OM lenses to Micro 4/3
Started Apr 24, 2013 | Discussions
108
108
Contributing MemberPosts: 503
Apr 24, 2013
Hello
Does anyone have an experience with adapting OM legacy lenses to the M4/3 format ? I have done it for the Olympus 4/3 Dslr with success but when I see the "huge" width of the adapters compared to those for the 4/3 I wonder if such a distance between lens and sensor might affect the results.
RomanB
Contributing MemberPosts: 952Gear list
Re: OM lenses to Micro 4/3
In reply to 108, Apr 24, 2013
108 wrote:
Hello
Yes, I've used OM lenses with m43 cameras.
Adapter length is defined by flange focal distance, for OM it's 46mm. These adapters don't have optics so the results are not affected.
OM adapters are relatively large, there are SLR formats for which adapters are 3-4mm shorter. However, OM lenses are often smaller than other brands' SLR lenses of similar specs. There are good buys among MF lenses of many brands, you don't need to lock yourself into one, almost all are adaptable to m43.
 RomanB's gear list:RomanB's gear list
Olympus PEN E-P1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 7.5mm F3.5 UMC Fisheye MFT +8 more
lambert4
Senior MemberPosts: 1,793Gear list
I have had great success with the OM lens on my micro four thirds bodies.  There is a miss on the infinity focus being that it is slightly short of the barrel rings infinity, but negligible.  It could be my adapter as well, a Fotasy version.  The only other shortcoming is the CA is quite apparent high right light on my Olympus body, not sure if the corrections in a Pnanasonic body would negate this or not.
All of that being said I love the manual focus lens on the bodies and have purchased and anxiously await a Nikon adapter and lens now to further compliment the system.
you can see a few images on my Flickr thread or on the group on Flickr micro four thirdsLegacy lens alternative lens
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Olympus OM-D E-M5 Olympus E-M1
Kleeks13
Regular MemberPosts: 310
In reply to RomanB, Apr 24, 2013
roman:  and what's your experiences with 4/3 lenses (especially the 50mm) with the micro 4/3 OMD body?  I'm very interested as the "4/3 to micro 4/3 adapter" is a rebate special for us new OMD owners.
Kleeks
"a weed is just a plant in the wrong place."
Bassam Guy
Regular MemberPosts: 256
In reply to lambert4, Apr 24, 2013
I have bundles of great OM Zuiko glass left over from the film era and used it with my E-PM1.
They all produce fantastic results - but focusing is a bit awkward on the PM1.
I just bought a E-PL5 which is better for manual focusing but not perfect.
The most useful OM lenses are my 50mm f1.4, giving me effective 100mm f1.4 and another 50, the 3.5 macro.
ALSO, make sure you have the latest firmware for you camera. Last night I installed a new FW for my PL5 that has a fix for exposure issues with non-4/3 lenses.
Oh yes, the distance scales on the OM lenses will be incorrect and like stated above, infinity is not where you think it is!
Art_P
Veteran MemberPosts: 9,743Gear list
The distance is constant
The adapter makes up the difference between the film to flange distance on an OM body and sensor to flange distance on an M43 body.  With the adapter, the lens to sensor/film distance is the same.  With 4/3, you had a fairly small adapter because there wasn't that much difference between OM and 4/3.
I haven't bought a dedicated OM to n43 adapter yet, I'm still piggybacking an OM - 4/3 adapter on a 4/3 - m43 adapter.   It works because the correct adapter lets the lens focus on the surface of the sensor, don't worry about the size.
Art P
"I am a creature of contrast,
of light and shadow.
I live where the two play together,
I thrive on the conflict"
 Art_P's gear list:Art_P's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +2 more
davestravelgear
Contributing MemberPosts: 511Gear list
I've added many old manual lenses to my collection since acquiring my E-M5 3 months ago (probably too many) and my favorites are all OM's, 28mm f2.8, 50mm f1.8 and 50mm f3.5 Macro.
There is something about the build quality that makes you want to caress them, and even though the adapter makes them longer, they are still very manageable and one hell of a lot of fun to use
I love the way you can set up the E-M5 to zoom in on your subject (up to 14x) with the Fn2 custom button to nail the focus, and the OM's can give you some smooth backgrounds to boot!
Here's mine with the 50mm f1.8 fitted;
 davestravelgear's gear list:davestravelgear's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8
OM User
Regular MemberPosts: 262Gear list
M43 lenses appear to be very thin and long to soemone used to regular OM Zuiko manual lenses.
The thinness is just down to aperture as most M43 lenses let in less light than their 35mm equivalents (as a general rule).
But put the squat looking OM 50mm F1.2 (or F1.4/F1.8) on the adapter and its pretty close in length to the M43 12-50mm kit zoom. For any OM manual lens try measuring from the main objective lens to the film plane for your OM camera and then measure the main objective lens to the sensor plane wjne mounted via the adapter to a M43 camera. They will be identical. In practice the second measurement will be fractions of a millimeter shorter to ensure the lens can reach inifinity focus (the reason the inifinity mark does not always line up).
 OM User's gear list:OM User's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
108
108 OP
Thanks for the link. Great pictures. A bit too bad a lot of them don't mention the lens type.
108
108 OP
In reply to davestravelgear, Apr 24, 2013
Yes the 50 mm f1.8 is an awesome lens. I like it better than the 1.4.
108
108 OP
In reply to OM User, Apr 24, 2013
Thanks to you and to all the others for the explanations.
amipal
Regular MemberPosts: 420Gear list
My dad says he has an OM-10 at home somewhere with a couple of lenses and a flash, so I'm quite interested in doing this myself. Saying that, I've dug around at my parent's house - can I find it? Nope.
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +4 more
Kleeks13
In reply to amipal, Apr 25, 2013
OMG....I collect old Olympus Pen cameras and I think an Olympus OM came with it one of my purchases along with the  50 lens!!!!....Off to the storage closet to check.  Thanks for all the great information!!!!!  Plus the adatper is a rebate offer for us newbie OMD owners!!!!
Kleeks
davestravelgear
In reply to 108, Apr 25, 2013
I recently acquired an OM 50mm f1.4 very cheaply and it is very soft wide open, but things soon become better around f2-4.
RomanB
In reply to Kleeks13, Apr 26, 2013
Sorry, I haven't owned any 4/3 lenses. Frankly, I never considered them. Reportedly, AF is not the fastest on m43 and they are larger than native m43 lenses. Comparing to manual focus they are more expensive (adapters are more expensive too).
So I stick with some native lenses (some great buys here btw, like 45/1.8) and some MF lenses (most of them are Canon FD)
hindesite
Senior MemberPosts: 1,999
Adapter is one of the simplest
In reply to 108, Apr 26, 2013
The OM>m4/3 adapter is one of the most reliable, as it has no moving parts (release is on the OM lens) and the system was never hacked around like m42 was so there don't seem to ever be any compatibility issues.
robonrome
Senior MemberPosts: 1,842Gear list
In reply to amipal, Apr 26, 2013
maybe its with mine... went looking for my old om10 and zuiko 135 when i got into m43 and no luck... maybe they go where all the biros go....
 robonrome's gear list:robonrome's gear list
Sony Cyber-shot DSC-RX100 III Olympus E-M5 II Sony Alpha 7R II Olympus E-M1 Olympus 12-40mm F2.8 +13 more
Elix
Regular MemberPosts: 298Gear list
In reply to robonrome, Apr 26, 2013
My dad gave his OM-10 to my sister's boyfriend, that is a photographer.., Check if you have any sister.
 Elix's gear list:Elix's gear list
Sony RX100 Olympus E-M1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus 12-40mm F2.8 +3 more
