Do you guys use VR on or off mostly?
Started Apr 23, 2013 | Discussions
alegator Regular Member • Posts: 202
I always had the idea that VR should always be OFF unless stricltly necessary, like when shooting in vibration environments. I found a great article
I infer from such article that even with handheld, unless standing on a vibrating surface, VR should be OFF.
What's your feedback on this?
kiirokurisu Regular Member • Posts: 385
Re: Do you guys use VR on or off mostly?
This seems totally contrary to the design intent of VR. It is designed to damp out small movements of the photographer's hands, not the ground he or she's standing on (with the exception of lenses that have an Active VR setting, which is indeed designed for moving platforms).
For the most part I leave VR on unless I'm certain that I will be shooting above 1/focal length shutter speeds. But then I do a lot of available light shooting.
RBFresno
RBFresno Forum Pro • Posts: 11,027
The worse thing about turning VR off......
HI!
Under some circumstances (not most) there may be some minor advantages to turning VR off (though in my personal use, I'm not sure I've ever seen VR degrade an image)..
However, for me, the worse thing about turning VR of, is that I tend to forget to turn it back on when I really need it. I've screwed up a fair number of pictures that way.
So I now basically leave it on all the time unless:
-I'm using a tripod (and then I'll sometimes use tripod mode VR if the lens has it or if the tripod is on a moving or shaking surface, or if there is enough wind to shake even a tripod)
-I'm doing  a lot of shooting in a situation where  I'm always using a fast shutter speed (even then, VR can be useful as it stabilizes the image in the viewfinder, sometimes making it easier to track a moving subject).
RB
http://www.dpreview.com/members/2305099006/challenges
http://www.pbase.com/rbfresno/profile
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +12 more
ADeighty Regular Member • Posts: 175
The idea you have is wrong. You can use google and get all the correct info very easy.
 ADeighty's gear list:ADeighty's gear list
Nikon D90 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Tokina AT-X Pro 12-24mm f/4 (IF) DX Epson Stylus Photo R2880 +1 more
Hansa Yindee
Hansa Yindee Veteran Member • Posts: 3,949
99% of my work is handheld so it stays on.
I shoot a lot of wild monkeys just down the road..;-)
Jon in Thailand
www.flickr.com/photos/af2899/
 Hansa Yindee's gear list:Hansa Yindee's gear list
Nikon D50 Nikon D1X Nikon D300 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +9 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,599
Thom's current thinking has changed - the first part now seems to mirror what I have been saying for three or four years. There is nothing new there, except Thom does not mention VR can help AF keep something moving erratically in the viewfinder in sharp focus.
Nikon do not quote a current sampling frequency, and the correction frequency is not necessarily as fast as the sampling frequency. Nikon did say VR II is much better at eliminating low frequency vibrations than "original VR" prior to updating their VR links. On a detail I make it there are least 6 variations of VR in Nikon lenses, starting with the original 80-400 which remains on sale.
VR is an aid, like matrix metering, spot metering, AWB, auto focus, D-lighting, exposure compensation, TTL flash or using a tripod.
Sometimes using one or more of these improves results and sometimes using them makes results not so good. Knowing what to select when for your type of photography is part of the learning curve of photography.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
WIMorrison Senior Member • Posts: 1,499
Not exactly news given that Thom's article is dated April 2010 with the updated being June 2010 which are both 3 years ago
Iain Morrison LRPS CPAGB
wimorrison.co.uk
 WIMorrison's gear list:WIMorrison's gear list
Nikon D7000 Nikon D800E Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +13 more
Kuvasauna Contributing Member • Posts: 771
On - unless using tripod (nt)
'Anyone who believes exponential growth can go on forever in a finite world is either a madman or an economist.'
Robin Casady Forum Pro • Posts: 12,898
I think you misread the article.
I turn it off 98.765% of the time. Actually, I can't recall when I last turned it on. Don't think I've used it once with the D800E. Might have used it with the D700.
It should be off with shutter speeds of 1/500 sec. or faster.
It should be off if you are trying to get the ultimate sharpness out of the D800E. It can reduce motion blur, but it is not perfect and can cause a very small amount of blur.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
overniteman Contributing Member • Posts: 832
No tripod- VR always on
Tripod- VR off.
I always check the VR switch when I pull the lens out of the bag, just habit I giuess
andreben Regular Member • Posts: 109
One thing to keep in mind as well is that sometimes VR can give you unwanted artifacts in your image. For instance, particularly if you have some fairly out-of-focus objects such as trees, bushes, or even buildings in your picture, VR-on can at least on some lenses give you some nasty looking bokeh due to shifting of the out-of-focus objects. Due to this, I try to keep VR off unless I think I need it due to low shutter speeds.
Andreas
M Lammerse
M Lammerse Forum Pro • Posts: 11,272
It depends on my camera and usage.
I've only one lens which has VR, the 70-200mm F/2.8G VR-I
Inside on the D3S, it's mostly on, outside it's mostly off.
On D800 it's mostly on the whole time when I have to use it.
Michel
- To observe without evaluation is the highest form of human intelligence -
http://www.fotopropaganda.com
http://www.fotopropaganda.com/blog
http://www.flickr.com/photos/9240992@N05
Lance B Forum Pro • Posts: 29,023
Re: The worse thing about turning VR off......
HI!
That's pretty much me too, RB.
I rarely turn off VR and when I do I invariable forget to turn it back on! I mostly shoot with VR on, and it would only be on the rare occassion that I turn it off, and I don't think I have had an image suffer due to VR.
RB
 Lance B's gear list:Lance B's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +16 more
RBFresno
Hi!
I know that folks say this (even Rorslett), and I may  have seen a few examples(?). However I've never been able to reproduce this
VR on at fast shutter speed; Artifacts in the  bokeh?"
Nikon D3 ,Nikkor 200mm f/2G IF-ED AF-S VR
1/3200s f/2.0 at 200.0mm iso200
RB
larrywilson
larrywilson Veteran Member • Posts: 4,765
Mostly off.  Hardly ever on when using a tripod.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 500mm f/4G ED VR Carl Zeiss Makro-Planar T* 2/100 Carl Zeiss Distagon T* 2/25 +7 more
Red G8R
Red G8R Senior Member • Posts: 1,726
Mine stays ON for all handheld or even with monopod. The only time I turn it off is on the tripod.
I've read so many varying opinions but I do what I feel gives me the best results.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Fujifilm X-T1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
inasir1971
inasir1971 Senior Member • Posts: 3,460
I think as Leonard says above, there are many different versions of VR in use. This is further complicated as Nikon uses the suffix II after VR not in reference to the VR but to the lens - i.e. the AF-S 200/2 VR and VRII may have the same VR system (which I suspect).
I have three Nikon telephoto lenses with VR - the 70-200/2.8G VRII, 200/2G VRII, and AF-S 80-400 VR.
The VR in both the 70-200 and 200 seem very similar in effectiveness and I think that best results will be achieved with high enough shutter speeds and VR off. On a D800 viewing at 100%, there seems to be slight degradation with VR on at these shutter speeds. VR on both of these isn't really reliable enough to depend on.
The latest iteration of VR on the new 80-400 however is in a different league and doesn't seem to have any negative effects and I would just leave it on, except for tripod (maybe).
It really depends on the lens.
 inasir1971's gear list:inasir1971's gear list
Sony RX1R II Nikon D4 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED
richard cohen Senior Member • Posts: 1,045
Always on...
Unless I forget to turn it on I use it 100% of the time.
 richard cohen's gear list:richard cohen's gear list
Nikon D4 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 500mm f/4G ED VR Nikon AF Fisheye-Nikkor 16mm f/2.8D +6 more
Oscarroos Senior Member • Posts: 2,914
Re: Always OFF ...
 Oscarroos's gear list:Oscarroos's gear list
Nikon Coolpix 5700 Canon PowerShot S95 Nikon D200 Nikon D700 Nikon D800 +13 more
Kaj E Veteran Member • Posts: 9,105
Re: VR is a compromise
A stable camera always  wins over VR. If the camera is stable the image will be shaper without VR. VR involves a "vibrating" lens element that degrades image quality. But if your handshake is strong enough the VR will give you an acceptable image, but not as good as if the  camera would have been stable without VR.
Nikon therefore only makes VR for professional lenses where it is needed the most (long lenses where the effect of handshake is critical. Nikon and Canon do not have VR on their 24-70 for a reason.
VR on wide lenses is a challenge as the negative effects are stronger than on lenses with a narrow angle of view due to  the way VR works: http://www.dpreview.com/forums/post/29069086 . Case in point corner and edge performance of the 16-35mm f/4 VR.
Use VR only when needed.
Kind regards
Kaj
http://www.pbase.com/kaj_e
WSSA member #13
It's about time we started to take photography seriously and treat it as a hobby.- Elliott Erwitt
