are for your particular camera(s) and lens(es).  If you have been shooting for relatively big enlargements, maybe up to 16 x 20 then you should already be aware of what it takes to get the best resolution out of your equipment.
Personally, I don't really feel I KNOW a file/image until I have printed it out large.  If it won't hold up to 16 x 20 then it won't go any bigger (my opinion) and can only do smaller formats.
One assumes that YOU are not doing the printing...or you wouldn't have to ask the question.  Talk to the printing site as to what equip they are using and best resolutions /settings in the file you send them.
You will get various answers as to the issue of "how big can an xxMP file be printed".  My biggest enlargements so far involve a Nikon D2x....12.2 MP file....blown up into 4 16 x 20" panels wide by 3 panels high.....that translates into about 6 1/2 feet wide.  The native print resolution came out to something like 65 ppi.  I was blown away by the resolution/detail and to how well it works as a mural.  In your case, at a wedding, everyone is disposed to be positive, accepting, and gracious, so no one is going to get eyeball to print and register complaints.  Not all cameras and not all pixels are the same so what worked in this case is not a universal limit.
If I KNEW I was shooting for max enlargement then I would stick with my best resolution camera and lens, use a tripod or monpod as much as possible, and fuss over the details of focus, sharpest f-stop for your lens, lowest ISO, etc..  IF you don't know what I am talking about then this is going to be a painful learning curve for you....and maybe your couple.
Peter Patricelli
www.flyfishingfotography.com
Vinny311
Vinny311 OP Forum Member • Posts: 75
Thank you very much guys!!!...appreciate your time!...great advice, willl put them to work...let you know how it all comes out!!!
