Could use an programming API for Nikon Cameras
Started Apr 25, 2013 | Discussions
vFunct Regular Member • Posts: 435
I could really, really use a programming API for these Nikon cameras so that our photographers can  upload photos from the field directly to our CMS for publishing purposes, while at the same time adjusting/cropping/rotating/keywording these images.
Does anyone think Nikon will enable an open programming API for their cameras?  Need to be able to do this so that our photographers have a much easier publishing workflow.
inasir1971
inasir1971 Senior Member • Posts: 3,460
Re: Could use an programming API for Nikon Cameras
 inasir1971's gear list:inasir1971's gear list
Sony RX1R II Nikon D4 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED
vFunct OP Regular Member • Posts: 435
These don't look like in-camera APIs, but APIs for your computer to either control the cameras remotely or process raw images.
I need something on the camera itself.
Per Baekgaard Senior Member • Posts: 1,070
Don't think that exists...
You mean you want to run something inside the camera itself, on the embedded processor?
I don't think that currently exists. I know there exists some custumized/hacked firmware for a few non-Nikon cameras, but I haven't seen anything running on top or inside the Nikon DSLR cameras.
A possible alternative might be to use a portable device to grab the images from the camera via USB or WiFi (either Nikons WiFi or something like the EyeFi cards) and then send those off to your CMS in whatever way you want.
The portable device could be a tablet or a phone.
Or you could wait till the DSLR cameras also run Android
 Per Baekgaard's gear list:Per Baekgaard's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +15 more
lnaru78 Forum Member • Posts: 62
Or you can get the D4
nplanet Regular Member • Posts: 152
Will this help: http://nikonrumors.com/2013/04/14/nikon-sdk-c-wrapper-library.aspx/
inasir1971
Oh, something on the camera itself might be a problem. There are a lot of trade secrets in the firmware (AF algorithms etc.) - probably why firmware is encrypted.
