X100S - OVEREXPSURE WHEN SWITCHING CAMERA ON
Started Apr 25, 2013 | Discussions
rex oneill
Forum MemberPosts: 61
Apr 25, 2013
When i turn my camera on or press the shutter from sleep at a bright seen the image is majorly overexposed before settling down to correct exposure. i had a similar experience when using panasonic 17mm lens on ep2 body, apparently because the lens was faster than any olympus lens. my friend has a similar experience with his x100s. does anyone know the reason why... it's quite an annoying phenomenon and means i have missed several shots. otherwise i couldn't be happier. amazing camera and well worth the upgrade from the x100. thanks
Fujifilm FinePix X100 Fujifilm X100S Olympus PEN E-P2
rex oneill
Re: X100S - OVEREXPSURE WHEN SWITCHING CAMERA ON
In reply to rex oneill, Apr 25, 2013
is this the aperture dance associated with the x100? i never experienced it on my x100. thanks
NachoYogi
Regular MemberPosts: 142Gear list
Happens to me as well (on occasion) .  I just assumed it took time for the camera to adjust to the sudden blast of light.
 NachoYogi's gear list:NachoYogi's gear list
Canon PowerShot G10 Canon PowerShot S110 Fujifilm X100S Nikon D300S Fujifilm X-Pro1 +9 more
rex oneill
In reply to NachoYogi, Apr 25, 2013
seems to me that this shouldn't be happening. i've missed quite a few shots waiting for the exposure to "settle down". It also makes a very feint noise when it's occurring. thanks
NachoYogi
I haven't heard the noise, but I agree it shouldn't be happening.
It would be good to hear if this is happening to others.
chartno3
Junior MemberPosts: 26Gear list
This happens to me too. Just figured it was another quirk to deal with
 chartno3's gear list:chartno3's gear list
Fujifilm FinePix X100 Fujifilm X100S Fujifilm X100T Fujifilm X-T1 Fujifilm XF 35mm F1.4 R +1 more
blulegend
Senior MemberPosts: 1,600
In reply to chartno3, Apr 25, 2013
Happens to me too. It takes a long time to settle down the exposure when the shutter first opens. It would seem like it could be optimized a bit better.
-Jack
http://blupic.com/show
sdfreeland
Junior MemberPosts: 33
I guess that would explain why I thought a lot of my pictures were overexposed last weekend initially after turning the camera on.  I noticed the camera was trying to set a super high ISO of 1600 even when it was super bright outside.  I was using manual f/2.8, shutter of 1/500 and auto ISO.
BurpeesAreHard
Regular MemberPosts: 487
What if you use the OVF and turn on OVF Power Save, so that the default state of the camera is for it to sit there with the shutter slammed shut. Do you find that to be therapeutic?
Of course, if you do this you lose your live histogram, you might see higher shutter actuation counts (due to the fact that the shutter has to open each time you half-press to meter a scene) and other things. Life has its tradeoffs. And there will still be some startup delay no matter what. I don't have the 's', though, so I can't test it.
94
94
Contributing MemberPosts: 985Gear list
In reply to BurpeesAreHard, Apr 26, 2013
I don't know what it might be but because mine does not do that I'd tend to think that it may have to do with something in the setup configuration of each camera.
 94's gear list:94's gear list
Fujifilm X100T Canon EOS-1D Mark II N Canon EOS 5D Mark II Fujifilm X-Pro1 Fujifilm X-T1 +23 more
