Anything to look out for in printing transparencies with my inkjet?
Started Apr 23, 2013 | Discussions
Philnw2 Senior Member • Posts: 1,658
These are the kind of transparencies used in overhead projectors.  i see that Staples sells them in the US.
Phil B
Nex 5n, Pentax K5, Epson R3000
 Philnw2's gear list:Philnw2's gear list
Sony Alpha NEX-6 Pentax K-3 Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 28mm F2
John W Hall Contributing Member • Posts: 549
Re: Anything to look out for in printing transparencies with my inkjet?
I suggest you look carefully at which type of inks to use with them.
Dyes filter some colours out of transmitted light, pigments reflect some colours and absorb others.
So I expect to find that Dyes: good, Pigments: bad, on a transparency.
but perhaps it is not so simple.
Endrick Man Contributing Member • Posts: 506
Done it some years ago and it works well, there didn't seem to be any problems with the inks in my Epsom photo priner.  You do need to make sure you use transparencies that are intended for inkjet printing as some heat  can be generated in the process and a melted transparencie would be unfortunate to say the least!
RS_RS Senior Member • Posts: 1,734
Phil B
I thought OHPs were about as widely used as slide rules and tape recorders these days, but there you go!
